Production Equipment Forms - Case study with ISO 9001:2008
solarcon5
Hello guys i need help please. Can someone answer in this problem ??
?A small company that has been specialised in the production of plastic bags is been under investigation for compliance with ISO 9001:2008 ?.
During the inspection of Department of Production, it appeared that two ?Extruder? used the same (identical) production form but with different data encoding. In the ?Extruder? 1 production form brought encoding E-QA-7.5.1 -3, version 2 from 01/01/2012 and the Extruder 2 form production brought encoding E-QA-7.5.1 -3, version 1 since 01/06/2009?.
Is this confirmation or not according to ISO 9001:2008? And if it is, what paragraph is? HELP ME PLEASE !!!!
Re: help for a case study with ISO 9001:2008
Perhaps you could give us your ideas? Are you studying for a test/exam? If you tell us what you think the answer is, that would help.
solarcon5
Thank for you answer Sir
Yes I am a student from Greece. Please did you any idea ?
I found Paragraph 7.5.3 mark 3 in ISO 9001:9008. Is it suitable ?
It appears to be an auditing question. Did you think there's a problem here? If so, why? Please describe why you think it's a problem.
solarcon5
i think has something to do with traceability traceability... I think is Non-Conformance with 7.5.3
7.5.3 IDENTIFY AND TRACK YOUR PRODUCTS
Establish the unique identity of your products.
Identify the monitoring and measurement status of your organization's products.
Marc
Hunkered Down for the Duration
Re: Case study with ISO 9001:2008
I assume you are referring to a form. I assume you mean each form is a bit different. Please define "data encoding".
Off hand it doesn't matter that although the production machines are identical each has a specialized form.
Do they make (extrude) the same exact product? Is one machine newer than the other? If they produce the same thing can the products one outputs be differentiated from products the other outputs? Is there a requirement for traceability to begin with?
The question does not really provide enough information to give a definitive answer. More information is needed.
Sidney Vianna
Post Responsibly
As Marc said, we would need more information to give a definitive answer, but, in principle, based on what I understood from the scenario you described, the different versions of the "production forms" might impact the homogeneity of the products; thus creating a quality problem. If that is the case, the problem, in terms of conformance with ISO 9001:2008 lies in section 4.2.3 d) & g). Apparently one of the forms is obsolete, and might be providing erroneous process setup parameters for the extruding machine.
solarcon5
same (identical) production forms with different encoding numbers
I think that the use of extruder Involve the requirement for traceability
Marc
Probably is a traceability issue, with each "assigned" to a specific machine. Doesn't sound like a problem to me. Machines are never totally, truly identical.
For example - In metal forming you may have 2 identical presses but each will be a bit "different" in one way or another. Usually the production forms for each are identical but there is a place on the forum to identify which press the form was filled out at. The same condition is met by having a nearly identical form but (for example) a different form number for each (which sounds like what you are describing). This is not typically done because it's easier and cheaper to have a bunch of identical forms printed and have the operator identify which press (or machine) was used in a field on the form.
Randy Lefferts
It sounds like a document control issue (4.2.3), as Sidney posted. Two identical forms being used with different rev. levels.
Solarcon - you have mentioned traceability a couple of times. Traceability (7.5.3) applies to the actual product. In 7.5.3 it does state that records shall be maintained. Your forms (that you apparently have 2 different versions of) become the records that include the appropriate information, once filled in. However, the forms will be controlled via the document control section of the standard. Thus, if I am reading your question correctly, your issue is with the 4.2.3 section of the standard, not the 7.5.3 section. You basically have 1 form (the original version one, dated 1/6/2009) that has been updated in 2012 (now becomes version two, dated 1/1/2012) and not all of the original 2009 forms have been removed from the production area (as required by 4.2.3) to prevent their use.
As I said, my response is based on the assumption that you are auditing your production area and found 2 identical forms with different revision levels, being used on 2 different machines. It is also assumed that what you mean by "data encoding" is actually the revision level.
N Calibration Requirements for Production Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Maintenance requirements for Production Equipment in AS9100D General Auditing Discussions 8
A ISO 9001 Control of Production Equipment - CNC Machines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Calibration of processing equipment - 21 CFR 820.70 Production and process controls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
B AS9100C 7.5.1 d and calibrated equipment in the production areas AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
W Production Equipment Cleaning Protocol Example Needed Other Medical Device and Orthopedic Related Topics 2
T Control of Production Equipment - Seventh Procedure AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
J AS9100 C - 7.5.1.3 - How do you handle Production Equipment Maintenance? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
B What is "Use of suitable production equipment" - ISO 9001 Clause 7.5.1 c) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Validation of processes for production for Test Equipment ISO 13485:2016 - Medical Device Quality Management Systems 9
K Gauge (gage) R&R for production equipment/fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
L Control of Production Equipment, Tools and NC Programs: 7.5.1.3 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 12
A Control of Production Equipment,Tools and Numerical Control (N.C.) Machine Programs AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
G AS9100A - Production Equipment, etc... AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
C Production and Post Production feedback - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 4
DuncanGibbons How is the arrangement between Design and Production organisation envisaged? EASA and JAA Aviation Standards and Requirements 4
J Production Line Test Brasil - High Voltage Dielectric Strenght Test Other Medical Device Regulations World-Wide 5
J Iterative design and production for custom made products ISO 13485:2016 - Medical Device Quality Management Systems 3
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
S How do you record your Nonconforming product? Batch production of staged processes Nonconformance and Corrective Action 2
A When there is a 2 year lapse in production, is a full FAI required? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
P Definition of production tooling in IATF16949 clause 8.5.1.6 IATF 16949 - Automotive Quality Systems Standard 4
Moncia Production Planning procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
A Production of raw materials in university labs? Lean in Manufacturing and Service Industries 11
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Customer audit demands - that I state in my QM who can shut down production AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
Ed Panek Bringing Production In house ISO 13485:2016 - Medical Device Quality Management Systems 10
Q IATF 16949 certification without automotive products in "production" IATF 16949 - Automotive Quality Systems Standard 5
Ed Panek Small Medical Device company - Bring production in-house ISO 13485:2016 - Medical Device Quality Management Systems 1
Mr Skeleton PV (Production Validation) test plan responsibility APQP and PPAP 21
D Valeo 5 Axes and VPS (Production System) Lean in Manufacturing and Service Industries 1
C Medical Device Stability Studies - Non-validated pilot production Other Medical Device Related Standards 1
Ed Panek Moving from Contract Manufacturing to Production In-House ISO 13485:2016 - Medical Device Quality Management Systems 3
andika_untoro What are a good Critical to Quality (CTQ) metrics for a biotech manufacturing production? Lean in Manufacturing and Service Industries 0
Ed Panek Bringing Production in house from Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
L Why is initial production units, lots, or batches, or their equivalents required for Design Validation? US Food and Drug Administration (FDA) 3
chris1price MDR Conformity Assessment for a Class 2a device - Production Quality Assurance EU Medical Device Regulations 2
Ed Panek Observational Audit of Contract Manufacturer Production ISO 13485:2016 - Medical Device Quality Management Systems 5
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
W AS9120B 8.5.1 Control of Production and Service Provision AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
Q Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
T Logic that determines what production testing is needed ISO 13485:2016 - Medical Device Quality Management Systems 2
G Medical Devices: Product/Production Quality EU Medical Device Regulations 2
R Mass production handover check sheet (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 1
