QMS requirements for legal manufacturer when outsourcing manufacturing process
Hi guys,
I was wondering if someone can help me....If I'm the legal manufacturer of a medical device and I outsource the manufacturing process, what parts of the quality system requirements do I have to comply as per MDR 2017/745 and FDA?
Thank you.
Marcelo
Hello, and welcome to the Cove. If you are the "legal manufacturer" (please note that this term do not exist in all regulatory systems), you are responsible for complying with all the regulatory requirements, including the QMS requirements. If you outsource some aspects, you need to control them in YOUR qMS, but you must make it clear who performs them in your name (this is done thru a quality agreement, see this FDA guidance (chichis for drugs but the idea is the same for devices) - Contract Manufacturing Arrangements for Drugs: Quality Agreements.
Hi Marcelo,
Obrigada :) Was very helpful...
It means that i don't have to have in my QMS the procedures that my contractor manufacturer has (manufacturing procedures for example) in their QMS? I just have to control and make sure they (with their procedures) are compliant with QMS requirements?
For example: do I need device history record (batch/lot control) in my QMS or I can just use/control the contractor's records? Because as a legal responsible I have to track the devices specially for post market surveillance purposes.
Obrigada again.
racglobal
Hi Gisah,
As the legal manufacturer (your name on the label), you are responsible for the manufacturing part of your QMS even if it is outsourced. I would still recommend having manufacturing procedures in place to ensure the overall process is clear. You do not need your device history records, but your CMO should allow you access to the DHRs at your request. Again, this has to be made very clear in a quality agreement. If anyone has additional insights, I would also like to hear.
Ronen E
Problem Solver
Moderator
Hi Gisah,
I would say the other way around. They don't need manufacturing procedures for operations they don't perform and don't have expertise in anyway. On the other hand, I would try hard to reach agreement that they get a full copy of each DHR with the supplied corresponding batch. Only if they hit resistance I would go for an access agreement instead, and that only as a last resort (if proprietary info is involved maybe negotiate redacting or partial supply of the DHR). The time they might need the DHR the most might prove to be a time that the CM would be least cooperative, because there might be a conflict of interest in some cases.
Hi Ronen,
Thank you. I agree with you about the manufacturing procedures and DHR...it makes more sense.
Watchcat
I may be answering this one with my MBA hat on more than my RA hat. I would agree that you are responsible for your product, and not just for its compliance with regulatory requirements. I don't see how you can fulfill that responsibility if you don't understand its manufacture.
[As an aside for clarification, "The process is the product." I work mostly on the premarket side, where I find developers often think their design is the product. A design is just a good idea. V&V done right, confirms that the design is a good idea. The product is an output of the manufacturing process, and it is that process that defines what the product is. When products fail at scale up, it often turns out that the development team didn't include manufacturing expertise.]
I think contract manufacturing makes good business sense from the perspective of not having to make a huge investment in capital equipment and labor. It is essentially a means of achieving economies of scale. I think outsourcing expertise is quite a different matter.
Ronen E
Problem Solver
Moderator
In this context, understand is a parameter - there are infinite degrees possible between full understanding (expertise) and no understanding at all. IMO one can be perfectly responsible for their product with a good understanding at some medium detail-level; it's not necessary to master all the nitty gritty.
This is a great example why the term "V&V" annoys me so much. The second V typically stands for Validation, and here it apparently refers to Design Validation. While the latter is a very common term, fairly-well understood in the industry, it makes little sense if you look at what it actually means. One can't really validate a pure design (which is an abstract object; drawings are not the design, they're just a medium to convey it). To "validate a design" (in the sense regulators intend, and industry typically applies) you need a physical product, one that users can use. So a much more accurate term would be Product Validation (in contrast with Process Validation, which is a different beast).
In that sense Design Validation, or Product Validation, can't be completed without some fairly-good understanding of the manufacturing process, and especially it's parameters, noises and limitations, but the step where a very intimate knowledge of the manufacturing processes is required is actually Process Validation. Luckily, Process Validation can usually be scoped as a turn-key and outsourced to a Contract Manufacturer. Again, it doesn't mean one should shut their eyes and minds to it - it's always better to have some understanding, involvement and critical thinking even if one doesn't have the expertise; but it's usually unnecessary (and maybe even damaging) to control every little detail in this activity (where outsourced).
I tend to agree, and we have a name for it - DFM (Design For Manufacturability). But that should come quite before one even starts to develop the manufacturing process in any detail. It's an essential part of product design, not something external to it. When design engineers fail at that (and they do, quite a lot, sadly), it is a design failure first and foremost. The level of expertise that a CM typically has, the one that IMO the Specification Developer doesn't need to have, is at much finer levels of detail. It can, and usually should, be incorporated into the product realization process, but it can happen in later stages.
I think you might have written this wearing your Class III devices hat. When considering lower-risk device types, outsourcing manufacturing (Private Labeling) is, not in a few cases, a way to gain access to technical expertise while focusing on core strengths such as marketing. I'm nothing near a business expert, but it seems to me that it works all right, at least in some of the cases.
Watchcat
While I like "V&V" 'cause its catchy. :p
I see where you are coming from, but on this I think I'll stand my ground. You make physical devices that meet the design requirements, you use them to validate the design (essentially that you CAN make a physical device that meets the design requirements AND the user requirements). So it really is a good idea! But it's not a product until you can reliably manufacture more devices that also meet requirements.
Maybe more my startup hat, as they love to do V&V with prototypes that they have no idea how to manufachave for market. Im not always opposed to this, but it tends to make them think they are done, when they are not, and still don't know if their good idea will ever be a marketable product.
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
L Exemption from the Regulation COVID-19 and QMS requirements EU Medical Device Regulations 2
R Approvals on QMS Documents - ISO 13485 Requirements Document Control Systems, Procedures, Forms and Templates 2
C CE marking for general IVD (self-certified) & ISO 13485 QMS requirements - auditing EU Medical Device Regulations 6
B IATF 16949 Supplier QMS Requirements IATF 16949 - Automotive Quality Systems Standard 3
K Meeting the requirements of ISO 13485:2016 Cl. 4.1.4 within a wiki-based QMS ISO 13485:2016 - Medical Device Quality Management Systems 3
D How to add AS9145 requirements to my existing AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T IATF 16949 Quality Management System (QMS) Scope Requirements IATF 16949 - Automotive Quality Systems Standard 11
Marc IAQG 9100:2016 - QMS Requirements for Aviation, Space and Defense AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Buckyb Boeing QMS Requirements for Tier 2 Distributors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
J Requirements for Review and Approval of QMS Documents Document Control Systems, Procedures, Forms and Templates 14
N Identifying Changes and Revisions in QMS Documents - 4.2.3.c Requirements Document Control Systems, Procedures, Forms and Templates 13
T QMS & CE Mark requirements for an EU Market Distributor/Trader CE Marking (Conformité Européene) / CB Scheme 7
D Auditor Requirement to 'Map' TS 16949 Requirements against our QMS IATF 16949 - Automotive Quality Systems Standard 27
T Quality Compliance Software to meet ISO 13485 QMS and 21 CFR 820 Requirements Quality Assurance and Compliance Software Tools and Solutions 3
M AS9100 Clause 4.2.3 requirements - Documents required by the QMS shall be Controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
J QMS Planning Requirements - What are the 5 clauses involved? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 13485, ISO 9001 QMS and FDA Requirements - Process vs. Compliance Approach? ISO 13485:2016 - Medical Device Quality Management Systems 4
J What's the meaning of word "map" (Map these requirements with your implemented QMS)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K How can I revise my QMS documents to meet requirements of ISO 9001: 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G Requirements for Implementing an ISO 9001:2008 Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q QMS General Formula - Satisfying the Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 42
Hershal Accreditation to ISO 17025:2005 meets ISO 9001:2008 QMS requirements ISO 17025 related Discussions 5
J Software for tracking QMS training - Database to track training requirements Quality Tools, Improvement and Analysis 2
P QMS-requirements should be excluded from the customer specific requirements Customer and Company Specific Requirements 13
T How to implement Customer Requirements into your QMS under TS IATF 16949 - Automotive Quality Systems Standard 1
1 Should I be concerned about Sarbanes-Oxley requirements affecting my ISO9001:2000 QMS Various Other Specifications, Standards, and related Requirements 6
D Heavy Truck QMS Requirements Customer and Company Specific Requirements 1
Gman2 ISO 9001:2000 - Requirements for Control of the QMS Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
R ISO 13485 Medical Devices QMS - Requirements for Regulatory Purposes Checklist ISO 13485:2016 - Medical Device Quality Management Systems 26
J Quality Objective for QMS prior to Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
V Remote QMS Coordinator Position Job Openings, Consulting and Employment Opportunities 0
A How to prepare QMS manual for purchasing department Quality Management System (QMS) Manuals 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
supadrai Remote Opportunity - Large Scale Glove Factory QMS / RA / Legal Job Openings, Consulting and Employment Opportunities 0
C Retention of QMS Plans and Reports ISO 13485:2016 - Medical Device Quality Management Systems 5
Q New QMS...Old Projects ISO 13485:2016 - Medical Device Quality Management Systems 5
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
R Gap Audit Aerospsace and Rail QMS Quality Manager and Management Related Issues 0
S AS9120 Store QMS packages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Disappointed in leadership buy-in to QMS Quality Manager and Management Related Issues 67
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
T How you ensure that QMS is effective and efficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
