Re: QMS and Calibration Procedure
Be carefull here.
"I had them calibrate and refer to ISO-17025."
Basically, if you do in-house cal, you'll have to be certified (registered) to the same standard. it's much easier and cheaper, in the long run, to outsource cal services.
" Is it advisable to add into my QMS procedures and work instructions now for how I want things to be at those points in time? Or should I just hold them in my bag of tricks and implement them at those time periods." If your procedure meets the standard during the audit, keep that bag of tricks closed. When you want to initiate a change, generate a Preventive Action to do it. This shows continuous improvement, a primary principal of ISO.
Remedial action: This is being stressed these days. Have a plan on how you plan to perform a risk-analysis when you do (and you eventually will) have a tool come back that was out-of-tolerance when you sent it in. Just because it comes back serviceable doesn't mean you can ignore the initial cal test.
"I want my establishment to be driven by the documentation, most do it the other way around". What you want is for your QMS to be process-driven, not paperwork driven. What happens is that you write what you feel is a great procedure. Then when it has to be implemented, you find (at least I did, with 29 years of hands-on experience in my business), that there's problems at the floor level or that you've added non-value adding activities to your QMS, which reduces productivity. Think in terms of the start of the project (when you receive an order from a customer). Map out the steps to product completion. That's your process. Then you document it.
This is the reason that, in my industry, aviation, many companies are moving to the SAE standard, AS9100. It does a better job of what ISO is supposed to promote, a process-driven QMS.
But the best piece of advice I could give you has already been given by Brad and others "But for goodness sakes, keep it simple. It's easier to communicate, and a heck of a lot easier to stay in compliance."
