QMS Document Management Software Recommendations
We are currently using Microsoft SharePoint for all of our QMS documentation (Processes, Procedures, Work Instructions, Forms, etc) but for the size of our organization, we have determined that this is not the right tool. It's really just a repository of files within document libraries (some have approval workflows, revision control but most libraries do not.) We are looking for a stand alone "QMS Document Management Software". We are not looking for a "Document Control" Module within a QMS Software. Does anyone have any recommendations? ConSense GmbH is the only Software that we have found so far, but would like to look at other options as well. Thanks.
Randy
How big are you? I've seen organizations that have 10,000 people on a shift use Sharepoint and even Windows Office or Lotus Notes.
Whatever you use, no matter the cost. size or complexity, will always be subject to "Garbage in - Garbage out", and only as good as it's managed
We are 6000+ people. Do large organizations really just use SharePoint for their documentation? It just seems to me that there should be better solutions out there. Thanks though.
Randy
I'd like to be able to tell you who uses it by name, but if you use gasoline, have anything made from plastic, fly commercial or use a MS Windows based computer you probably are familiar with some of the company's
Tagin
Just searching on "QMS Document Management Software" I found this: Document Management Software | AssurX Compliance QMS
I agree that SharePoint doc libraries are not the best thing, especially for enduser use. We (a small company) use SharePoint, and I create pages for each department or functional area. On those pages, I use link webparts, and other webparts to organize links to documents, forms, reports, external links, etc. that are relevant to the particular needs of those users. I doubt more than a handful of employees have ever viewed the actual document libraries that house all the documents behind the scenes. All most users need is a main menu link or tab to get to "their page", which then contains all the items that they will use.
ScottK
Not out of the crisis
Hi There cpeter17.
For a 6000+ person organization you're going to need something pretty robust.
Have you looked at Documentum? A lot of larger companies use that.
Or Master Control? I believe you can just get the document control module and then have expansion possible later if needed.
Verse also has a doc control system and I don't believe you need to own other modules.
Watchcat
ScottK, I'm in RA, not Quality, so I don't know what these systems look like, nor do I totally understand the discussion. However, I would like to understand, so I will ask, do your suggestions (or some of them) run counter to:
ScottK
Hi Watchcat
when you search for eQMS systems, most are integrated systems that offer modules that can be interconnected. For example, I am currently learning Q-Pulse and we have several modules including Documents, CA/PA, Training, Assets (calibration), and others. This way a new procedure can be linked to training so it cannot be released until training is complete (if you choose to set it up that way).
Master Control and Verse are like Q-Pulse but more focused on the document and record control - I don't believe you need to pay for all the modules. and they are far more expensive, catering to large companies.
Documentum, as I understand it (I've never used it personally but have connections who have), is strictly for enterprise document management and doesn't have the other QMS modules. So this is more in-line with OP's search.
I have used another program called DocLineUp in manufacturing that is strictly for document control. It was really meant for hospitals and labs but we modified it and it did a fine job for us. But it couldn't be linked to our CAPA, Training, NCR, etc. databases. This was a while ago and don't know if it's around anymore or has evolved into something new.
Hope that helps
D Specifications - All the same type of document? Change Management part of our QMS Document Control Systems, Procedures, Forms and Templates 4
M IMDRF document - Application of QMS to SaMD ISO 13485:2016 - Medical Device Quality Management Systems 2
J Is DCR (Document Change Request) Needed for Initial QMS Procedures? Document Control Systems, Procedures, Forms and Templates 16
K Non-Disclosure Agreement as a QMS document Document Control Systems, Procedures, Forms and Templates 9
Q Document Control ECO (Engineering Change Order) or QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
C Document Nomenclature - Can you call WI (Work Instructions) a QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
F CE Mark Technical Files as controlled document in ISO9001 QMS Document Control Systems, Procedures, Forms and Templates 7
J Looking for stand-alone QMS manual & procedures for ISO 14001 as a guidance document. Document Control Systems, Procedures, Forms and Templates 8
D What document will indicate the date the QMS became effective? Misc. Quality Assurance and Business Systems Related Topics 4
M Supplied Goods out of QMS / DtS? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Can outsourced processes be excluded from QMS scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
H QMS ISO 13485:2016 - ISO14971 IEC60304 etc ISO 13485:2016 - Medical Device Quality Management Systems 2
S Implementation of QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Correcting Electronic QMS Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Are We Ready for a QMS? Quality Management System (QMS) Manuals 7
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
J Quality Objective for QMS prior to Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
V Remote QMS Coordinator Position Job Openings, Consulting and Employment Opportunities 0
A How to prepare QMS manual for purchasing department Quality Management System (QMS) Manuals 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 11
supadrai Remote Opportunity - Large Scale Glove Factory QMS / RA / Legal Job Openings, Consulting and Employment Opportunities 0
C Retention of QMS Plans and Reports ISO 13485:2016 - Medical Device Quality Management Systems 5
Q New QMS...Old Projects ISO 13485:2016 - Medical Device Quality Management Systems 5
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
R Gap Audit Aerospsace and Rail QMS Quality Manager and Management Related Issues 0
S AS9120 Store QMS packages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Disappointed in leadership buy-in to QMS Quality Manager and Management Related Issues 67
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
T How you ensure that QMS is effective and efficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Is QMS like a set of rules and regulations that a company follows? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Timeframe for updating QMS / transitioning from ISO 14971:2012 to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 10
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Offsite storage of QMS documents ISO 13485:2016 - Medical Device Quality Management Systems 9
L Exemption from the Regulation COVID-19 and QMS requirements EU Medical Device Regulations 2
DuncanGibbons Model-Based procedures and Architecting the QMS as a System Document Control Systems, Procedures, Forms and Templates 2
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Expanding our business and the implications to our QMS Manufacturing and Related Processes 2
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
M QMS for a repair/servicing company ISO 13485:2016 - Medical Device Quality Management Systems 2
A Is there a better way to do a complete assessment of our QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
