Purpose of using different Distributions to solve Reliability Problems?
convivial
I do not understand why sometimes we choose weibull and sometimes binomial and sometimes other distributions to solve reliability related problems?
WHat is the reason of first choosing a distribution and then solving for the reliability?
Steve Prevette
Deming Disciple
Re: Purpose of using different Distributions?
There are two primary reasons for fitting a distribution:
1. I have a theory related to my engineering and operational knowledge of the system being measured. For example, do I expect the failures to be "memory-less" (exponential) or do I expect there to be a "burn-in" period and/or a "burn-out" period (the "bathtub curve", generally fit with weibull).
2. Analysis of the empirical data shows me that one curve fits better than the other.
What distribution that is fit is especially important with high-reliability, low failure rate systems. I am many times trying to estimate the reliability of the system out many standard deviations, yet only have a limited set of data, which may be truncated data (not running the system sufficiently long enough to get an actual failure).
Z Using Different Forms For One (same) purpose Document Control Systems, Procedures, Forms and Templates 2
A What is the purpose of using AQL (Acceptable Quality Level) for Sampling? AQL - Acceptable Quality Level 3
Q Using Class 3 used Electronic Devices for Training purpose ISO 13485:2016 - Medical Device Quality Management Systems 1
T Using Cpk for the purpose of determining sample size/frequencies Capability, Accuracy and Stability - Processes, Machines, etc. 2
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
dgrainger Informational DRAFT - Common specifications for the groups of products without an intended medical purpose listed in Annex XVI. EU Medical Device Regulations 0
Dan Pare Density Column setup for Measuring General Purpose ABS General Measurement Device and Calibration Topics 0
T Intended purpose for devices that might not fit the IP criteria EU Medical Device Regulations 0
B Nasal Saline Solution for Irrigation purpose classification EU Medical Device Regulations 0
A Intended Purpose on device label EU Medical Device Regulations 7
M ISO 13485 for general purpose disinfectants? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A A purpose of a Stage 1 audit - Off site document review Registrars and Notified Bodies 3
A Audit purpose - case study - What is the role of SQE in such case? General Auditing Discussions 3
A True purpose of doing EST (Electrical Safety Test) on medical device Other Medical Device Related Standards 3
T Informational What is the purpose of Internal Audits? Internal Auditing 27
K QMS Improvement - Analyze the systemic weaknesses of the QMS for improvement purpose Quality Tools, Improvement and Analysis 6
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
SK13485 Can a literature alone be used for the purpose of Clinical Evaluation of a device? EU Medical Device Regulations 6
E IATF 16949 Cl. 7.1.5.1 - Documented information as evidence of fitness for purpose IATF 16949 - Automotive Quality Systems Standard 3
R Auditing Fitness of Purpose for Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Are dermal fillers & PDO sutures for aesthetic purpose under CE MDD? EU Medical Device Regulations 6
somashekar Electronic data Back-up procedure, for Medical device QMS and regulatory purpose. ISO 13485:2016 - Medical Device Quality Management Systems 4
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
Q IEC 60601 for Non-Medical Research Purpose Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D UV Absorption Test - What is it's purpose and what specifically is it looking for? Other Medical Device Related Standards 10
A ISO/IEC 20000 Toolkit For Academic Purpose IT (Information Technology) Service Management 6
L What is, and the purpose of, ISO STATS recording ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
x-files Hardcopy and Electronic Forms for same purpose vs. Naming and Numbering System Document Control Systems, Procedures, Forms and Templates 1
N How to qualify (IQ, OQ, PQ) a multi-purpose equipment ? Imported Legacy Blogs 1
V The Purpose of Basic Dimensions on Prints APQP and PPAP 6
Q Beginner's Understanding - The Purpose and Applications of QMS/ISO Standards Philosophy, Gurus, Innovation and Evolution 12
J How to qualify (IQ, OQ, PQ) a multi-purpose equipment ? Qualification and Validation (including 21 CFR Part 11) 5
S Logo Marking for Marketing purpose - ISO 9001, ISO 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P What is the latest version of ISO 10021 used for Certification purpose? Other ISO and International Standards and European Regulations 3
N Export & Import of Unapproved Device in USA for Service Purpose Only 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Purpose of the Quality Manual for an Organisation Quality Management System (QMS) Manuals 4
M TS 16949 Clause 7.5.1.8 - Special-Purpose Tools or Measurement Equipment IATF 16949 - Automotive Quality Systems Standard 2
A FDA: Label Requirements for General Purpose Reagents IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S What is the purpose of ON HOLD Labels Food Safety - ISO 22000, HACCP (21 CFR 120) 5
Q How to write Statement of Purpose for a Law School Admission Career and Occupation Discussions 9
C FDA Approval Process for Device that can also be used for Veterinary Purpose 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Can some one share JIS B7502/7507 or DIN862 with me for study purpose? General Measurement Device and Calibration Topics 2
C What is the Purpose of or Requirement for having a Gage Glossary? IATF 16949 - Automotive Quality Systems Standard 2
P What is the purpose and use of Chart Stickers Labels? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Auditor suggested company find a higher purpose for Internal Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Z CMM Measuring Instruction - Example needed for translation purpose Document Control Systems, Procedures, Forms and Templates 17
L Please share some practical SPC exercises for training purpose Statistical Analysis Tools, Techniques and SPC 4
