QMS (Quality Management System) Manual - The Boss Wants a 4 Page Manual - What to Do?
How many pages is your QMS Manual?
  • 1 to 5 Pages
    Votes: 6 3.7%
  • 6 to 10 Pages
    Votes: 11 6.7%
  • 11 to 15 Pages
    Votes: 17 10.4%
  • 16 to 20 Pages
    Votes: 21 12.8%
  • 21 to 25 Pages
    Votes: 21 12.8%
  • 25 to 30 Pages
    Votes: 12 7.3%
  • 31 to 35 Pages
    Votes: 16 9.8%
  • 36 to 40 Pages
    Votes: 15 9.1%
  • 41 to 45 Pages
    Votes: 9 5.5%
  • 46 to 50 Pages
    Votes: 8 4.9%
  • 51 to 60 Pages
    Votes: 19 11.6%
  • Resembles Juran's Handbook
    Votes: 6 3.7%
  • We have no manual per se
    Votes: 3 1.8%
  • Total voters
    164
Justin
Have been following this thread for awhile and finally decided to add my :2cents: .
After several years of refinement, I have a quality manual template that is only 9 pages and satisfies both ISO 9001:2000 and AS 9100 B requirements for a quality manual.
What adds up is all the supporting documentation which explains how you do what your quality manual says you do.
I bet if I increase the margins and reduce the font I could get it down to 7 or 8 pages.
The manual is the easy part as the standard tells you exactly what needs to be there. It's all that supporting documentation that is the real work because it is different for every business.
JMO
psyched1
hjilling said:
It seems unclear what the purpose of what the "manual" is there for. The manual is just there to address the requirement to have a manual, but what does it do? By the way, I agree the other documents can be "lower level" though I don't know if TS particularly addresses the old multi level pyramid of documents. I think it regrds them as documents, which is fine.
But, what is the purpose of the manual? It doesn't address very much. There may need to be more in define the interlinks between processes as well. Recent witness auditors have required more detail than that, I am told. ...my two cents...
Hjiling has asked the right question "What is the purpose of the manual?". I've seen Quality Manulas used as the main document supplementing procedures and working directly to work instructions which is an older more traditional use requiring additional pages due to content. Ive seen Quality Manuals used as sales pamplets pointing out key aspects of the system that appeal to customer. I've even seen a larger Quality Manual used literally as a door stop (DoD facility). :frust:
If you really belive managers not assigned direct quality responsibility are going to read your manual you are in for disappointment.:(
During an implementation I set up the Quality Manual as a prinicple auditing tool. I provide the traditional org chart, procedures list with a responsibility matrix, a plant map (I hate it when I lose auditors:D ) and a process flow. I provide a uncontrolled copy for auditors use.
The bottom line is determine the use of the manual if your hand cuffed to a standard then make sure it is appleid as required without waste.
Hey - just got a 4 pager in the mail.........
from Comcast of all companies!:mg: It includes lots of things which look amazingly like 'policies' and 'procedures' and stuff like that to tell us cable customers what's what with Comcast products and services:agree1:
Maybe my model of a 4 page quality manual wasn't so far off, after all:jawdrop:
Merry Christmas everybody!:bigwave:
Andy
W
wilsonmm
Justin said:
Have been following this thread for awhile and finally decided to add my :2cents: After several years of refinement, I have a quality manual template that is only 9 pages and satisfies both ISO 9001:2000 and AS 9100 B requirements for a quality manual.
The QA office of our business sector will always tell me to "keep it short and simple," but every time they audit us there are always 5-7 suggestions of things that should be added. My current plan is 37 pages in an old format that doesn't relate to ISO. When I redo it next year in ISO format, I'm going to shift a lot from the body of the document into appendixes, but still think it will wind up at least 40 pages long.
F
fqm1001
hello
i am a consult, i have consulted many companies, most of the quality manual are about 30-40 pages,i think it is normal level,
K
kaliko81
vanputten said:
We just had a TS 16949 surveillance audit. Our auditors said that best practice is 4 pages for a TS 16949 Quality Manual.
What bothers me is that this discussion is based upon number of pages. Do we care about functionality and purpose or the number of pages that an external auditor is suggesting?
I care about functionality which is affected by number of pages for sure. People generally not read long documents (or postings :) ).
I think we need to discuss effectiveness and efficiency and not number of pages.
By the way, looking at the requirements in TS 16949, a quality manual can be 4 pages. All you need is a scope and exclusions statement, a reference to documented procedures, and a description of the interaction between processes. This is... all you need if it effectively and efficiently meets your busness requirements.
Regards, Dirk
Two years ago we went from QS to TS. Our quality manual in the QS time had 80 pages and when we got to TS, we build a pretty efficient process flow that explain it all in only 8 pages. What would made the difference is the number of and the structure of your processes.
Hang on!
Kaliko
juliedrys
Chiming in on this one...
Most of my clients are using a model I developed a few years ago, it's about 5 pages and it's booklet-sized (half-sheet).
It includes the scope statement/exclusions, a blurb about the company, the policy statement, the overview map, and a reference to the next level of docs. Some clients also want other things in there, photos of the product, etc., but I leave that up to them.
I did this because my experience as a consultant taught me that the quality manual was the least used document in the system; this booklet-style manual, when designed well, is an attractive and easy-to-read handbook that can also be used for marketing. Most clients put their registrar's logo on the back after they get registered, and the registrars like that.
I had one auditor/registrar tell me that it was the best design for a manual that he'd ever seen. I don't know about that, but at least it's not a waste of paper anymore -- it only has information that people need, and it's likely to be read by most of the employees.
K
kei_ko
i would like to see a sample too, if possible :thanx:
John Predmore Explain Quality Management System (QMS) for the uninitiated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T IATF 16949 Quality Management System (QMS) Scope Requirements IATF 16949 - Automotive Quality Systems Standard 11
A QMS (Quality Management System) for Logistic Agency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Where does the QMS (Quality Management System) fit in your organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P What is a QMS (Quality Management System), really? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
0 Feedback on proposed restructure of Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K The differences between ISO 9001 vs a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F How to set-up a Dual Company QMS (Quality Management System) Quality Manager and Management Related Issues 2
A Software Tools for managing a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Processes required for the Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Q Where to include the SIPOC results in QMS (Quality Management System)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Shortcomings of Compliance Focus Quality Management System (QMS) Quality Manager and Management Related Issues 3
S QMS (Quality Management System) and Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
M Building an AS9100 QMS (Quality Management System) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
J Difference between Management System and QMS (Quality Management System) General Auditing Discussions 5
J Supplier Quality Management System (QMS) Audit - Formal Documented QMS does not exist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B Where do policies fit in the setting up of a Quality Management System (QMS)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Marketing Process as part of QMS (Quality Management System)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
C How do you measure the Effectiveness of a QMS (Quality Management System) Quality Manager and Management Related Issues 34
S Including Product Trade-Ins in our Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
O QMS (Quality Management Systems) Team Structure & Responsibilities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
W Sustaining a TS16949 QMS (Quality Management System) IATF 16949 - Automotive Quality Systems Standard 15
Y Training on the Basics of a QMS (Quality Management System) for ISO 13485 Training - Internal, External, Online and Distance Learning 4
D QMS (Quality Management System) on Intranet - Business Case ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Marc Definition QMS - Quality Management System - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
J Sitting Back and Reflecting on ISO 9001 QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R BMS Vs QMS (Business Management Vs Quality Management System) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Building the QMS (Quality Management System): Getting Started Document Control Systems, Procedures, Forms and Templates 16
G Requirements for Implementing an ISO 9001:2008 Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L Definition Quality Management System (QMS) as per ISO 9000:2005 - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
V ISO 9001 QMS (quality management system) for MBA College ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Help a newbie to develop a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
Q QMS (Quality Management System) Fundamentals Training Training - Internal, External, Online and Distance Learning 4
G Must the QMS Management Representative be part of the quality department? Quality Manager and Management Related Issues 23
Pancho Interesting Discussion Using a Wiki to implement a Quality Management System (QMS) Document Control Systems, Procedures, Forms and Templates 273
O QMS (Quality Management System) in a Project Implementation Organisation Quality Manager and Management Related Issues 3
I Developing Quality Objectives for a Quality Management System (QMS) Quality Manager and Management Related Issues 7
K Quality Management System (QMS) Echo Training or Refresher ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Creating a New QMS (Quality Management System) from Old AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Evaluating my QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Writing a QMS (Quality Management System) Manual from Scratch Quality Management System (QMS) Manuals 2
R ERP/MRP system as part of the QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
F Training Employees on the QMS (Quality Management System) Training - Internal, External, Online and Distance Learning 4
Q How can I make the QMS (Quality Management System) interesting to employees? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
B When is a QMS not a "Quality" Management System? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T QMS (Quality Management System) for a business support organisation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Quality Management System (QMS) audit checklist needed General Auditing Discussions 3
F Quality Management System vs. Effects of Local Culture on Implementing a QMS Misc. Quality Assurance and Business Systems Related Topics 22
P How to Assess the Effectiveness of the QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L What TYPES of documents are in your QMS (Quality Management System)? Document Control Systems, Procedures, Forms and Templates 7
