Q1 Clause 5.7.1.5 - Validation of process
Aussie99
with regards to Q1 clause 5.7.1.5 - "The organisation shall validate processes for production and servicing where the resulting output cannot be verified by subsequent monitoring or measurement, and as a consequence, deficiencies become apparent only after the product is in use or the servicing has been delivered."..............
The company I work for has been hardbanding drill pipe and collars for over 20 years now. Initially for the mining industry, and over the last six years, for the Oil and Gas industry as well.
We have never carried out any form of testing other than the "test of time and usage" to validate our process. We know it works, and our customers know it works, but is that enough? Are we able to comply with clause 5.7.1.5 using some form of "grandfathering" for our process, which was developed many years ago. Tried, tested and evolved into what it is today?:confused:
Thanks in advance
sagai
Re: Validation of process
So what is the "resulting output cannot be verified by subsequent monitoring or measurement" in your case?
Cheers!
somashekar
Thanks in advance
HARDBANDING is a process.
You know your process best, but please read the details ABOUT HARDBANDING to decide what tests you can do to confirm that your 20 year old process is assured to be good.
Then maintain your process to stand by it and with assurance say that your process of hardbanding is validated to meet the customer requirement.
Add some data to your 'grandfathering' for assurance in your quality management system. That will be a day to learn and wish you good luck ~~~
Aussie99
Thanks Somashekar.............that's exactly what I was trying to avoid! But in my heart I think I knew some destructive testing would be the only way to truly satisfy an API auditor that our process has been validated.
We know the wear rates are good, (for several different wire types we use), and we know we have good adhesion and pretty much nil porosity, (from viewing our product after many years in the field when it has worn back to the parent metal). In hindsight we could have documented this by tracking the pipe numbers and taking photos when they returned to the facility.
I think our simplest method of validation might be to complete a test piece, and skin the hardbanding back on the lathe, 1mm at a time to examine the hardbanding at different levels all the way through. We could take photos at each "skinning".
Regards
somashekar
Regards
You are free to define your sound and scientific criteria for review and approve of the process. If you have international standards or industry benchmark / guideline these can also be your source for criteria.
For several different wire type, is your process slightly different for each wire type or the same ?
Remember that your are validating the process for a defined set of inputs.
This is where revalidation requirements comes into play.
If the process is the same, then have your records with each type of wire. This will show that with only the wire change, the process still is good without a change.
If each wire type have a slight difference in the process, then obviously you have each as a seperate validation record.
The defined criteria for all can still be the same.
SO.
Same process, change in one material, criteria is met, process is validated good.
Different process, unique for each type of wire, criteria is met, process is validated good.
When any input changes, be sensitive to re-validate and confirm process is good.
Aussie99
Process doesn't change Somashekar................just various inputs which we have on set up sheets relative to pipe diameters, wire types and hardband widths etc.
:thanx:
Aussie99
Sorry Sagai for not replying earlier.......
Processes which could not be verified in this case would be hardbanding wear rates, weld adhesion, weld porosity etc.
somashekar
:thanx:
Hi my friend ...
Process doesn't change ??
For example, when the pipe dia changes, do you not change the RPM suitably ?
When wire type changes, do you not change the weld current suitably ?
When hardband width changes, do you not change the RPM and / or current / feedrate / wire diameter suitable ?
From your point of view, I agree that the process of hardbanding does not change.
But when I look at validation, each change in input leads to a process change, that you will aim to get the optimum result. Finding this is the purpose of validation.
Aussie99
I see what you are saying Somashekar..............if I take that road it means many different validations.
somashekar
OK...
So be it.
How many ?
We are not re-inventing the wheel all over again every time.
Use your learnings from the first validation into next.
Think optimizing process, if you do not require such fineness of process variations when any change takes place. Use your Risk assessment, technology and experience.
Then perhaps 15 different validations may be just 5.
Let us know again that you are doing these to establish the process and then the process begins to repeat in the best possible way for your outputs.
it is not a hard task when we approach validation with purpose.
B ISO 9001 Clause 7.5.2 - Validation of Process for Production and Service Provision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
S Understanding of Process Validations - ISO 9001 Clause 7.5.2 Validation Qualification and Validation (including 21 CFR Part 11) 9
Q Validation - The process or product? ISO 9001 Clause 7.3.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
S Special Process Validation - ISO9001 Clause 7.5.2 - How do I go about it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
D "Special Production Process" Validation and TS16949 Clause 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 5
Z Can we Exclude the Validation of Process Clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Validation of Soldering Process - Clause 7.5.2 - my conundrum! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Validation of Processes for Injection Moulding - Special Process? Clause 7.5.2 IATF 16949 - Automotive Quality Systems Standard 9
S What is the clause in ISO 13485 for SAP Software Validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
M AS9110C Clause 8.5.1.2 Validation and Control of Special Processes for Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9100D Clause 8.5.1.2 Validation and Control of Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
S Software Validation – Clause 4.1.6 of ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 12
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
M Satisfying ISO 9001 Clause 7.3.6 D & D Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R ISO - Clause 7.5.1.3 - CMM Software Program Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001 Clause 7.5.2 Validation of Processes - How to comply? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
P What is Validation, Verification and Improvement of FSMS in ISO 22000 Clause 8? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Q ISO 9001 clause that covers Production Line Re-Validation Quality Manager and Management Related Issues 10
F External Storage of Data - ISO 9001 Clause 7.5.2 Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Validation of Special Processes - N/A of ISO 13485 Clause 7.5.2 ISO 13485:2016 - Medical Device Quality Management Systems 12
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Interpreting clause 7.5.2.1 (validation of software used in production & service) ISO 13485:2016 - Medical Device Quality Management Systems 2
L Outsourcing "passivation" - Clause 7.5.2 Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O Format for Clause 7.5.2 (Validation of Processes) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Software validation question - TS 16949 Clause 7.6 IATF 16949 - Automotive Quality Systems Standard 4
Randy Clause 7.3 Design and Development - Verification and Validation Design and Development of Products and Processes 3
R Validation of Processes for Production and Service Provision - Clause 7.5.2 IATF 16949 - Automotive Quality Systems Standard 4
L Validation of Processes - Plastic Injection Moulding - ISO 9001 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
R Validation of Processes for Production - How are doing it? Clause 7.5.2 Reliability Analysis - Predictions, Testing and Standards 25
M Examples for Clause 7.5.2 - Validation of processes for production and service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
E Clause 7.3 - Verification and validation of the sub assemblies and the final product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
apestate ISO 9001:2000 Clause 7.5.2 Validation of Processes - Level II Response ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K Design & Development - Exclusion of Clause 7.3.6 - Design and Development Validation Design and Development of Products and Processes 6
B Design - Simple System - ISO 9001 Clause 7.3 - Review vs. Verification vs. Validation Design and Development of Products and Processes 12
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
