PV (Production Validation) test plan responsibility
Mr Skeleton
#11
I think there are two test plans required by APQP. The first (DV) validates the design is good (element 23 from the ford Doc) and answers the question "if the parts are made according the design, will it perform in service to the required level" and is done on prototype "nominal" parts. The next testing (PV) confirms the process is delivering the design (element 50 from the ford doc) and answers the question "does the expected process performance deliver the required product performance" and could only be designed with reference to the process and the understood risks.
I'm referencing the Ford doc because I'm currently locked out of AIAG and can't ref their manual.
Marc
#12
The definition of PV from my business process is "Product Validation testing" but the element of APQP taken from Ford's APQP guideline is "Production Validation Testing". This is relevant because my business's processes are derived from Fords
Yea - Variations an a theme. Note that the Ford document is from 2001 - Things haven't changed. Add in that all sorts of companies now embrace what they call APQP. The Ford document is a good one with respect to detail of their customer specific requirements, but all in all it's pretty standard stuff going back over 20 years, actually.
As you noticed, the first thing that came up in this discussion was what you meant by "PV".
Mr Skeleton
#14
So I don't understand the difference, unless the 2nd lot of testing from "off process" parts represents all potential process risk conditions? And how can you know that without reference to the PFMEA? I would like the DV to validate the design and then (in an Ideal world) no further testing unless the process risk (defined in PFMEA) requires it.
Marc
#15
Well, it's pretty much all here: https://elsmar.com/APQP/ - Technically I did that around 1997 or so. The "printout" here is from later, but again - This is all really old stuff. The catch is that often different companies use a slightly different name for something than another company uses.
I first got involved in automotive back around 1988, first with Ford and then GM, and all of this was the same then as now. Terminology has always been an issue. Ford calls something <term 1> and GM calls the exact same thing <term 2>.
First, stop using terms like "DV". Say what you are referring to. There are too many meanings for "DV". Spell out the acronyms. If you mean Design Validation, type in Design Validation.
"Off the process" testing is Process Validation. Yes - It uses the Process FMEA to design the test. It also uses the Design FMEA in that the Design FMEA feeds into the Process FMEA.
And Yes -
That is exactly what your Process Validation test design is intended to do.
Mr Skeleton
#16
Easy fella, I get your point, but don't appreciate the tone, especially when I did clarify my abbreviations as requested
Good point about abbreviations (y)
STA / SQA = Supplier Technical Assistance / Supplier Quality Engineer
OEM = Original End manufacturer
PV = Production Validation
DV = Design Verification
PFMEA = Process Failure Mode & Effects Analysis
Mr Skeleton
#17
We got there though:
And Yes -
My experience in my business is that with Product Development department engineers responsible for this APQP deliverable, there is no reference to PFMEA by them and they fail to design a robust and value for money Production validation test plan. making the testing ineffective and wasteful.
Bringing me back to my first point:
"PV test plans are ineffective and inefficient. They are created with little or no respect for the PFMEA and therefor the risk inherent in the process so are ineffective and wasteful".
Mr Skeleton
#18
So the question is, if anybody here has good experience creating PV (Production Validation) test plans. Clarification of best practice methods etc.
And if the STA / SPQ team are (normally) responsible for developing and approving the suppliers manufacturing quality system, primarily the PFMEA & Control Plan, should they not also be responsible for the PV test plan?
All views and comments welcome
Johnnymo62
Haste Makes Waste
#20
My experience with Production Validation plans has nothing to do with process variation. It was a part of design.
We made xx number of acceptable parts off of Production tooling/process and verified they passed design requirements at all the different operating conditions (hi/lo temperatures voltages, pressures etc.).
A Validation of processes for production for Test Equipment ISO 13485:2016 - Medical Device Quality Management Systems 9
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
L Why is initial production units, lots, or batches, or their equivalents required for Design Validation? US Food and Drug Administration (FDA) 3
P Production Line Pump Cleaning Validation Method Question Qualification and Validation (including 21 CFR Part 11) 0
J Design Control - Can Validation be based on a limited/first Production Run ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D 7.5.2 Validation of Processes for Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
A 7.5.2.1 Validation of Processes for Production and Service Provision IATF 16949 - Automotive Quality Systems Standard 7
D 7.5.2 Validation of Processes for Production and Service Provision - Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Y 7.5.2 Validation of Processes for Production and Service Provision Discussions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Determination of Production Equivalence for Design Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
V Utility (power production) Company - Mitigating risks in Verification and Validation. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q ISO 9001 clause that covers Production Line Re-Validation Quality Manager and Management Related Issues 10
H Excluding 7.5.2 - Validation of Processes for Production and Service Provision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B ISO 9001 Clause 7.5.2 - Validation of Process for Production and Service Provision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
S 7.5.2 Validation of Processes for Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 56
S Validation of Production Process - Practical Example ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Process Validation of Low Volume Production of Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 9
B Validation of Processes for Production and Service Provision - 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Interpreting clause 7.5.2.1 (validation of software used in production & service) ISO 13485:2016 - Medical Device Quality Management Systems 2
B Validation of processes for production & service provision - Service industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I AS9100B Cl 7.5.1.3 - How to comply with validation of production tools requirement? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D "Special Production Process" Validation and TS16949 Clause 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 5
B Can I exclude 7.5.1 & 7.5.2 (Control of Production & Validation) from our QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Process Validation - Production Line Transferring to a Different Facility Qualification and Validation (including 21 CFR Part 11) 16
S Which sample to use for PV (Production Validation) or DV (Design Verification) tests Manufacturing and Related Processes 4
V Validation of Processes for Production and Service Provision Procedure Document Control Systems, Procedures, Forms and Templates 8
T What is required for APQP step 4.5 Production Validation Testing APQP and PPAP 2
R Validation of Processes for Production and Service Provision - Clause 7.5.2 IATF 16949 - Automotive Quality Systems Standard 4
A How do you do "Validation of Process" of production? IATF 16949 - Automotive Quality Systems Standard 16
R Validation of Processes for Production - How are doing it? Clause 7.5.2 Reliability Analysis - Predictions, Testing and Standards 25
C Master Validation Frequency in production - Absence of leak, thread presence, etc. Reliability Analysis - Predictions, Testing and Standards 4
T Anybody could share an example of Ford PVP (production validation plan/program) APQP and PPAP 2
M Examples for Clause 7.5.2 - Validation of processes for production and service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Exclusion from Validation of Processes for Production and Service Provision? Service Industry Specific Topics 17
D Weld Stepper Validation in production weld-cells Preventive Action and Continuous Improvement 6
H TS 16949 - 7.5.2.1 - Why does TS ask for process validation for all the production? IATF 16949 - Automotive Quality Systems Standard 5
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
thisby_ Post Market/Production Risk Assessment ISO 14971 - Medical Device Risk Management 0
Felony Melony Project Milestone Plan-Development to Mass Production APQP and PPAP 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
R Monitor production quality - Internal KPIs Manufacturing and Related Processes 5
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Conformity assessment based on a quality management system or production quality assurance EU Medical Device Regulations 3
