Production Line Test Brasil - High Voltage Dielectric Strenght Test
Hi there,
I have a doubt regarding Production Line Tests of medical devices for Brazil market.
Until now I was focused on the European Market and my strategy to plan the Production Line Tests and the installation tests was the norm: IEC EN 62353. The idea was applying this norm and common sense to draw a test strategy which at the end of the day can ensure that my device is safe before connecting it to the patient.
But recently I was told that for the Brazil market there are higher standards. They take as a reference Annex K of TIR 62354:2009 (which is informative for rest of the world but compulsory for Brazil). And they have some requirements, that although they go clearly against common sense they have to be fulfilled.
I explained a bit further my case.
We have a Medical Device Class I supplied from Mains. Mains is just connected to our Power Supply which concert it to a DC Secondary Circuit.
Well according to an Audit from Brazil authorities we got a deviation.
We have to perform a dielectric strength test of 1,5kV between L/N and PE during 60s for all the finished assembled devices
I have tried to argument that this test can be destructive and that it is just a type test. But my collegues told me this is a fact and that's how Brazil wants it.
My approach would be to say - We could test 1,5Kv 1 or 10 seconds and that would be more than enough.
(I am even not sure if a dielectric strength test is needed as Production Line Test)
Does anybody now about this topic?
Is there anyway written this specific requirements, or they just come from Auditors
Even the TIR 62354:2009 does not specifically say that we have to applied this test voltages.
Thanks in advance!
I would agree with you that a short duration (say 5s) would be better for production line tests.
But what damage a 1min test may cause is rather dependent on what components you have in your mains part, specifically what filter components are in place. 1k5V is not actually that high so you may not find a problem (other than nuisance).
Thanks for you answer.
Yes you are also right. For our case is not so critical, and I don't expect nothing gets damaged.
For me is a little bit to understand what is the point in doing that if the test could be destructive. And if someone is facing similar issues with Brazil authorities...
rogerpenna
Look, I know next to nothing about electric and electronic tests, nor about medical equipment.
But the link mentions using that HP5500M equipment for the CERTIFICATION test, as an example
HP5500M – Ensaio de Rigidez Dielétrica | Entran Equipamentos
"Adicionalmente ao processo de certificação, os fabricantes de equipamentos médicos ficaram obrigados a realizar ensaios de segurança elétrica em todos os produtos fabricados."
Additionally to the certification process, manufacturers of medical equipment became obliged to perform electric security tests in ALL MANUFACTURED PRODUCTS.
This is determined by ABNT NBR IEC 60601-1
ABNT is the Technical Norms Association of Brazil.
here is the link to buying the norm directly from ABNT
ABNT Catalogo
Gee, it's quite expensive. R$28k!! (right now, due to exchange rates, it's about U$5600, but just 2 years ago, when U$1 = R$3, that would be U$9300!!)
I am used to the price of civil engineering norms, the most expensive ones are about U$50-U$100.
But then, this 60601-1 norm is 2771 pages long! And ABNT prices are based on the number of pages of their norms.
BUT... this Target company also sells ABNT norms. They have won several lawsuits against ABNT, because according to the constitution or something, technical norms can´t be monopolized or something.
So Target sells the same norms for a fraction of the price and legally.
ABNT NBR IEC 60601-1-6 NBRIEC60601-1-6 Equipamento eletromédico -
Apparently, R$37 only... U$ 7,5
Q Reducing the Frequency of a Production Line Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
P Production Line Pump Cleaning Validation Method Question Qualification and Validation (including 21 CFR Part 11) 0
P Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
T Production line requirements for IATF 16949 - Need to have dedicated lines? IATF 16949 - Automotive Quality Systems Standard 3
K 21 CFR Part 11 (and EU) compliant Digital Signatures on a Production Line Other US Medical Device Regulations 5
K Mandatory Electrical Safety Tests - Regular Production Line IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
B Outsource Production Line need ISO13485 Certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
S Our Production Line at our Supplier - Who's TS 16949 Cert? IATF 16949 - Automotive Quality Systems Standard 4
E Translating AQL to a Production Line Inspection Plan AQL - Acceptable Quality Level 14
T What innovations led to Ford's production line? Coffee Break and Water Cooler Discussions 5
T How to Approach and Document a Production Line Transfer to Asia Manufacturing and Related Processes 3
R Line Balance Simulation when Designing a New Production Line Lean in Manufacturing and Service Industries 1
Q ISO 9001 clause that covers Production Line Re-Validation Quality Manager and Management Related Issues 10
I Primary Failure Modes in a Production Line - Pls help a new member FMEA and Control Plans 5
G Automated Production Line Quandary... FMEA and Control Plans 1
V Production Line Change - Moving to another country IATF 16949 - Automotive Quality Systems Standard 5
I Traceability Method for Assemblies in a Continuous Production Line Manufacturing and Related Processes 3
B Planning for production line Manufacturing and Related Processes 1
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
C Time Study in a Sewing Production Line Manufacturing and Related Processes 3
G Tagging and Tracing Nonconforming Products on the Production Line ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Bottleneck on a Production Line Lean in Manufacturing and Service Industries 11
Anerol C What protocol do you follow to stop the production line? Nonconformance and Corrective Action 9
M Correlation Production Time Study on a Process on an Assembly Line Manufacturing and Related Processes 3
P Robots in a Production Line - Control Plan and Process FMEA Manufacturing and Related Processes 9
R Line Leader Assessment form - Qualification process for production line leader Training - Internal, External, Online and Distance Learning 1
P How to prevent the LED wrong polarity when insertion on the production line? Problem Solving, Root Cause Fault and Failure Analysis 8
B Is a sewer line inside the production house a Major or Minor NC? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
M Digital video camera system portable for production line and other monitoring? Design and Development of Products and Processes 4
D Cpk and MSA study for Chemical Production Line Capability, Accuracy and Stability - Processes, Machines, etc. 4
K Process Validation - Production Line Transferring to a Different Facility Qualification and Validation (including 21 CFR Part 11) 16
J TS 16949 Certification Only for Production Line IATF 16949 - Automotive Quality Systems Standard 7
G Flowchart on How to Feedback Quality Issues to Production Line wanted Preventive Action and Continuous Improvement 5
V HACCP on automated pizza production line Food Safety - ISO 22000, HACCP (21 CFR 120) 6
S Material shortages to the production assembly line - Form and reporting system Document Control Systems, Procedures, Forms and Templates 6
S Control Chart CpK dilemma - Defect Per Unit data on a single production line Capability, Accuracy and Stability - Processes, Machines, etc. 16
R APQP and Dod Product Qualification Program (Production Line Qualification) APQP and PPAP 4
Felony Melony Project Milestone Plan-Development to Mass Production APQP and PPAP 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 9
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
R Monitor production quality - Internal KPIs Manufacturing and Related Processes 5
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Conformity assessment based on a quality management system or production quality assurance EU Medical Device Regulations 3
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
Q ISO 9001 8.5.1 - Control of production and service performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
