Proof of incoming material verification - Electronic CofC's
Michel Saad
Hi folks,
We purchase material where we only compare the data supplied with our incoming material specifications, sign off the C of C, and file it. In a paper reduction effort (we have to keep stuff around for 25 years), we are looking to receive the C of C's electronically. If the C of C are received and filed electronically, how do we demonstrate that the material was verified at incoming.
Anyone out there already doing this?
thanks.
SteelMaiden
I have done this before. We started to receive all of our certs electronically and did not want to have the paper anymore. To create a record for incoming inspection i.e., does the cert match our spec, we created a spec file (our specifications for raw material) and batched all the incoming certs. We ran an edit check that passed the conforming certs and flagged the nonconforming ones. After the edit was run, it was only a matter of having someone look at the ones that did not go through and getting updated info from supplier, or initiating a rejected material process etc.
Each certification record was traceable as to when it went through the edit, if it passed, or was accepted through deviation and who did that edit step if it was not conforming etc. We still had some actual physical inspections going on at receiving, but the electronic cert stuff was really slick. I transferred before we finished the total program, but the plan was to use barcoding technology to input the rest of the receiving process automatically. i.e. read the length, check the length, if they matched you push the OK button and on it went, if not you could put it on hold in the system right from the dock without transferring a bunch of stuff to some clerk in the office.
E Wall
Just Me!
We're ISO not QS - but this might help
We receive material putting it into a designated receiving/inspection area, a month sticker is placed on pallet for FIFO and it has a sign-off block for QA Approval, QA verifies CoC or inspects part (depending on the designated criteria) then signs approval, material handler moves material to designated location, production depts know to use oldest material first and verifies QA sign-off before starting to use material on pallet (may be few or many depending on the part).
CoC's are kept for 1 year. Basically if it isn't approved by QA it isn't to be used in production. Our objective evidence is existing inventory examples - do a random check and see if anything gets through to the production machine line that isn't signed off.
Eileen
U
Unregistered
You could state that by virtue of an electronic files location it has been reviewed and approved.
I would imagine that these certs will be received as a JPEG type image to an e-mail address. Simply create a folder with secure write access and you can say that all certs in folder C:\CERTS\APPROVED (for example) have been reviewed and approved by QA (or whoever).
The auditor need only satisfy himself that the folder is secure and he should be happy.
M Greenaway (posting from home)
gpainter
We use C of C as most companies are starting to do this more and more. If a C of C is provided , then incoming inspection is waived and it moves to stock. We file in binders and have had no problem. If we went "e" then, we would just save them.
Z
Zanzi
The way that I see it is that as long as you have evidence (CofC or Inspection Cert) that material used in production conforms to the specified requirements (Specification / Goods In Contol Plan) then you need only save a copy of the C of C. This becomes more process driven by virtue of material location.
Simply define in your procedures how it is completed and comply with your stated actions. This should be more than satisfactory - as long as you demonstrate the link into non-conforming product as necessary.
G
Greg Maggard
Hey ,
That was very well stated. :lick: I actually sent the response for this treat to a friend Tim Turner also a member. They are writing a std procedure now.:smokin: great thread
K
keithm696 - 2008
C of C or C of A for raw materials
Hi all!
We use the supplier C of C or C of A for inbound materials from our suppliers. We build first aid kits and deal with lots of over the counter meds. During a recent FDA Audit I was asked a question about processing OTC meds by passing them thru a heat shrink tunnel after being unitized. Did this exposure to heat for 15 to 20 seconds change the stability of the product? We are now sending samples back to the labs to be compared to the retained samples. I use an excel spread sheet for lot # tracking of all products but this Investigator didn't want to look at anything they didn't have full control of. Any thoughts on this?
Thanks,
Keith
Al Rosen
keithm696 said:
Hi all!
Thanks,
Keith
Hi Keith:
Did you exceed the storage temperature of the meds? The FDA is tough although thety may have a valid point iof you exceeded the storage temp. They are regulators not your friendly ISO auditor.
S Nadcap - Heat Treatment Proof of Verification question for Digital results AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Proof QMS compliance for class I ISO 13485:2016 - Medical Device Quality Management Systems 1
P API Q1 - Monogram Product & API 4F - Proof Load Test Oil and Gas Industry Standards and Regulations 3
Awais How to mistake proof - Shipping Orders with Shortages - Product Quantity Accountability mismatch with Job Traveller? Manufacturing and Related Processes 17
M Proof of distribution - FedEx/UPS tracking numbers Manufacturing and Related Processes 2
L Proof of Concept Studies - Do we need to comply with SAE reporting? Medical Device and FDA Regulations and Standards News 3
R Defib-proof applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A IEC 60601-2-2 - Defib-proof test amendment to base standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M Can the CE Mark Cert be used as Proof of Sterilization Conformity? Other Medical Device Related Standards 7
W Suggest a Poka Yoke (Mistake Proof) Method for my Product Manufacturing and Related Processes 24
H Acceptable Time to provide proof of CAR (Corrective Action Report) Nonconformance and Corrective Action 4
S Category AP (Anaesthetic Proof) and non-AP IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Internal Audit - No Proof of Acceptance of Customer New Payment Terms Internal Auditing 10
G ISO 9001 Clause 7.6 Tamper Seals - Alternatives to Tamper-Proof Seals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A How to write a US FDA proof MDR procedure? Other US Medical Device Regulations 5
M Minimum number of samples to inspected for Pp & Ppk study ? Any statistical proof?? Capability, Accuracy and Stability - Processes, Machines, etc. 4
N Auditing Proof of Delivery signed by the customer - Determining Sample Size General Auditing Discussions 6
S Proof of Competency Outside of the Organization - Sending an Employee Abroad Training - Internal, External, Online and Distance Learning 4
R Control on Setting piece mix-up - Are there any fool proof systems? Quality Tools, Improvement and Analysis 2
G Posting of Initials or Names on a Computer Document as Proof of Approval or Task Done Document Control Systems, Procedures, Forms and Templates 3
R Methods and Requirements for "Proof of Concept" Design - Class 2 Medical Device Design and Development of Products and Processes 3
D Anyone familiar with IECEx (Hazardous/Explosion proof) scheme Requirements? Other ISO and International Standards and European Regulations 1
Govind What is a Proof Reading Ratio? Japanese Customer Questionnaire General Measurement Device and Calibration Topics 10
Marc No proof airport security makes flying safer - Surprise? Travel - Hotels, Motels, Planes and Trains 8
Marc 1957 Nuke-Proof Bunker Turns Out Not Waterproof World News 6
Q Proof of defect - Customer reworked all the defective parts Supplier Quality Assurance and other Supplier Issues 8
Jim Wynne Idiot-Proof Website? Funny Stuff - Jokes and Humour 5
apestate Need supplier, error-proof inspection of ID threads present attribute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
I Benefits of adding Health and Safety to an EMS - Any studies with proof? Miscellaneous Environmental Standards and EMS Related Discussions 5
Q Training Records - Proof of "training" per ISO 9001 section 6.2.2 (b) Records and Data - Quality, Legal and Other Evidence 33
Ajit Basrur "Licensed" copy of ISO 9001 Standard During Audit - Has an Auditor Asked for Proof? General Auditing Discussions 44
Steve McQuality Process Change - Proof of Transparency Statistical Analysis Tools, Techniques and SPC 2
Q Hand processes - How can you error proof human systems with out automation? Preventive Action and Continuous Improvement 7
Marc 5.1 Management Commitment - How do you comply and what proof do you have? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
W Incoming Certification Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Incoming Stock QC, where to start? Manufacturing and Related Processes 6
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
I Incoming insepction needs repair - sell as "new", "brand new", or something else Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
T Primary & Secondary Inspection Definitions - Incoming, In-process & Final Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ajit Basrur Incoming Inspection for Instructions for Use (IFU) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R Is pre-conditioning supplier component before incoming inspection tests allowed? Quality Manager and Management Related Issues 16
T How to identify requirements for 'Incoming inspection' Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Incoming Inspection Plans under Design Control (part of DMR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C ISO13485 Incoming Receiving Parts Verification ISO 13485:2016 - Medical Device Quality Management Systems 13
T Can incoming and outgoing areas be allocated inside the store? Other ISO and International Standards and European Regulations 1
