QMS Overhaul - Reorganizing and Renaming Documents - Internal References
#11
Interesting. Like someone said earlier, naming conventions need to work for your company and it looks like all these examples do.
RIght now I'm in the process of rewording our procedure that deals with documents to match our new practices. I feel that these things need to be done in a certain order to come out successful on the other side. And this
Without referencing, expect dead roots.
is gold, totally agree. I'm going to start manually going through all the documents and changing the old document references that did exist to the new corresponding document name.
Maybe this post needs some more structure:
1.Create spreadsheet to track old document, name and "code" and how it correlates to new name and "code"
2. Revise "Procedure" that deals with documentation to reflect new practices (in process)
3. Decide whether revisions will continue or start over (should probably add this to the document PR with a statement "from this day..."
4. Physically change documents with new names, formatting, etc.
5. Backup all original docs (Actually that was the first thing I did, everything I'm working with is a copy)
6. Upload new everything to our system
Sound about right? Am I missing anything or would you guys do it differently? As for the rest of management, they should be fine with the cheatsheet from step 1 so I won't have to hear, "Where's this document?" 50 times a day...
Randy
#12
Be careful because you're picking a potentially really bad cup of Hemlock here. You're #1....#1 priority will be that of control, awareness, accessibility and everything else that can go wrong.
I just went through this with a client just this audit year (QMS multi-site certification). Previously they had documentation down picture perfect (including document access to every location from any other location) and then they decided to fix it. Cutting to the chase, after the "fun" we had this year, they're going back to the original method.
You have totally got to maintain every aspect of control.
Johnnymo62
Haste Makes Waste
#13
We use 4 different codes depending on the type of information is contained in the document. I.E. QMSD-1001 is our quality manual. The "D" stands for documents. We use QMSF- for Forms. QMSP- for procedures. QMSM- for process maps. This system works very well for us, as it is easier to search by the type of document, rather than by department or clause.
Ted Rocks!
Richard Regalado
#14
I use a 5-level in my documentation tiering. Here are my classification levels:
L1 - policy documents may include policy statements, information security policies manual,
L2 - anything procedural i.e., documented procedures, WIs, etc.
L3 - standalone documents guidelines, risk registers, business impact analysis worksheets, approved external providers list, etc.
L4 - templates or forms
L5 - records
Jen Kirley
Quality and Auditing Expert
#15
Coming back to the original question of a mass change:
The advice to "do as suits you" is fine. The standard is asking for your documents to be accessible, retrievable, preserved etc. How you do that is up to you. Very often organizations write document control procedures that are so constrictive that they think they need to do 300 formal engineering change notices for just a different logo in the header. We have discussed this sort of thing in the Cove before.
If you have a document control procedure that does not allow for a simple "administrative change" that is the first update I would make. In an administrative change, the revision block gets a note of what changed when, and who did it. If there are no changes to instructions for work, acceptance criteria or other critical details, there is just no need for a round of signoffs.
My heart goes out to the people who must go into all those documents and make updates to references buried in the text. It might make it easier to do a search-and-replace, but if it's possible to say what the user needs to know in a simpler way and make a reference table in the first page, maybe that would help. I can't see your documents so it's hard to know.
To summarize, just don't make it harder than it needs to be.
rogerpenna
#16
A question... why are CODES used??
I suppose usually codes match TYPE of document.
So for example... CP-0001, QMSP-0001 for Procedures, QMSM for process maps (using codes listed above as examples, our company codes are in portuguese)
Why not having just the name of the document and the full name of the TYPE of document? Why a number for it?
The reason I am specifically asking, is because we had a DMS and we are creating a new system for our company, customized, which will include Document Management, some other QMS systems, as well as stuff directly related to our business (Client Contract Management, Bidding, Engineering, etc)
Then the programmer created an Alpha version of the Doc system. When setting a type of document, we give it a code, alongside metadata, approval list, etc.
But that code is not showing in the list of documents.
It only shows the particular document name, type of document (let's say, Procedure).
I questioned him. He said he only included code in the configuration of type of document because we asked, but he used it for nothing.
I want to give him a nice answer why document codes are important. But I could not think of anything lol. Specially because we can already see the type of document, by full naming.
Maybe they are not so important after all?
rogerpenna
#17
L5 - records
what's the use of tiering the documents? And do you use it in the code?
greatwhitebuffalo
#18
"A question... why are CODES used??
Why not having just the name of the document and the full name of the TYPE of document? Why a number for it?"
I suppose you don't need one, if that suits your system. Off the top of my head I like the codes for when I reference the document in other places (i.e. control plan / pfmea / quality manual) With the code system I simply reference the associated document number and the user is certain to look in the right place, there is no chance of documents getting duplicated as I simply would 'retire' the obsolete document (and code) and change all references to it.
rogerpenna
#19
Ok, that is a good reason I had forgotten about. I will give it. Out of the top of my head, it's specially good to have codes in training matrixes, etc, where you can´t write the whole title...
Also, even in text documents, if you use the code, it may tell you stuff about the document (like if it's a procedure, department it belongs to, etc)
#20
L Where to Start to Completely overhaul a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
E How to write a Project Plan to Overhaul our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
M Overhaul QMS or start over? How do you decide? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
J Quality Objective for QMS prior to Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
V Remote QMS Coordinator Position Job Openings, Consulting and Employment Opportunities 0
A How to prepare QMS manual for purchasing department Quality Management System (QMS) Manuals 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
supadrai Remote Opportunity - Large Scale Glove Factory QMS / RA / Legal Job Openings, Consulting and Employment Opportunities 0
C Retention of QMS Plans and Reports ISO 13485:2016 - Medical Device Quality Management Systems 5
Q New QMS...Old Projects ISO 13485:2016 - Medical Device Quality Management Systems 5
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
R Gap Audit Aerospsace and Rail QMS Quality Manager and Management Related Issues 0
S AS9120 Store QMS packages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Disappointed in leadership buy-in to QMS Quality Manager and Management Related Issues 67
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
T How you ensure that QMS is effective and efficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Is QMS like a set of rules and regulations that a company follows? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Timeframe for updating QMS / transitioning from ISO 14971:2012 to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 10
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Offsite storage of QMS documents ISO 13485:2016 - Medical Device Quality Management Systems 9
L Exemption from the Regulation COVID-19 and QMS requirements EU Medical Device Regulations 2
DuncanGibbons Model-Based procedures and Architecting the QMS as a System Document Control Systems, Procedures, Forms and Templates 2
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Expanding our business and the implications to our QMS Manufacturing and Related Processes 2
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
M QMS for a repair/servicing company ISO 13485:2016 - Medical Device Quality Management Systems 2
A Is there a better way to do a complete assessment of our QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
qualprod From paper to Electronic (records) in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
qualprod Documented actions and changes in the QMS by COVID 19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
DuncanGibbons Enterprise Architecture for QMS Conceptualization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
S Class I MDR Article 10 – QMS EU Medical Device Regulations 1
I Drupal for QMS Quality Tools, Improvement and Analysis 26
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Validation Records - Very young QMS Qualification and Validation (including 21 CFR Part 11) 2
E Sharepoint for ISO 13485 QMS for small IVD company ISO 13485:2016 - Medical Device Quality Management Systems 11
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
mike10 QMS Update - Rev. up or start over? Document Control Systems, Procedures, Forms and Templates 3
