Proper terms for describing Hardness
marcusja2002
A debate in my company has come up and I'm hoping the community can help me out.
I've been taught throughout my career when you describe hardness on a drawing you use the term "Hardness" then indicate the Number and the Scale or it's also acceptable for like rubbers and plastics to shorten it to 0075 or A75 as in Shore 00 or Shore A.
Some of my coworkers are using the term Durometer 75 with no scale indicated plus a material call out. and I'm believing this is wrong, but they are pushing back saying its ok because Silicone rubber can only be in the Shore 00 range for example.
Am I being too picky in asking for a full audit and update of the drawings or are they wrong because a material called out, doesn't necessarily lead you to a path of proper scale choice and the drawings should have further detail.
What is the industry standard way to call out hardness properly?
Thanks in advance.
I would think that at a minimum you would want to call out the relevant standard (ASTM D2240, e.g.) and the scale. Whether or not this is worth backtracking and updating drawings is a different question that no one here can answer for you. It might be enough to require the proper callout on new drawings and changing the specification on old ones when other changes are being made.
marcusja2002
A durometer is a measuring instrument. I don't understand why they don't want to callout the actual requirement.
That's what I said. I made the analogy that they are saying "The side of this steel box is caliper 12" and his face got a little red and he just said thats not what I was taught. So for all I know there is a school of thought out there that teaches Durometer means Hardness, I'm just not familiar with it.
From the above comments, my gut is it has more to do with embarassement and time to audit and update drawings properly then be being wrong.
I have always been amazed at the number of engineers who don't know how to do their jobs when it comes to bullet-proofing a drawing.
I would check ASTM D2240 to be certain, but I worked 15 years in the rubber industry (20 years ago), and I believe that we used 55 Shore A.
We also used ASTM D 2000, "Standard Classification for Rubber Products in Automotive Applications", which encodes the hardness specification into the callout. D2000.png
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
M Proper way to develop LCL when only given a lower spec limit Reliability Analysis - Predictions, Testing and Standards 7
L How to write a proper defect description in a NCR Nonconformance and Corrective Action 4
M Proper method to test flow of a regulator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Proper ISO standard for Pressure Testing and Leak Rates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
D Proper Tool to Measure Wall Thickness (ISO 3611 - Micrometers) Manufacturing and Related Processes 7
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Proper Record/Document Manipulation Document Control Systems, Procedures, Forms and Templates 2
I Proper gauging of tight tolerance (reamed) holes General Measurement Device and Calibration Topics 4
kedarg6500 Selection of proper modifying agent for Aluminium Silicon Alloy Manufacturing and Related Processes 2
J Proper Amount of Data Points for Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 12
K Proper YTD PPM Supplier Calculation Six Sigma 3
S Proper FDA Classification for a DICOM Viewer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 29
E Measuring Parts without Proper Tools - Measurement Device Resolution Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
J Proper Method of Measuring Hex Socket Heads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Getting the proper information from the supplier - Returning Nonconforming Material Nonconformance and Corrective Action 4
G What is the proper Thanks Giving turkey sampling size? Coffee Break and Water Cooler Discussions 9
B How to Determine the Proper Solder Class Manufacturing and Related Processes 5
S What is the proper flow to feedback the defective found during QA sampling check? Quality Tools, Improvement and Analysis 8
M Proper Format for a Manufacturing Route Sheet Manufacturing and Related Processes 6
K Putting a regulated device on the market without the proper ISO Certs and CE Marking EU Medical Device Regulations 9
L Proper Personnel Ratio - Quality to Manufacturing Manufacturing and Related Processes 6
M ISO14001 nonconformance - no proper treatment of wastewater prior to discharge ISO 14001:2015 Specific Discussions 6
A What is the proper definition for Class 1 & 2 design changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Proper GD&T for spindle & housing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Proper term for 'Easy Identification'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M How to implement a proper Calibration System? General Measurement Device and Calibration Topics 5
F Is there a proper protocol to follow for Self Certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
J Proper way to calibrate a check fixture General Measurement Device and Calibration Topics 7
G Proper Poundage for Checking XX Tolerance Plain Plug Gages? General Measurement Device and Calibration Topics 2
G Labeling Responsibility - Manufacturer vs. Repacker? Proper Component Use ISO 13485:2016 - Medical Device Quality Management Systems 7
L Procedure for proper use and protection of Registration and Accreditation Marks Document Control Systems, Procedures, Forms and Templates 21
C What is the proper method for cleaning dial calipers? General Measurement Device and Calibration Topics 4
N Proper use of the Blueing process when inspecting the taper of bushings General Measurement Device and Calibration Topics 6
J Proper use of gauge pins - Inspecting thru holes of plastic parts General Measurement Device and Calibration Topics 19
I What is the proper date to use as effective date? Old 'procedures', New documents Document Control Systems, Procedures, Forms and Templates 10
D Rockwell vs. Vickers vs. Knoop - Does Thickness Determine the Proper Test? General Measurement Device and Calibration Topics 1
M What is the proper way to use a GO NO/GO guage? General Measurement Device and Calibration Topics 3
B Preventive and Corrective Action Mapping - Proper Sequencing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Registered or Certified - What is the proper terminology? QS-9000 - American Automotive Manufacturers Standard 17
John C. Abnet Terms- Different Items in a system ISO 26262 - Road vehicles – Functional safety 0
John Broomfield Informational Terms used in quality management [Deleted] Misc. Quality Assurance and Business Systems Related Topics 6
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
M Informational IMDRF proposed document – IMDRF terminologies for categorized Adverse Event Reporting (AER): terms, terminology structure and codes (Edition 4) – Anne Medical Device and FDA Regulations and Standards News 0
J MEDDEV 2.12/1's new MIR & IMDRF terms & codes (IMDRF Annex) EU Medical Device Regulations 1
S Measurement Terms - How do I say this in Inches? General Measurement Device and Calibration Topics 5
