Purchasing Verification & Supplier Selection
ali335
hello everyone,
i am now preparing our company (Purchasing procedure)
our company is maintenance contractor for petrochemical plants
here are my questions :
1- Verification of purchased product (7.4.3)
is it enough to stamp "inspected" on the invoice with the signature of the person in charge for Verification as a verification tool instead of having receiving form
2- Supplier selection
as I roaming through this forum, I found a lot talking about "Supplier Survey" , the idea is good, but for me it is difficult to do in my business.
also, is it required by the standard?
because our way to select the supplier is :
• Sample Approval
• Product Demo - In-house Testing (QC Report)
• Customer’s Specifications
• Trial Order
• Price Comparison
• Catalog Verification
• Catalog Technical Evaluation /Supplier Site Visit
• Product Demonstration
• manpower Verification - qualification
it is very difficult to collect information about the suppliers themselves
and also are the information provided by them is true or not
specially their finical issues, competency and quality ??
thank you
somashekar
Yes, it meets the requirement of ISO9001:2008 which at 7.4.3 says :
The organization shall establish and implement the inspection or other activities necessary for ensuring that purchased product meets specified purchase requirements.
provided the person who signs is competent about the inspection methods or other activities necessary, and how he ensures that his inspection or activity is against the specified purchase requirement. Hopefully it is consistent across your organization.
About the supplier selection, your detailed method is good enough if it has been working well for you. Supplier survey is not a stated requirement in the ISO9001:2008.
ali335
thank you for the fast reply
your answer is very helpful for me
thank you
Ajit Basrur
hello everyone,
• Sample Approval
• Trial Order
• Price Comparison
thank you
Answer 1
Yes, as already mentioned by somashekhar earlier, its enough but do not forget to mention it in your procedure.
Answer 2
Supplier selection is the most important tool in evaluating if they can meet your expectations. If you arent sure of supplier's competency and capabilities, how can you ensured of good quality supplies consistently ?
The different steps that you have mentioned from "Sample Approval" are undertaken only after select a supplier.
harry
Generally, when you are involved with critical parts, highly technical, complex or big value service or products (usually dictated by time and capability) you may want to go through the process of Wikipedia reference-linkPre-qualification. Pre-qualification is like a filter process where you select only those that meet your preliminary requirements for further assessment and consideration.
This method is widely used in the project environment and I believe the oils & gas industry too.
Jeorg
hello everyone,
• Sample Approval
• Trial Order
• Price Comparison
thank you
Item 2 first: Your method of supplier selection is perfect if you have documentation to back it up. The survey is, well, basically useless. Its just a feel good activity that keeps critics away. But it only consumes time and money.
Item 1: You need to define somewhere in your documentation what will inspected and how. (see purchasing in standard) If you are just buying bulk materials and do not test you have to verify that you got what you ordered by comparing labels to shipper and PO. If you ask for certification it needs to match and be retained also. You always need who and when on the verfication. So it can be on the Invoice but are you sure you don't mean the shipper. Either way you need to maintain a copy to substantiate that inspection was done. I would caution you not to use the word "Inspected" but rather "Accepted" or "Rejected". "Inspection" does not identify inspection *STATUS* which is required on the product container also.
ali335
Answer 1
Answer 2
Dear Ajit ,
for Answer 2 :
sometimes we found this is the only supplier who can provide the requested product/service on that time and we don't have other choices
the issue here i am tring to use our existing and try to do minimum modification to comply with ISO requirements
ali335
dear Harry,
thank you for your reply,
our clients used this method when they ask us to participate on their projects
ali335
for item #2
yes, this what i am worry about , to be (useless) and waste a lot of time & effort
also, our company is new just completed the 3rd year,
i don't want to send Survey and few only will answer it !!
specially on our market, still the suppliers not rely engaged with the standards
for item #1
thank you for the advice of using the word "Accepted" instead of "inspected"
when i completed this part of vitrifaction, i will posted here for review
thank you all
JaneB
ali335,
It is nowhere a requirement that you do a supplier survey. Entirely up to you if you do or not. (I've only ever done one, and then only because the client wanted to do it that way. Not a useful exercise at all!)
What IS required is that you:
- have criteria for how you select & monitor suppliers
- periodically evaluate them against your criteria, and
- of course take suitable action if they don't perform well, eg, fail to supply according to specs.
All this really is common sense: you need reasonable suppliers, so you get 'good stuff' from them that meets your requirements. How someone does that varies enormously.
If there's only one supplier... then there's only one supplier! Because no.1 in the criteria, of course, is 'ability to supply what you want'. But you still need to make sure you got what you wanted, and monitor supplier performance. Sounds like you're already doing this well.
A Purchasing Controls on Change Management of Literature/Labeling ISO 13485:2016 - Medical Device Quality Management Systems 3
A How to prepare QMS manual for purchasing department Quality Management System (QMS) Manuals 5
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Purchasing procedure and workload ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Non-Conformance from recent Audit carried out on Purchasing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
D Do purchasing controls apply to non-medical parts? ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Purchasing requirements for Toll Manufacturers Manufacturing and Related Processes 1
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
J COC (Certificate of Conformity) when NOT purchasing medical devices direct from the Manufacturer Other Medical Device Related Standards 2
R ISO 13485 purchasing QMS and ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 8
A Purchasing - Internal Audit Questions Internal Auditing 8
M Case study - If the restaurant (ISO 9001:2015 certified) was run by 2 persons covering cooking and purchasing processes (Mother and Father) supported ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Use of non-ISO 9001 Supplier - Purchasing through a distributor IATF 16949 - Automotive Quality Systems Standard 7
M AS9100d Controlling External Provided Processes (purchasing 8.4) - The customer want us to use supplier X AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Purchasing for Design and Development Organization ISO 13485:2016 - Medical Device Quality Management Systems 3
Q AS 9100 C and D Purchasing requirements difference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Risks and opportunities that could be associated with the purchasing department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R DFARS Compliance - Purchasing Aluminum Alloy 7075 -T73511 per AMS-QQ-A-200/11 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
N ISO 17025 Clause 4.6 Purchasing Services & Supplies (Compliance) ISO 17025 related Discussions 3
V Purchasing Controls - Prerequisites for Batch Release or even before Purchase Order 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L ANVISA RDC 16 - purchasing records Other Medical Device Regulations World-Wide 2
K "Purchasing Controls" for Stand-alone Software US Food and Drug Administration (FDA) 2
H Cause analysis for an Audit Finding - Purchasing Procedure Content ISO 13485:2016 - Medical Device Quality Management Systems 9
D Can we exclude purchasing and supplier evaluation - ISO9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Difference between 7.4.1 & 7.4.3 - Purchasing Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
S AS9100 7.4 "Purchasing of a Service" - Stress and Design Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Supplier Audit Form for Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 2
A Question on Purchasing clause 7.4.1 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A 7.4 Purchasing Question - My company only provides services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W ISO 9001 Clause 7.4.2 Purchasing Information for Retail Products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L AS9100 - 7.4.2d Purchasing - Specification revision for raw material needed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Purchasing Process Out of Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Methods to Ensure that we are Purchasing what we've Designed Benchmarking 16
T Purchasing SPC Software for Automotive Company Statistical Analysis Tools, Techniques and SPC 9
P Supplier Scorecard for ISO 9001 - Help me review the draft from my purchasing team ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V Satisfying AS9100 7.4.2 Purchasing Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Q Exclusion to Purchasing - AS9100 Clauses 7.4.1 & 7.4.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Do I have to audit 7.4 Purchasing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D AS9100 Tooling Purchasing Process Manufacturing and Related Processes 5
T Purchasing a Digital Multimeter Calibration and Metrology Software and Hardware 3
B Bill of Material Content to meet Purchasing Requirements Manufacturing and Related Processes 2
W ISO 9001:2008 Purchasing Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T ISO 9001 Clause 7.4.1 Purchasing Process (Supplier Approval) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Distributor and 21 CFR Part 820.50 Purchasing Controls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Purchasing Performance KPI (Key Performance Indicators) Benchmarking 4
K Purchasing a Portable CMM to Measure a 14' Cylinder that's 5' Tall Calibration and Metrology Software and Hardware 3
