Pros & Cons of FDA viewing QAU Audit Report Findings
AnaMariaVR2
What would be the pros and cons of having FDA view the contents (findings) of QAU audit reports during surveillance or for cause GLP inspections?
MIREGMGR
I'm assuming that this document substantially describes your context.
The only upside, I think, is if your internal audit report is absolutely clean, or identifies only trivial issues.
If on the other hand your internal report identifies anything more complex, you'd be doing two things: pleading "guilty" to charges that haven't even been brought yet, and likely damaging your QAU's further effectiveness.
AnaMariaVR2
Thanks MIREGMGR for the document.
Washing dirty linens in public is never a good idea, so in other words weaknesses are surrendered to inspectors altering their objectivity in the process.
The cons are obvious...are there any other pros out there to consider?
jscholen
The only Pro is that you would establish confidence in the investigator in your ability to audit yourself adequately and that your CAPA system is doing what is intended in bringing about change that is effective.
i don't know that I agree with the comments that you open yourself to observations by the investigator....yes, if you don't have an adequate system, No, if your CAPA systems work.
I bring up CAPA because we funnel observations from our Internal Audits into our CAPA system. Not everyone maybe doing this because there is fear that FDA has access to your CAPA system...this is a half truth. If your CAPA items include corrective action from your Internal Audit system, you can exclude those files from view....just don't highlight the finding in the CAPA log.
As long as you have a corrective action system that works, AND I stress Works, you should be fine.
But as a general rule, investigators are all different, so one may be fine with what you are doing, and another may not. I would suggest you side with caution and not VOLUNTEER anything.
AnaMariaVR2
Good point & I agree:agree1:
During systems-based inspections, one statement stands out: "the auditor should compare his or her observations to the approved procedures." So I guess the downside of showing internal findings is that it's not information the inspector needs as part of his/her inspection process.
Surrendering such data would undermine the intent of conducting internal audits? Does anybody has any thoughts on this?
Doug Tropf
The QSR Manual indicates that the FDA's policy of normally not requesting internal audit records was established because the agency does not wish to prejudice audits by having auditors concerned that their comments will be reviewed by FDA investigators.
AnaMariaVR2
But if the inspector will push for those documents to be surrendered, wouldn't this type of inspection technique be counterproductive to quality improvement?
Good point, Doug.:agree1:
The only exception to this might occur in a "for cause" inspection, in which case a subpoena would be issued for those records...but then will turn from an inspection to a criminal investigation, & that is another story.
:thanks:
AnaMariaVR2
I think everyone knows it is "policy" not to ask for QA findings, and by the way there is a lot more to GLP QAU than just 58.35 (b) (4), the status reports are just one of many types of inspections done in GLP QAU, and they are all protected from the regulatory request process under normal biomonitoring inspectionper 21 CFR 58.15:
"The records inspection and copying requirements shall not apply to
quality assurance unit records of findings and problems, or to actions
recommended and taken."
Regardless of reason, the FDA inspector can ask, and be refused, and it does not constitute a "refusal" of inspection.
The same is not true of records collected under 820.22. The FDA inspector probably will not ask for those records, because of the guideline.
But policy is not regulation, and if the inspector asks, you must provide records collected under 21 CFR 820, and to refuse constitutes a refusal of inspection. :bonk: Ouch!
The policy gives direction to the inspectors not to ask under most circumstances. The agency realizes that the findings of QAU will happen, and hopefully human errors are corrected properly/on-time & follow-up happens adequately, and so the QAU records should not in most cases be relevant to regulatory inspection.
But the agency has not chosen to extend the same "right of refusal" to other types of QAU that is written into GLP.
Push back is one thing, but outright refusal could net you a 483 for the refusal, even if they do not find anything else, and more.
E Should FDA implement 3rd party (PMAs) reviews? What are the pros and cons of doing so Other US Medical Device Regulations 2
M Standards Subscription Service and Standards Tracking Service Pros and Cons? Other US Medical Device Regulations 3
Claes Gefvenberg Windows 8.1 - Pros & cons, hints & tips. After Work and Weekend Discussion Topics 5
Sam Lazzara Medical Device Barcode Pros and Cons: GS1 versus HIBC Other Medical Device Related Standards 13
K What are the Pros and Cons of Auditing? General Auditing Discussions 1
JoCam ESD Flooring vs. Concrete - Pros and Cons Manufacturing and Related Processes 2
V Corporate Quality Management System - Structure, Pros and Cons? Quality Manager and Management Related Issues 3
R Recognition Programs for Good Suppliers - Pros and Cons Supplier Quality Assurance and other Supplier Issues 6
GStough Internal Audit Checklist as a Controlled Document - Pros and Cons Internal Auditing 19
W Pros and Cons of continued ISO 17025 accreditation ISO 17025 related Discussions 6
Q Pros and Cons of Duplicating Documents & Records Document Control Systems, Procedures, Forms and Templates 10
Jeff Putman Multi-Division QMS Certification - Pros & Cons IATF 16949 - Automotive Quality Systems Standard 16
somashekar Definition SMOI (Supplier Managed Owned Inventory) delivery terms - Pros and Cons Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
V Pros and Cons of integrating ISO 14001 and ISO 9001? ISO 14001:2015 Specific Discussions 4
Marc Glossy Screen Pros and Cons After Work and Weekend Discussion Topics 5
T Pros and Cons of Combined TS 16949 and ISO 14001 Audits General Auditing Discussions 3
H What are the pros and cons of working with gage pins? General Measurement Device and Calibration Topics 10
A ISO 9001 Registration Pros and Cons ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
J Pros and cons for combining ISO 14001 Certification ISO 14001:2015 Specific Discussions 4
P Portable CMM, new purchase: PROs and Cons General Measurement Device and Calibration Topics 4
D Ford Q-1 Pros and Cons Misc. Quality Assurance and Business Systems Related Topics 0
R Rework by Inspectors - Pros and cons of a quality inspector also doing rework? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
G ISO 9001 Procedures: Flowchart vs. Text - Pros and Cons ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Understanding of, and Pros and Cons of, 17025 ISO 17025 related Discussions 3
R Registrar Audit Frequency - Pros and Cons of a 1 year vs a 6 month frequency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Informational US FDA – Patient-Reported Outcomes (PROs) in Medical Device Decision Making Medical Device and FDA Regulations and Standards News 0
Marc SAS vs. R vs. Python: Which Tool Do Analytics Pros Prefer? Statistical Analysis Tools, Techniques and SPC 6
BradM Calling all Regression Analysis Pros! Statistical Analysis Tools, Techniques and SPC 1
J Quality Pros? Salaries on the Upswing, ASQ Salary Survey Says Career and Occupation Discussions 4
A Cons and Flaws in AAMI 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
R Importers - For the FDA Registration/ Listing, is the CMO the importer? Medical Device and FDA Regulations and Standards News 6
Z Iterative development and FDA change requests IEC 62304 - Medical Device Software Life Cycle Processes 2
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
O Clarifying FDA definition of "finished device" and “capable of functioning” 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 6
JoCam FDA Registration for Sub-contract manufacturers Medical Device and FDA Regulations and Standards News 2
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
P Choice of FDA reviewer US Food and Drug Administration (FDA) 6
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
T Definition Human Use (FDA) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
J FDA notification of address change US Food and Drug Administration (FDA) 2
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 3
