Product Requalification Test - Auditor want us to carry out
bpritts
Involved - Posts
#12
Well, I was ready to state that Ford requires an annual requalification as one of their C.S.R.'s... but, when I checked, they do not specifically require
engineering spec tests, only dimensional layout. (Ford CSR 4.42). Meanwhile my experience with GM is that they do not require periodic requalifications, at least at the system/ C.S.R. level. Of course, what matters is what your specific customers demand. I agree with the others who do not believe that there is any general requirement for periodic test requalification.
Another document that might help to define testing is the DVPR (Design
Verification Plan and Report). This is usually done by the design function, whether customer or supplier.
Regards...........Brad
P
Panayiotis
#13
Dear All
The Auditor was referring to 8.2.4.1 Layout Inspection and Fuctional testing.But my question is that although the standard says "shall be performed" I dont have any CSR and I can have also in writing that is not required can I get away with it or in a next audit will be a NC:confused:
#14
Dear All
8.2.4.1 says nothing about, and doesn't even hint at, revalidation, or requalification, or re-anything. If this is your auditor's sole criterion, he's just wrong. You shouldn't try to fix something that's not broken.
Marc
#15
8.2.4.1 says nothing about, and doesn't even hint at, revalidation, or requalification, or re-anything. <snip>
That's where the definition aspect came into play. The original post stated "Requalification", but as the thread has progressed it has come down to:
This reintroduces the question of how "Requalification" and "Product Requalification" are defined.
Dear All
In short, there was a language or wording issue. This is all about the aspect of the TS 16949 requirement for "8.2.4.1 Layout Inspection and Functional testing" and has nothing to do with "Requalification" or "Product Requalification".
I think the question now is: If the company is registered (aka certified) to TS 16949, can a customer give the company some sort of "Not Required" exemption statement to avoid having to comply with the TS 16949 Clause 8.2.4.1 requirements.
I'm sorta flying blind because I don't have a copy of the current TS 16949 at hand to reference.
I'm adding this:
Yes, I think these are in the customer specific requirements (paragraph numbers may not be the latest version)
Chrysler CSR 4.2.8 Continuous Conformance - Annual
Ford 4.42 Layout Inspection and Functional Testing - Annual
GM 4.2.5 Layout Inspection and Functional Testing - None unless told
Is your customer one of these companies? If so, why are you exempt?
Secondarily, are you only supplying 1 automotive customer?
Lastly, are you a Tier 1 supplier?
Howard Atkins
Forum Administrator
#16
I repeat what I posted before
Did he say Re-qualification or verification? because
8.2.4.1 Layout inspection and functional testing
A layout inspection and a functional verification to applicable customer engineering material and performance standards shall be performed for each product as specified in the control plans. Results shall be available for customer review.
This is a specific TS requirement not connected to CSR's or customers. The control plan MUST control layout inspection, if or if not the customer requires it
1010011010
#17
it might be a little late, but to untangle the wording confusion a bit...it all comes down to the translation of the ISO/TS 16949 into other languages:
English: "8.2.4.1 Layout inspection and functional testing"
German: "8.2.4.1 Requalifikationspr?fung"
Now take the German and put it back into English - "Requalification Testing"
You probably can imagine how much I was struggling myself with the wording. However, some things seem a bit clearer to me now - even though it's foggy outside :yes:
L Product Requalification for Plastic Injected Parts APQP and PPAP 3
D Periodic Product Requalification Process IATF 16949 - Automotive Quality Systems Standard 1
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Extension to shelf life of new product under MDR EU Medical Device Regulations 1
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
R Compatibility studies - combination product CE Marking (Conformité Européene) / CB Scheme 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
dinaroxentool Selling a product in Both UK and EU after Brexit UK Medical Device Regulations 9
P EU MDR Translation of Product Name EU Medical Device Regulations 0
N Is this a single integral drug device combination product EU MDR CE Marking (Conformité Européene) / CB Scheme 1
V New Product Model CE Mark Certification under MDR EU Medical Device Regulations 0
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
S How long does it take to register a product with MHRA? UK Medical Device Regulations 4
D Classification of product for clinical trials EU Medical Device Regulations 14
N Adding unclassified product to the medical device registration US Food and Drug Administration (FDA) 1
B Internal Auditor Competency - Product Auditors Internal Auditing 9
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
S AS9120B - 8.5.2 Delivering Split Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Classification of a product according to MDR EU Medical Device Regulations 3
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
Felony Melony New Product Launch - Safe Launch Customer and Company Specific Requirements 1
Marcel DS How do I know if my product is required be RoHS certified? REACH and RoHS Conversations 6
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
A ISO 11135:2014, B.1.4, BI resistance x product bioburden ISO 13485:2016 - Medical Device Quality Management Systems 6
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
R Product Recall - medical devices in the hospital warehouse Canada Medical Device Regulations 2
A Software bug fixes after shipping a product EU Medical Device Regulations 3
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
H Operational planning and product and service provision when things happen so fast ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Letter to file for Product Certification CE Marking (Conformité Européene) / CB Scheme 0
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Can a Contract Manufacturer "release" product on behalf of client to the market? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Formal Q Self Assessment - Problem with assigning Product and Process Customer and Company Specific Requirements 1
S California Cleaning Product Right to Know Act - Product Label advice needed Miscellaneous Environmental Standards and EMS Related Discussions 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
H PCD remains valid for new product ISO 13485:2016 - Medical Device Quality Management Systems 11
