Production duties vs. Final Acceptance Testing - New Quality Manager needs HELP!!!
MsHeeler
How do I explain to our new Quality Manager that when a quality inspector performs production duties they can not do final acceptance testing their own work? :eek:
I have tried everything I know!!!!
I'm afraid I will need more help with this guy....
BTW - I have an audit coming up and I just went thru my procedures and found some items that needed updating, he said that they were fine the way they are. :biglaugh: I will let him answer the auditor.
MsHeeler
CarolX
Hi MsHeeler,
Why can't they? Can you provide a little more info on what you company produces? I know certain industries require independence of the final part approval, but this is not mandatory in many fields. I know most folks are accustomed to this type of enviroment, but it really isn't a requirement.
MsHeeler
We make optical devices and most of the final inspection is visual. I just don't see how that can be ok. Then why have a quality department, production could do final acceptance test on their own work?
I'm sorry I don't get it...:mg:
MsHeeler
Unless you are in a regulated field that specifically states this requirement, there is no reason that a production operator cannot final inspect their own work. A facility that I worked in with the best quality that I have seen had 0 quality inspectors. All inspection was performed by the operators, and they were very concientious about it because they had no inspector to fall back on.
By the way, this was an ISO9001 and Q-1 plant.
I agree with Miner; there's no reason that operators can't inspect their own work, and certainly no reason that dedicated inspectors can't do both in-process and final inspection.
qcman
Registered Visitor
I want my people cross trained as much as I can so I end up doing just what you are saying you can't do all the time. On another angle one of my goals is to have the operators do all or as much inspection as possible.
Wes Bucey
Prophet of Profit
I agree with most of the other responses: Redundant inspection is often just that - redundant and unnecessary. We often talk about best practices using in-process inspection. The sense I get from your post is one where the final inspector is "judge, jury, and executioner." We like to think that inspection is an opportunity to
  1. confirm the process is in control
  2. point out areas for concern or improvement
Who better to have first hand knowledge whether the process is in control or to recognize opportunities for improvement than the operator who is making the part?
Thanks for raising this question - it should provide grist for good discussion!
Helmut Jilling
Auditor / Consultant
MsHeeler
The Quality Dept. can serve many functions, but two in particular in your case. Presumably, they are more highly trained than general operators in the doings of the "Science of Quality." These higher skills can be applied however you choose. Some do inspection, some testing, some auditing, wherever you want to deply them.
The second aspect, is commonly they reinspect a smaller population of parts, to ensure that the first line of operator/inspectors are achieving the level of performance we want them to achieve.
If they find the first line is doing a great job, then you can rely on it. But, if the Q people reinspect the same population all the time, then you are doing redundant work. If this is necessary, then your first line is not effective, and you should take corrective action, and redesign the approach.
You don't inspect the soda you drink for lunch, do you? You just open it and drink.
SteelMaiden
MsHeeler
we don't....have a quality department, that is. Even our laboratory ops are production people.
It all goes back to, it depends on your company's culture. you've either given your employees the ownership, responsibility and authority they need to operate on their own, or you haven't, in which case they might well be working under what I call "ship it" philosophy. All production cares about is getting it out the door, no matter what the quality. This leads to separate inspection functions, additional personnel, lack of ownership.
Of course, there are industries out there that require separate inspection...that is your call to determine the regulatory requirements.
good luck
G Clause 8.5.1 -- Is non Identification evidence of ineffective control of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
D 10.2.3 Problem Solving - What to look for at a non production remote site? IATF 16949 - Automotive Quality Systems Standard 4
C Production not following AS9100 std AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J API Q1 - 5.7.1.5 - Validation of Processes for Production and Servicing Oil and Gas Industry Standards and Regulations 4
J Non_GMP (PIC/S 010) production in a GMP area ? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
P KPI Template for Daily Production Manufacturing and Related Processes 6
A Production for same product at two production sites AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K ISO 2859-5 (single run production) control plan issues FMEA and Control Plans 2
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
H Pre-production units & Purchasing/Supplier/Material controls ISO 13485:2016 - Medical Device Quality Management Systems 6
T Design Transfer & use of "prototype" components in production devices. ISO 13485:2016 - Medical Device Quality Management Systems 10
T Cease Production Sample Procedure Manufacturing and Related Processes 1
S Exclusion of chapter 7.5 production for clinical investigation ISO 13485:2016 - Medical Device Quality Management Systems 1
M Quality Manager and Production Manager Advice Quality Manager and Management Related Issues 19
W Posting Non-Quality System instructions on the Production Floor Manufacturing and Related Processes 13
Z PSW approval process for production IATF 16949 - Automotive Quality Systems Standard 2
B EO Production Batch Failure ISO 13485:2016 - Medical Device Quality Management Systems 1
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
B Documents for production process IATF 16949 - Automotive Quality Systems Standard 8
Watchcat When to begin putting together postmarket production QMS for a mobile app? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
H Production Validation- CE Mark ISO 13485:2016 - Medical Device Quality Management Systems 3
S Wooden Pallets in Production Clean Room Food Safety - ISO 22000, HACCP (21 CFR 120) 5
A Production line for medical devices Other Medical Device Related Standards 1
O PPAP'ed part manufacturer has discontinued production Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 7
I Static Mixer on Solution production Mixer Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
A Traceability unequal lots/batches delivery production IATF 16949 - Automotive Quality Systems Standard 8
qualprod Setup time only at starting production? Lean in Manufacturing and Service Industries 5
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
DuncanGibbons Pre FAI production terminology AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
O Production run inventory sell-by expiration date? APQP and PPAP 3
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 9
D 6.1.2.3 Contingency Plan - Dispositions to restart production after an unplanned stoppage IATF 16949 - Automotive Quality Systems Standard 3
S Production Work Order Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
thisby_ Post Market/Production Risk Assessment ISO 14971 - Medical Device Risk Management 0
Felony Melony Project Milestone Plan-Development to Mass Production APQP and PPAP 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
R Monitor production quality - Internal KPIs Manufacturing and Related Processes 5
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Conformity assessment based on a quality management system or production quality assurance EU Medical Device Regulations 3
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
Q ISO 9001 8.5.1 - Control of production and service performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
