Prove or disprove that a cube can be cut in 27 smaller cubes in less than 6 cuts
Mauri
I agree with Pancho, unless.....
Is the cube made of solid material or is it bendable? Is bending the pieces allowed?
smryan
Perspective.
I can get 27 cubes in 6 cuts... slice each face in 3rds.
I can also get 64 cubes in 6 cuts - that requires rearranging the cubes as they get cut.
But in less then 6 cuts the pieces are not cubes. They are shoe-box shaped.
MIREGMGR
Here's a technique that is sort of cheating:
Start with a cube, sized as 3x3x3 of the final-cube size. Make two parallel cuts. Now you have three pieces, each 3x3x1 of the final-cube size.
Line those three pieces up and make two more cuts. Now you have nine pieces, each 3x1x1 of the final-cube size.
Now line up those nine pieces in a flat row. This is easiest to envision as occurring on the table of a bandsaw. The nine pieces will be cut sequentially, not three at a time. As each piece is cut, what results is one 2x1x1 piece, and one 1x1x1 piece. As it's generated, immediately move each 2x1x1 piece to the end of the feed row, aligned so that its midpoint will be passed through by the blade.
After the nine 3x1x1 pieces are done being cut, the blade begins to cut through the nine 2x1x1 pieces...all in one feed process, sort of.
When you're done, you've made five cuts, and you have 27 1x1x1 cubes.
Mauri
That sounds like what I had in mind.
I was thinking if the material is flexible, take your 9 3x1x1 pieces and fold them so you have 9 1.5x2x1 and then make one cut through two layers 1" from the open side.
True Position
That's not sort of cheating, that's very much cheating. If you extend the problem to including 'painting each face a different color based on each cut' there's a problem. Using your method you'd have multiple faces with the same color. This is the equivalent of cuts turning at 90 degrees.
G
George Weiss
I must be confused?
I see a square being cut into 3 slabs with 2 cuts
I see 3 slabs being cut into 9 smaller retangles with 2 cuts
I see 9 rectangles being cut into 27 smaller squares with 2 cuts
I see 27 smaller cubes
MIREGMGR
What's a cut?
Is it when a tool enters a volume of material, and proceeds through the mass--ignoring intermediate seams at right angles to the cut line, where one piece of material is butted up against another piece--until it comes out the other side/end of the volume?
Or is it a certain length or area of cutting? Or does it have to be a certain shape of cut?
Q Do we have to prove a link between the mill and our raw material supplier? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
P How to Scientifically Prove the Importance of a Process - CMMI Process Areas Software Quality Assurance 7
B How to prove that an organization implements anti bribery policy IATF 16949 - Automotive Quality Systems Standard 8
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S How to Statistically Prove 2 Dimensions are Related Using Minitab Software 18
U Sample size to prove parts are good with 99.73% confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L What needs to be done to prove compliance with RoHS and WEEE EU Medical Device Regulations 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P How to prove that Cr oxide makes a stent biocompatible (e-polished 316LVM) Manufacturing and Related Processes 9
P Testing a US device in Europe to prove Equivalence in a ?head-to-head? Study EU Medical Device Regulations 6
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
K What would you give up to prove conformity and honesty? Internal Auditing 21
S ISO 17025 requirements not enough to prove NIST Traceability? ISO 17025 related Discussions 10
M How do I prove I don't receive a controlled product? Ractopamine Hydrochloride Misc. Quality Assurance and Business Systems Related Topics 4
C Clinical Data to Prove Equivalence Other US Medical Device Regulations 4
U Can anyone prove that: 2x2=5 ? Coffee Break and Water Cooler Discussions 63
D Testing an Inspector to Prove Competency in Visual Inspection Records and Data - Quality, Legal and Other Evidence 2
S Lean System Developer - How should I work to prove myself? Lean in Manufacturing and Service Industries 19
D How to Prove and Explain to Consultant (Internal Auditor) and Manager? Internal Auditing 7
M Planning requirement 5.4: How should the management prove compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J How to prove that we conform to legal requirements Miscellaneous Environmental Standards and EMS Related Discussions 11
L Is there any way to prove a process is in control other than with a control chart? Statistical Analysis Tools, Techniques and SPC 6
H How do we prove that we are improving the continual improvement process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
L How do you prove you need resources? Misc. Quality Assurance and Business Systems Related Topics 5
J Finished Goods Testing - Using historical test data to prove finished goods OK Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Contract Review - How do you prove it? Contract Review Process 16
K Statistical Hypothesis Testing to prove signficant quality improvement or decline Statistical Analysis Tools, Techniques and SPC 6
