Definition Product Audit vs. Dock Audit vs. Layout Audit - Differences
I
Isocyanate
Hi there,
What is the difference between a Product Audit, Dock Audit and Layout Audit.
How often should these be conducted in accordance to the standard? What are the major differences? I have been using an old schedule that combines Product/Dock/Layout.
I have recently discoverd that the layout audit should be done on an annual basis.( Is this like a a requalification?) what charaterristics/physical properties should audited in this?
Are product audits always on Finished Goods??? Does anyone have a format od these audits...???? A lot of questions.. Sorry.
Thanks for your answers
Stijloor
Re: Different between Product/Dock/Layout Audit
Welcome to The Cove! :agree1: :agree1:
A Product Audit is required by ISO/TS 16949:2002. Look at the requirement and implement it so that it serves your organization. Some organizations use roving inpectors for that purpose. They go from station to station based on a predetermined inspection schedule based on potential risk and criticality of the product.
A Dock Audit can be viewed as a Product Audit as well, but be aware that some Customers have included this in their Customer Specific Requirements (CSR's).
The Layout Inspection requirement is usually contained in the CSR's. Chrysler would be a good example of a Customer that requires this.
Keep in mind that you must study your CSR's to determine the specific inspection and audit requirements. Next, look at ISO/TS and make it work for you.
Stijloor.
Howard Atkins
Forum Administrator
I have a slightly different view:
Product audits are required by TS as said by Stiljoor
8.2.2.3 Product audit
The organization shall audit products at appropriate stages of production and delivery to verify conformity to all specified requirements, such as product dimensions, functionality, packaging and labelling, at a defined frequency.
As it states here "appropriate stages" I disagree that the dock audit answers this requirement.
The dock audit was a requirement from QS9000 and has been adopted by some to mean the product audit, most dock audits do not audit the part to the same level as required by the clause. I also would say that as invariably the Dock Audit is part of the normal flow of the part as seen on the Flow Chart and Control Plan it is not an audit.
The product audit in my mind is based on the requirements of VDA 6.5, for examples see the following post Product Audit
8.2.4.1 Layout inspection and functional testing
this is not an audit rather
A layout inspection and a functional verification to applicable customer engineering material and performance standards shall be performed for each product as specified in the control plans. Results shall be available for customer review
This can be performed at the companies instigation or as required by the customer.
The use of layout at your own instigation should be as a result of the various risk analyzes that you have performed.
Some customers require an annual layout others do not.
As always read what the standard actually says
JaneB
Guys, that's a new one on me. What is a 'dock' audit?
Inspection of finished goods prior to shipment, sometimes done after the goods have been staged for shipment on the shipping "dock."
JaneB
Is this the same as/similar to a final inspection before release?
Matt Swartwood
Yes it's similar. The difference is that with a dock audit, it is a last chance audit to verify customer specific requirements are met. This audit could include dimensional, packaging methods, count accuracy, bar code labeling requirements, etc. We sometimes use dock audits to verify corrective action effectiveness and also as a short term containment plan for corrective action.
Isocyanate, the following would be my definitions of the terms you listed without knowing the application or field that you are in.
Product Audit: In process inspection that inspectors or the operators perform periodically throughout their production run to ensure continued compliance to the print or to meet statistical requirements. The control plan or part specific inspection instructions usually are used to dictate how many pieces to check and at what frequency. This is not 100% dimensional inspection; only a few critical dimensions.
Dock Audit: Sometimes categorized as a product audit, but in a nutshell is a last chance verification to customer specific requirements as described above response to JaneB. Typically, the quantity of parts is dictated by an AQL level or percentage of the total shipment. The frequency of inspection could be each shipment or if on a skip lot plan, could be every 5 or 10 shipments. This is also not 100% dimensional verification (if any at all); only key dimensions.
Layout Audit: Never heard this called an audit, but I am assuming you are talking about the first article inspection. Some call it Initial Sample Inspection Report (ISIR), some call it Pre-Production Approval Process (PPAP), and some call it First Article Inspection (FAI). All of these are typically a 100% inspection on one or more pieces. This data, along with other manufacturing information, material traceability, etc is sent to the customer for approval before production can begin. Some customers require periodic re-verification annually to ensure that your processes are still in check.
Hope this has been of some help to you.
Howard Atkins
Forum Administrator
This is one of the occasions where there is a real difference between English and American.
By definition an audit cannot be a routine inspection, cannot be in the normal flow of production otherwise it is not an audit but part of the normal production.
ralphsulser
You are correct, the automotive customer specifics for Ford require an annual layout of each part and the report and parts available for review.
We have a monthly schedule to cover all the parts during the year
<snip>
Just for clarity, "PPAP" stands for Production Part Approval Process, and the term isn't synonymous with layout inspection. PPAP usually includes a layout inspection report, along with a whole lot of other stuff. Also, a layout doesn't necessarily involve a first piece or first article; in the automotive world it's sometimes required on an annual basis, long after the PPAP and initial layout have been approved.
U Dock Audits - Isn't waiting to do an audit when the product is "supposed" to ship a little late? Manufacturing and Related Processes 12
D Dock Audit (Product Audits and Process Audits) database wanted Quality Assurance and Compliance Software Tools and Solutions 20
Q Dock Audit - Reasons to do dimensional checks during product dock audit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S QS-9000 Clause 4.10.4.2 - Final Product Audit vs. Dock Audit QS-9000 - American Automotive Manufacturers Standard 6
M Dock Audits - 4.10.4.2 Final Product Audit QS-9000 - American Automotive Manufacturers Standard 4
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
C TS16949: Product Audit vs. "Regular Checks" Internal Auditing 1
P May I combine the Process Audit and Product Audit into Delphi's LSR? Customer and Company Specific Requirements 3
J Questionable Audit Finding about Revision Levels of Product Manual CD's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Requirement for NB audit with Discontinued Product EU Medical Device Regulations 3
J Product and Process Audit according to ISO/TS 16949:2009 Process Audits and Layered Process Audits 9
S Supplier Audit Questionnaire for aerospace product suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Anvisa Manufacturer Audit - Product produced at two different Sites Other Medical Device Regulations World-Wide 3
W Definition Product Audit - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O Product Audit for Rubber Parts for Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q How to Audit the Client Quality System - Product Failure caused by no Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L EN 45011 (European Standard for Product Certification) Audit Checklist needed Other ISO and International Standards and European Regulations 3
A Non-Conforming Product vs. Supplier Audit Finding Supplier Quality Assurance and other Supplier Issues 8
Q Product Audit Check List according to VDA VDA Standards - Germany's Automotive Standards 1
A Seeking: documentation for intrinsically safe product audit General Auditing Discussions 6
A How to calculate the Effectiveness of the Process and Product Audit System Internal Auditing 10
michellemmm Software Product Development Quality Assurance (PDQA) Audit Checklists Software Quality Assurance 12
Q Product Characterization Audit - What is "Characterization" IATF 16949 - Automotive Quality Systems Standard 7
R Product Audit Checklist according to ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 24
Q What should be Audited in a Product Audit IATF 16949 - Automotive Quality Systems Standard 14
harrysons Product Audit Checklist - Please give some advice or share your opinions Software Quality Assurance 10
A Product Audit - Traceability of Sand used Internal Auditing 8
B What is in a Product Audit? TS 16949 Clause 8.2.2.3 Process Audits and Layered Process Audits 21
K Help in meeting the requirements in 8.2.2.3 Product Audit of TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
V Is Product Audit Mandatory as per ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 19
somashekar Product audit for using the safety mark (ETL) on label Other Medical Device and Orthopedic Related Topics 2
Ajit Basrur Process and Product Audit format needed Process Audits and Layered Process Audits 1
R Product Audit Summary Form needed IATF 16949 - Automotive Quality Systems Standard 5
B What is the full name of QKZ in product audit? IATF 16949 - Automotive Quality Systems Standard 8
H Product Audit - TS 16949 Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 18
K Mock Audit Log Form Template for Product Recall/Return at Food Plant Document Control Systems, Procedures, Forms and Templates 8
P Product Audit looking at Conformity, not Effectiveness General Auditing Discussions 6
C Audit NonConformance - Evidence of Post Market Vigilance and Product Recall. ISO 13485:2016 - Medical Device Quality Management Systems 6
J AS9100 Clause 7.4.3 Verification of Purchased Product (audit Finding) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 30
Icy Mountain Product Audit Process Requirements - Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 35
