Q as the Datum Maximum Material Condition then MINUS 0.020
CharlesLethbridge
I have a GD&T frame that looks normal but on the second last frame it has Q as the datum maximum material condition then MINUS 0.020.
I don't understand what the designer is trying to tell me.
Q is the centre of a keyway and the frame is for a hole on a different plane but angled at 60 degrees from the key center
Thanks running this site it is great
Charles
  • Doc3.docx
Stijloor
Charles
Welcome to The Cove Forums!! :applause:
What GD&T Standard is mentioned on the drawing?
"Minus" is an unusual modifier in a feature control frame.
It is possible that the engineer wanted to invoke LMC, but that's just a guess on my part.
The best advise I can provide is to contact the engineer and ask for clarification.
Others may chime in soon...
optomist1 Maximum Shift Tolerance Restrained Part - Calculation of Datum Shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
2 GDT of datums - Putting Datum C on a drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
O Clamps in checking fixtures used to drive datum features. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
O Orientation with respect to a Compound Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Establishing -F- datum - need advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O How to establish Datum Planes with two cylinders? Various Other Specifications, Standards, and related Requirements 0
O Datum A and B are both Cylinders (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Flatness Measurement Errors from a Datum - Test Method General Measurement Device and Calibration Topics 3
K Assumed Alignment and Assumed Datum on a Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Geometric Tolerance Bonus Datum question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Positional Tolerance - Bonus / Datum Shift / ASME Y14.5M - Clarification Various Other Specifications, Standards, and related Requirements 9
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F Angularity of 2 Surfaces to a Datum which is a Radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Complex Surface Profile as a datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Does anyone have an AS9100 System Training Datum? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
optomist1 Feature Control Frame is applied to the end of a Cylinder - Datum Dilemma Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Datum B and C are each both vertical and horizontal - Tolerance of Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
optomist1 Parallel Cylinders (Dowels or Pins) As Datum Features Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Parallelism call out of .005" to Datum A - A GD&T question Capability, Accuracy and Stability - Processes, Machines, etc. 12
optomist1 Coplanar Widths As Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
optomist1 Tolerance of Position - Pattern of Holes at MMC - Datum Feature Reference Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
CycleMike Profile of datum planes - Profile callout back to datum A (itself) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Definition GD&T Clarification - Callout for Profile of a Surface Reference to the Datum Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 34
G What is meant when a datum (feature) is called a "6 way"? GD&T help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
B How to do a profile on a surface with one datum General Measurement Device and Calibration Topics 23
M IEC 60601-1-8 clause 6.4.1 (statistics of the distribution of the sum of the maximum ALARM CONDITION + SIGNAL GENERATION DELAY) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K IEC Maximum Power Density for Muscle Stimulator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Maximum Mains Voltage (clause 8.5.3) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
Judy Abbott Increase the maximum allowable dose for E-beam sterilization Reliability Analysis - Predictions, Testing and Standards 2
M Maximum Height for the stored material or stock materials Occupational Health & Safety Management Standards 1
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 3
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Marc Definition MPEE - Maximum Permissible Error for Length Measurement Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Maximum bubble volume for subcutaneous injection IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
V Correlating Maximum 'Range' of Values for a given "RSD" (Control Limits) Statistical Analysis Tools, Techniques and SPC 3
