Definition Product Audit vs. Dock Audit vs. Layout Audit - Differences
ralphsulser
#11
Here is a latest list of items we have to supply for PPAP to be accepted. I replaced our company name with "OUR":
FORD
Ref.:Global Phased PPAP Requirements Handbook Appendix D
TABLE OF CONTENTS
PPAP Requirements-Functional checklist
TAB ITEM # Requirement
A 1 Design Record FORD DRAWING
B 2 Engineering Change Documents N/A NO SREA or ALERTS REQUIRED
C 3 Customer Engineering Approval FORD DVP & R, ESER, PTF-024 Characteristic classification Transmittal (Pass thru characteristics)
D 4 Design FMEA FORD DFMEA
E 5 Process Flow Diagrams OUR FLOW DIAGRAM
F 6 Process FMEA OUR PFMEA
G 7 Control Plan OUR CONTROL PLAN
H 8 Measure System Analysis Studies OUR (Gage R&R)
I 9 Dimensional Results OUR LAYOUT-Bubble print, dimensional results report & 2 samples marked 1 and 2
J 10 Records of Material/ OUR METALLURGICAL
Performance Test Results DATA & STEEL
CHEMICAL ANALYSIS REPORT, CQI-9, and WHTX audit report
K 11 Initial Process Studies OUR CAPABILITY STUDY
L 12 Qualified Laboratory Documentation N/A NO OUTSIDE LAB
M 13 Appearance Approval Reports N/A NON APPEARANCE ITEM
N 14 Sample Production Parts OUR SUPPLIED TO PRODUCT
ENGINEERING
O 15 Master Sample OUR RETAINS
P 16 Checking Aids MSC LISTS
Q 17 Customer Specific Requirements FORD SPECIFIC-Trademark requirement/Exemption, Capacity report
R 18 PPAP/PSW Warrant OUR SUPPLIED
S 19 Bulk Material expectations NOT APPLICABLE
T 20 ELV Reporting IMDS System
U 21 AIAG Bar-Coded shipping label OUR SUPPLIED
V 22 Packing Method-Dunnage OUR SUPPLIED
W 23 ISO/TS 16949:2002 Certification OUR SUPPLIED-AQA INTL.
X 24 ISO 14001:2004 Certficate OUR SUPPLIED-ORION
Matt Swartwood
#12
Very similar to what we submit to the trucking industry. I stand corrected on the acronym PPAP. I knew that.. not sure what I was thinking LOL :confused:
dianel
#13
I audit the items on my control plans or only items that i have seen nonconformities/customer complaints in the past. Otherwise, what is the use? I dont believe in a dock audit. If processes are in control and stable upstream you wont need a dock audit. In addition, if processes are not in control and stable your audit /containment should be done upstream so the least amount of "rework" or damage is done. As far as i am concerned, once something gets to the dock it is too late to be prevented, costs too much, and goes against the entire concept of ISO itself.
H
HONEST_123
#14
Re: Different between Product/Dock/Layout Audit
Product Audit: In process inspection that inspectors or the operators perform periodically throughout their production run to ensure continued compliance to the print or to meet statistical requirements. The control plan or part specific inspection instructions usually are used to dictate how many pieces to check and at what frequency. This is not 100% dimensional inspection; only a few critical dimensions.
Dock Audit: Sometimes categorized as a product audit, but in a nutshell is a last chance verification to customer specific requirements as described above response to JaneB. Typically, the quantity of parts is dictated by an AQL level or percentage of the total shipment. The frequency of inspection could be each shipment or if on a skip lot plan, could be every 5 or 10 shipments. This is also not 100% dimensional verification (if any at all); only key dimensions.
Layout Audit: Never heard this called an audit, but I am assuming you are talking about the first article inspection. Some call it Initial Sample Inspection Report (ISIR), some call it Pre-Production Approval Process (PPAP), and some call it First Article Inspection (FAI). All of these are typically a 100% inspection on one or more pieces. This data, along with other manufacturing information, material traceability, etc is sent to the customer for approval before production can begin. Some customers require periodic re-verification annually to ensure that your processes are still in check.
Stijloor
#15
Look at Post #3 in this thread (from our Fellow Cover Howard Atkins) for an explananation of "Layout Inspection."
Stijloor.
#16
See my earlier post in this thread.
John Broomfield
#17
Is this the same as/similar to a final inspection before release?
A dock audit is for someone independent to experience what the customer experiences on unpacking the product ready for use.
As you can imagine, it can be expensive, disruptive and very valuable so it must be carefully planned and taken very seriously. It could be part of design validation.
It is obviously not done on music CDs!
BTW, this activity has to be independent to be called audit, otherwise it is monitoring, measurement, inspection, testing or management.
Abdul Majid
#18
Final Inspection id seperate from dock audit,
dock audit includes the packaging condition , material as per invoice.etc.
rshollack
#19
Dock Audit sometimes is incoming inspection or EOL inspection to verify product is ready for shipment.
Product audits are random. The auditor verifies all requirements are followed. An operator may perform a First off inspection and the auditor will verify the inspections have been completed. On a product audit, the auditor may verify a dimensional reading. The audit verifies that actual inspection has taken place and requirements have not been 'pencil whipped' by the operator.
#20
Welcome to the Cove! Perhaps you can throw some light on your experience of doing these audits. Others may have a different idea about when and where to do these audits - which may conflict with your comments - so, some further background on your knowledge of doing audits would help greatly.
U Dock Audits - Isn't waiting to do an audit when the product is "supposed" to ship a little late? Manufacturing and Related Processes 12
D Dock Audit (Product Audits and Process Audits) database wanted Quality Assurance and Compliance Software Tools and Solutions 20
Q Dock Audit - Reasons to do dimensional checks during product dock audit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S QS-9000 Clause 4.10.4.2 - Final Product Audit vs. Dock Audit QS-9000 - American Automotive Manufacturers Standard 6
M Dock Audits - 4.10.4.2 Final Product Audit QS-9000 - American Automotive Manufacturers Standard 4
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
C TS16949: Product Audit vs. "Regular Checks" Internal Auditing 1
P May I combine the Process Audit and Product Audit into Delphi's LSR? Customer and Company Specific Requirements 3
J Questionable Audit Finding about Revision Levels of Product Manual CD's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Requirement for NB audit with Discontinued Product EU Medical Device Regulations 3
J Product and Process Audit according to ISO/TS 16949:2009 Process Audits and Layered Process Audits 9
S Supplier Audit Questionnaire for aerospace product suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Anvisa Manufacturer Audit - Product produced at two different Sites Other Medical Device Regulations World-Wide 3
W Definition Product Audit - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O Product Audit for Rubber Parts for Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q How to Audit the Client Quality System - Product Failure caused by no Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L EN 45011 (European Standard for Product Certification) Audit Checklist needed Other ISO and International Standards and European Regulations 3
A Non-Conforming Product vs. Supplier Audit Finding Supplier Quality Assurance and other Supplier Issues 8
Q Product Audit Check List according to VDA VDA Standards - Germany's Automotive Standards 1
A Seeking: documentation for intrinsically safe product audit General Auditing Discussions 6
A How to calculate the Effectiveness of the Process and Product Audit System Internal Auditing 10
michellemmm Software Product Development Quality Assurance (PDQA) Audit Checklists Software Quality Assurance 12
Q Product Characterization Audit - What is "Characterization" IATF 16949 - Automotive Quality Systems Standard 7
R Product Audit Checklist according to ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 24
Q What should be Audited in a Product Audit IATF 16949 - Automotive Quality Systems Standard 14
harrysons Product Audit Checklist - Please give some advice or share your opinions Software Quality Assurance 10
A Product Audit - Traceability of Sand used Internal Auditing 8
B What is in a Product Audit? TS 16949 Clause 8.2.2.3 Process Audits and Layered Process Audits 21
K Help in meeting the requirements in 8.2.2.3 Product Audit of TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
V Is Product Audit Mandatory as per ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 19
somashekar Product audit for using the safety mark (ETL) on label Other Medical Device and Orthopedic Related Topics 2
Ajit Basrur Process and Product Audit format needed Process Audits and Layered Process Audits 1
R Product Audit Summary Form needed IATF 16949 - Automotive Quality Systems Standard 5
B What is the full name of QKZ in product audit? IATF 16949 - Automotive Quality Systems Standard 8
H Product Audit - TS 16949 Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 18
K Mock Audit Log Form Template for Product Recall/Return at Food Plant Document Control Systems, Procedures, Forms and Templates 8
P Product Audit looking at Conformity, not Effectiveness General Auditing Discussions 6
C Audit NonConformance - Evidence of Post Market Vigilance and Product Recall. ISO 13485:2016 - Medical Device Quality Management Systems 6
J AS9100 Clause 7.4.3 Verification of Purchased Product (audit Finding) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 30
Icy Mountain Product Audit Process Requirements - Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 35
