Protective vs. Functional Earth Differences
U
username10
Please see the grounding scheme below.
In order for the device to be a class 1 device, it needs to have the chassis as protective earth. This is accomplished by running a conductor from the AC MAINS input to a ground stud on the chassis.
However, if I also have my analog ground also connected to the chassis, doesn't this make my protective earth functional ground?
How should this be wired to meet class 1? Should all the ground be tied to the chassis or only the earth from AC?
Thanks!
bassa
No it doesn't. A PE is PE because it's used to Protect the operator/patient, by means of a reliable ground connection, to make sure the touch current won't exceed certain values.
Connecting a FE to it doesn't change this.
8.6.8 states that it is not allowed to use a functional ground for Protective Earth.
The other way around (like you described) is allowed.
Peter Selvey
It is a bit confusing. The term "functional earth" as used in the standard is only for cases where a special terminal is provided for the user or installer to connect to an external earth, usually for the purpose of noise reduction.
It is rare to see such a terminal, so in most cases, there are no "functional earth" connections, at least as defined in the standard. Of course in day to day conversation, we often refer to something as being "functionally" earthed just to make it clear it is not protectively earthed.
The standard actually uses two terms "earthed" and "protectively earthed".
The term "earthed", when used in the standard, includes all parts which are earthed, regardless of the reason.
The term "protective earth" covers only those parts which need to be earthed
for protection against electric shock.
Throughout the standard, you will see some requirements which refer to "earthed" parts and others to "protectively earthed" parts. But if you see a requirement for "functionally earthed" parts, ignore it unless you really have a functional earth terminal, for external connection.
sankui
In this case, did you mean that the reliability of connection of earth need not to be investigated? And therefore such earth connection does not provide ONE MOP?
Peter Selvey
Exactly. If you look at the definition of a MOP, you will find it is limited to protection against electric shock.
The earthing may be there for other safety reasons (e.g. sensor noise reduction, EMC immunity, which are also safety issues), but in the context of IEC 60601-1 the term "protective earth" is used for MOP only which in turn means it is just for electrical safety.
Any part which is earthed to prevent electric shock is an MOP and must meet the relevant requirements to confirm the protection is reliable, like being <0.1ohm @ 25A.
Other parts which are earthed for other reasons are not MOP and don't need to meet these tests. But there may be some requirements which refer to earthed parts in general (e.g. the green/yellow marking for conductors is allowed for these other parts).
W Protective earth for Class I ME equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Secondary circuits and protective earth IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
G IEC 61010 - Single Fault Condition - Protective Impedance Implementation IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Can the shield of a cable be used as a protective bonding conductor? Design and Development of Products and Processes 2
N Accelerated Aging Test for Disposable Protective Garment for Incontinence Other US Medical Device Regulations 1
R Is protective earth connection regarded as a part of the applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Medical Device Protective Earth (PE) issues IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
N Protective Earthing of Medical Device Moving Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Minimum Testing Requirements for a Clear Protective Equipment Barrier (Class II 510K) Other US Medical Device Regulations 1
R How much Protective Current Rating of Building Branch Circuit should be considered? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R How to Design a Protective System for Infusion Pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 48
R What is the meaning of "Highest RATED Current" in Protective Earth Impedance Test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S How to overload a linear transformer with multiple protective devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
S Protective Earth Test in IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
J Protective Earthing for Medical Device with two wire power cord in metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
A Essential Requirements Checklist for PPE (Personal Protective Equipment) CE Marking (Conformité Européene) / CB Scheme 6
G ASTM b137 - Is protective value equal to protective capability? Various Other Specifications, Standards, and related Requirements 3
Z Packaging and shipping of multiple PWBA/PCBAs in one ESD protective bag Supplier Quality Assurance and other Supplier Issues 5
B Allergic reactions complaints for a protective apparel (impervious gown) Customer Complaints 4
A Maintaining traceability through our manufacturing process - Protective suits - 110 Misc. Quality Assurance and Business Systems Related Topics 1
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
R Quality System Functional Safety Checklist / Guidance IATF 16949 - Automotive Quality Systems Standard 0
S Potential Equalization Conductor vs Functional Earth Terminal IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 4
K IEC 62304 - Functional and performance requirements for SOUP items IEC 62304 - Medical Device Software Life Cycle Processes 2
L IEC60601-1-11 Home Healthcare + IEC60601-1-2 EMC (Functional Earth allowed?) IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
W Key functional characteristic definition - Tolerances and Deviations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
I Functional Safety Analysis/Report Example IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
E How do you know your test equipment is good? Functional testing and Golden Boards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Informational EU – Draft Functional specifications for the European Database on Medical Devices (Eudamed) – First release (High(1)) to be audited Medical Device and FDA Regulations and Standards News 0
N Configuration Management - Physical Audit and Functional Audit for Software and Hardware General Auditing Discussions 4
D FAI. Form 2, process or functional test? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
O Guide on EMC for Functional Safety CE Marking (Conformité Européene) / CB Scheme 3
C IEC 61326 Functional Performance CE Marking (Conformité Européene) / CB Scheme 1
R Development of Design FMEA - Functional Requirements FMEA and Control Plans 1
F Functional connection between ME and non-medical equipment in different rooms IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Functional group / area responsible on a Control Plan IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
Q Looking for Cross Functional Matrix of Medical Device Regulations around the World Other Medical Device Regulations World-Wide 5
H Functional Safety PFH vs PFD according to IEC 61508 Reliability Analysis - Predictions, Testing and Standards 3
P House of Quality Functional Requirement question Six Sigma 4
I Non-functional Corrective Action - Could Not Find some Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Conducting an MSA study for ICT(HP3070) and Functional Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Functional Specifications - Tracability to requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q ME System - Is a Wireless Connection a "Functional Connection"? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Q Removing Inspection (Functional Tests) from a Process Step Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Functional Test Fixtures - Calibration Required? Quality Manager and Management Related Issues 8
J Identifying version of Standards in Functional Specification of a New Device ISO 13485:2016 - Medical Device Quality Management Systems 6
P Understanding ISO 26262 Road Vehicle Functional Safety Other ISO and International Standards and European Regulations 2
