Proper Amount of Data Points for Cpk
#11
Why does the customer require 100% inspection?
The OP will have to give the specific answer of course but many Customers in the Aerospace and defense industry require 100% inspection due to the nature of the severity of the effect of a defect. They typically have a system where you can go to a sampling plan IF you can establish both a "Cpk" level and you have an appropriate control plan in place (such as SPC, PMs, training programs, etc.)
I've run into this a lot...
TWA - not the airline
#12
Thanks Bev for the explanation. I come from the medical device field and though we also deal a lot with high severity effects we have a somewhat different look on things here. Doing 100% inspection tends to give people the impression that you are not really in control, i.e. you do not know much about your processes as well as statistics and SPC. Really interesting...
#13
The A&D industry has a negative history (mostly but not exclusivley with smaller) suppliers (and there a LOT of them) not complying (first article inspection and change notification is and has been a major thorn) with requirements. They are also not well versed in statistics and SPC nor do they staff for it (especially smaller suppliers). Many of the processes are susceptable to things 'breaking' which can't be modeled or detected with continuous data SPC but these defective parts are often more catastrophic than a simple 'out of tolerance' part. Finally, a lot of parts have critical dimensions that are 'forms' or geometric curves that are very difficutl to measure and are typically inspected with go, no-go gages or optical comparitor overlays. Having struggled with obtaining compliance, control and use of statistical practices and having been involved in numerous 'ground the fleet' excursions, I actually understand the A&D OEM viewpoint.
Think about the questions we get here at the cove (thank goodness people are smart enough to know that they need to ask these questions). the vast majority of people simply don't understand good statistical and quality management practices. they aren't taught in school and when they are taught it's often mythologoy and hack training.
I am answering the same questions I answered 25 years ago. and I had to learn the answers myself through trial and error, reading thousands of published articles and books as well as desparately searching for gurus who knew what they were doing.
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
M Proper way to develop LCL when only given a lower spec limit Reliability Analysis - Predictions, Testing and Standards 7
L How to write a proper defect description in a NCR Nonconformance and Corrective Action 4
M Proper method to test flow of a regulator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Proper terms for describing Hardness General Measurement Device and Calibration Topics 5
M Proper ISO standard for Pressure Testing and Leak Rates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
D Proper Tool to Measure Wall Thickness (ISO 3611 - Micrometers) Manufacturing and Related Processes 7
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Proper Record/Document Manipulation Document Control Systems, Procedures, Forms and Templates 2
I Proper gauging of tight tolerance (reamed) holes General Measurement Device and Calibration Topics 4
kedarg6500 Selection of proper modifying agent for Aluminium Silicon Alloy Manufacturing and Related Processes 2
K Proper YTD PPM Supplier Calculation Six Sigma 3
S Proper FDA Classification for a DICOM Viewer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 29
E Measuring Parts without Proper Tools - Measurement Device Resolution Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
J Proper Method of Measuring Hex Socket Heads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Getting the proper information from the supplier - Returning Nonconforming Material Nonconformance and Corrective Action 4
G What is the proper Thanks Giving turkey sampling size? Coffee Break and Water Cooler Discussions 9
B How to Determine the Proper Solder Class Manufacturing and Related Processes 5
S What is the proper flow to feedback the defective found during QA sampling check? Quality Tools, Improvement and Analysis 8
M Proper Format for a Manufacturing Route Sheet Manufacturing and Related Processes 6
K Putting a regulated device on the market without the proper ISO Certs and CE Marking EU Medical Device Regulations 9
L Proper Personnel Ratio - Quality to Manufacturing Manufacturing and Related Processes 6
M ISO14001 nonconformance - no proper treatment of wastewater prior to discharge ISO 14001:2015 Specific Discussions 6
A What is the proper definition for Class 1 & 2 design changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Proper GD&T for spindle & housing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Proper term for 'Easy Identification'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M How to implement a proper Calibration System? General Measurement Device and Calibration Topics 5
F Is there a proper protocol to follow for Self Certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
J Proper way to calibrate a check fixture General Measurement Device and Calibration Topics 7
G Proper Poundage for Checking XX Tolerance Plain Plug Gages? General Measurement Device and Calibration Topics 2
G Labeling Responsibility - Manufacturer vs. Repacker? Proper Component Use ISO 13485:2016 - Medical Device Quality Management Systems 7
L Procedure for proper use and protection of Registration and Accreditation Marks Document Control Systems, Procedures, Forms and Templates 21
C What is the proper method for cleaning dial calipers? General Measurement Device and Calibration Topics 4
N Proper use of the Blueing process when inspecting the taper of bushings General Measurement Device and Calibration Topics 6
J Proper use of gauge pins - Inspecting thru holes of plastic parts General Measurement Device and Calibration Topics 19
I What is the proper date to use as effective date? Old 'procedures', New documents Document Control Systems, Procedures, Forms and Templates 10
D Rockwell vs. Vickers vs. Knoop - Does Thickness Determine the Proper Test? General Measurement Device and Calibration Topics 1
M What is the proper way to use a GO NO/GO guage? General Measurement Device and Calibration Topics 3
B Preventive and Corrective Action Mapping - Proper Sequencing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Registered or Certified - What is the proper terminology? QS-9000 - American Automotive Manufacturers Standard 17
John C. Abnet Must COPQ always be quantified as a monetary ($) amount? IATF 16949 - Automotive Quality Systems Standard 2
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
J Studies conducted on the amount of autoclave sterilization of a PEEK implant Other Medical Device and Orthopedic Related Topics 1
S How to make pack bolts and nuts kits with right amount Preventive Action and Continuous Improvement 3
S Glove Protein Content in μg/dm2 to μg/g and Powder Amount mg/dm2 to mg/glove Other Medical Device Regulations World-Wide 4
M Using Minitab to Compute & Compare the Mean and Standard Deviation Amount Using Minitab Software 7
