QMS (Quality Management System) Manual - The Boss Wants a 4 Page Manual - What to Do?
How many pages is your QMS Manual?
  • 1 to 5 Pages
    Votes: 6 3.7%
  • 6 to 10 Pages
    Votes: 11 6.8%
  • 11 to 15 Pages
    Votes: 17 10.6%
  • 16 to 20 Pages
    Votes: 21 13.0%
  • 21 to 25 Pages
    Votes: 21 13.0%
  • 25 to 30 Pages
    Votes: 12 7.5%
  • 31 to 35 Pages
    Votes: 15 9.3%
  • 36 to 40 Pages
    Votes: 15 9.3%
  • 41 to 45 Pages
    Votes: 9 5.6%
  • 46 to 50 Pages
    Votes: 8 5.0%
  • 51 to 60 Pages
    Votes: 18 11.2%
  • Resembles Juran's Handbook
    Votes: 6 3.7%
  • We have no manual per se
    Votes: 2 1.2%
  • Total voters
    161
Josep_GN
Re: QMS (Quality Management System) Manual - The Boss Wants a 4 Page Manual - What to
Hi Dawn,
As most of other that have replied you I agree, if you want to cover all the points of the standard in your manual you will need at least 20 or 30 pages but there is something more to say.
Think about that, who is your first customer for the manual? Yes, your boss.
Are you able to convence your boss that it is needed a 20 pages manual? If the answer is no and you want to keep your main customer happy and your post, you will have to work harder.
I think it is a challenge, but possible to get. Your manual, for ISO 9001 and ISO/TS 16949 only needs to state:
1.- Scope of your system and exclusions
2.- Reference to your procedures
3.- Description of the interaction of your processes.
I'm sure you can write your scope and exclusions in just one or two paragraphs.
Reference to procedures in no more than one page.
Map of processes, of course at first level, one page more.
And you will have one free page for the cover. Total 4 pages.
Of course you will have to do a more robust documented system at 2nd level, but still possible.
Good luck,
Josep
BenL712
To reiterate many things stated here before, I believe the quality manual needs to be useful and cover the requirements. The format or length is irrelevant if both of the previous are satisfied, subject to your organization's approach.
On a slightly different topic then, can someone please explain what appears to me to be the inclination to create processes/procedures/requirements that turn around and state that another process/procedure must be written to incorporate all of the requirements? It seems to me that this is just more documentation for redundancy's sake. I've seen this in many areas, and I think it may be at the heart of some of the QMS Manual length debate.
For example, if the standard or corporate procedures say I have to do provide training on Topic A, then why have another document stating that I will do training on Topic A? Just write the process that says when, where, how, who, etc. because it is required by standard/procedure X, and be done with it.
N
noboxwine
I suggest one page, that includes only the requirements:
1. Scope and Permitted Exclusions and Justification (if applicable)
2. Procedure Reference
3. Process Map
I have never seen a Quality Manual used as a working document, so make it easy on yourself for 4.2.2 and spend your time improving the process.
JaneB
? Sounds to me more of a policy or a plan than a procedure.
The only time I have seen this is when someone really didn't quite understand what they were doing.
JaneB
Excellent post, Pennington. You made a number of very good points, succinctly and clearly. Well said.
Whether this takes 1 page or 5000 pages is irrelevant. The measure of its effectiveness is whether it aids understanding.
Yup!
John Broomfield
I have created a quality manual for our company which is 40 pages. It simply covers every element with a paragragh or so, except for Management Responsibility is covered in the manual instead of a procedure.
My superiors feel the manual should only be 3 or 4 pages long. Most of this reasoning is from different companies who have claimed to be certified.
Am I wrong in assuming a 3 or 4 page manual would not be adequate, and what exactly would be accurate?
Thanks, Dawn
Dawn,
For some reason the quality manual commonly is a re-write of the standard in terms applicable to your system.
This is not required by the system standard but some registrar's auditors seem to expect this type of quality manual.
Clause 4.2.2 of ISO 9001 specifies the minimum contents of the quality manual.
You may only need three pages to describe/specify your system and refer to its procedures.
You may also need to replace your auditor! :whip:
John
Helmut Jilling
Auditor / Consultant
Dawn,
John
You know, it's a funny thing. I am with a consulting client right now, working on a quality manual. The client and I decided it would be more useful to write a full 30 page manual. The reasoning is we will take the standard as a base, and revise/rewrite it in plain English and explain the requirements and their purposes. Many of the procedures will be incorporated into the manual. This way, employees will have a single document to go to to answer any questions they have related to ISO.
Further, we are going to combine ISO 14001 into it as well. Simple, clear and user friendly.
Now, whether someone writes a 3 page manual with 30 additional pages of procedures, or if they write a 33 page manual incorporating the procedures, is there really any difference? The only diff I see is my method will be one computer file, titled ISO manual, and everyone will be able to use and understand it. The other way there are 10-15 procedures, files, links and most of the time, way more complicated.
The important thing is they be written clearly, and easy to find. The rest of the discussion is silly. When Executives complainabout the number of pages, they are really complaining about the absence of any apparent value. The manuals need to be written to benefit the users.
John Broomfield
Helmut,
Excellent point, the manual could be an attractive brochure/webpage for the system so everyone understands how it works in preventing pollution, adding value and preventing loss.
I am not sure everyone needs to know what the system standards require.
John
P
Pennington
I agree that not everyone needs to know what the standards requires but everyone should know what the purpose of the quality manual is.
I am intrigued as to why anyone would call the manual the ISO manual - doesn't this send out the signal that it exists only to satisfy the standard and is disconnected from the business?
If top management don't use your quality manual to communicate their intentions with respect to quality to all stakeholders, the document you presently call the quality manual adds no value and should be scrapped.
John Broomfield
Pennington,
Agreed, worse than ISO manual is "ISO system" on the "I drive" maintained by an "ISO coordinator". :frust:
One day it will be XYZ Management System on the shared drive maintained by the System Manager.
Is getting "ISO certified" the worst reason for writing/copying and bolting-on another system of documents to the system that actually runs the business?
John
John Predmore Explain Quality Management System (QMS) for the uninitiated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T IATF 16949 Quality Management System (QMS) Scope Requirements IATF 16949 - Automotive Quality Systems Standard 11
A QMS (Quality Management System) for Logistic Agency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Where does the QMS (Quality Management System) fit in your organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P What is a QMS (Quality Management System), really? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
0 Feedback on proposed restructure of Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K The differences between ISO 9001 vs a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F How to set-up a Dual Company QMS (Quality Management System) Quality Manager and Management Related Issues 2
A Software Tools for managing a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Processes required for the Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Q Where to include the SIPOC results in QMS (Quality Management System)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Shortcomings of Compliance Focus Quality Management System (QMS) Quality Manager and Management Related Issues 3
S QMS (Quality Management System) and Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
M Building an AS9100 QMS (Quality Management System) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 21
J Difference between Management System and QMS (Quality Management System) General Auditing Discussions 5
J Supplier Quality Management System (QMS) Audit - Formal Documented QMS does not exist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B Where do policies fit in the setting up of a Quality Management System (QMS)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Marketing Process as part of QMS (Quality Management System)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
C How do you measure the Effectiveness of a QMS (Quality Management System) Quality Manager and Management Related Issues 34
S Including Product Trade-Ins in our Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
O QMS (Quality Management Systems) Team Structure & Responsibilities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
W Sustaining a TS16949 QMS (Quality Management System) IATF 16949 - Automotive Quality Systems Standard 15
Y Training on the Basics of a QMS (Quality Management System) for ISO 13485 Training - Internal, External, Online and Distance Learning 4
D QMS (Quality Management System) on Intranet - Business Case ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Marc Definition QMS - Quality Management System - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
J Sitting Back and Reflecting on ISO 9001 QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R BMS Vs QMS (Business Management Vs Quality Management System) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
J Building the QMS (Quality Management System): Getting Started Document Control Systems, Procedures, Forms and Templates 16
G Requirements for Implementing an ISO 9001:2008 Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L Definition Quality Management System (QMS) as per ISO 9000:2005 - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
V ISO 9001 QMS (quality management system) for MBA College ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Help a newbie to develop a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
Q QMS (Quality Management System) Fundamentals Training Training - Internal, External, Online and Distance Learning 4
G Must the QMS Management Representative be part of the quality department? Quality Manager and Management Related Issues 23
Pancho Interesting Discussion Using a Wiki to implement a Quality Management System (QMS) Document Control Systems, Procedures, Forms and Templates 271
O QMS (Quality Management System) in a Project Implementation Organisation Quality Manager and Management Related Issues 3
I Developing Quality Objectives for a Quality Management System (QMS) Quality Manager and Management Related Issues 7
K Quality Management System (QMS) Echo Training or Refresher ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Creating a New QMS (Quality Management System) from Old AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
M Evaluating my QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Writing a QMS (Quality Management System) Manual from Scratch Quality Management System (QMS) Manuals 2
R ERP/MRP system as part of the QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
F Training Employees on the QMS (Quality Management System) Training - Internal, External, Online and Distance Learning 4
Q How can I make the QMS (Quality Management System) interesting to employees? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
B When is a QMS not a "Quality" Management System? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T QMS (Quality Management System) for a business support organisation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Quality Management System (QMS) audit checklist needed General Auditing Discussions 3
F Quality Management System vs. Effects of Local Culture on Implementing a QMS Misc. Quality Assurance and Business Systems Related Topics 22
P How to Assess the Effectiveness of the QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L What TYPES of documents are in your QMS (Quality Management System)? Document Control Systems, Procedures, Forms and Templates 7
