Profile of a Surface Tolerance - Part with a 195 mm radius on it
K
Kamranabbasian
I have a part with a 195 mm radius on it. the general dimensinal tolorance is +/-0.5mm. There is also a surface profile toltrance for 0.05mm. It is confusing for us to check this part on the CMM. what would be the radius tolorance considering 0.05mm profile limit 194.5 to 195.5 or 194.975 to 195.025?
Stijloor
Re: Profile tolorance
The profile tolerance takes precedence over the general tolerance.
(Assuming that this general tolerance is stated in the title block).
Is there a basic radius of 195 mm specified? (the 195 in a box?)
The default for profile of a surface is that the 0.05 total profile tolerance zone is equally disposed about the true profile. This means 0.025 above and 0.025 below true profile.
Now, this clarification is provided to you without seeing the actual call-out on the drawing. It is always helpful to attach a sketch.
Hope this helps.
Stijloor.
Thanks for your information. I have attached the sketch also,
I don't see a profile callout on your sketch, or a 195mm radius.
Paul F. Jackson
The radius 195 is basic so it does not have general tolerance.
The profile callout has no datum reference associated to it so it can only constrain the form of the semi-cylinder... not its orientation or location.
It is difficult to orient and fit an axis to a small portion of a cylinder but that is what must be done to examine its form relative to a perfect cylinder of 390 diameter.
A number of ideas pop into my mind of artifacts that I would look around for to lay in the semi-cylinder and probe its perpendicular surfaces to approximate the orientation of the cylinder's axis... like the sides of a precision block with precise corner or a Vee block with sharp corners or a couple of large precision roll pins. I hope you see what I mean.
Remember your job is not to discover the size and center of a "best-fit" cylinder but rather compare the minimum possible error/displacement from a best fitted perfect cylinder of 390 diameter.
Paul
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Hole Surface Profile Tolerance Discussion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
B Help with the GD&T - Tolerance for the Profile of the Surface General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
C Complex Surface Profile as a datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B Surface Profile Callouts - How the profiles are being dimensioned Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C I need to verify the surface profile of a part - Sine plates General Measurement Device and Calibration Topics 4
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B Measuring the Profile of a Surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
C Reporting Profile of a Surface Results on an Internal Cylindrical Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
G How to calculate profile of a surface? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Definition GD&T Clarification - Callout for Profile of a Surface Reference to the Datum Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 34
B How to do a profile on a surface with one datum General Measurement Device and Calibration Topics 23
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
M How to verify profile gages provided by customer General Measurement Device and Calibration Topics 5
E Department Plan for QA and HSE (profile, plans, structure, goals, etc.) Misc. Quality Assurance and Business Systems Related Topics 2
G Gear Profile & Lead Report Manufacturing and Related Processes 1
R Temperature Profile for Transport Simulation (Sterile Eye Drops) Other Medical Device Related Standards 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
quality1 Form IPC 1720A Assembly Qualification Profile still required? Various Other Specifications, Standards, and related Requirements 1
B Requirement to have Customer Signature Profile on File Document Control Systems, Procedures, Forms and Templates 4
T CMM Inspection of Profile Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
M Measuring a circle's profile Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Capability for CMM Scanned Profiles on a feature with a Bilateral Profile Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 26
C Inspecting a Profile Tolerance for a Die Cut Gasket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
AnaMariaVR2 A Profile of the Pharmaceutical Manufacturing Industry: Russia Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
optomist1 Contour vs. Profile - Is there a connection between "Contour" & "Profile"? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
optomist1 Composite Profile Tolerancing Clarification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
optomist1 ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A Customer Profiles - Creating a Customer 'Profile' for our Top 10 Customers Document Control Systems, Procedures, Forms and Templates 2
J Reputable Third Party Inspection (Metrology Lab) In USA? Cam Profile Measurement General Measurement Device and Calibration Topics 5
P ISO 20072 Requirements - Example or template of a DFP (device functionality profile) Other Medical Device Related Standards 2
O How to report Profile of a Sphere crossed by a Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
A Capability Studies for Profile (GD&T Callout) Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Changing Job Profile - Logistics Engineer to Buyer Career and Occupation Discussions 3
S Benchmarking PVC Profile Extrusion Metrics Benchmarking 2
CycleMike Profile of datum planes - Profile callout back to datum A (itself) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Angularity or Composite profile - Angularity callout on a recent print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Oven Qualification - Thermal profile during the OQ of a vacuum oven General Measurement Device and Calibration Topics 6
A Checking Profile Tolerance on CMM's Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B New Print Profile Symbol? Misc. Quality Assurance and Business Systems Related Topics 6
P Design an experiment to optimize the PCB solder reflow profile Design and Development of Products and Processes 4
K Calculation for Similarity and Differences in dissolution profile (F1&F2 Values) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
