QMS Software Recommendations for a Small Company
dianamendes
My company is considering to buy a QMS software.
We are a small consultancy company of 20 employees. We need something easy to use ( the ones in charge of the QMS will also be working in projects so there is no time for extensive training...) that is made for service companies rather then industries (our "products" are "projects" and obviously we don?t have calibrations or inspections as in a factory).
Of course we are also interested in a affordable solution and that can be accessed in by iPhone of tablet.
Any idea?
If searched on previous discussions here in this Forum but all the softwares seem extremely complicated and with a horrible user interface...
P
PaulJSmith
What exactly are you looking for this software to do for you? Microsoft has some fine products - like Word, Excel, and Access - that will document just about anything you might need in a QMS, and it's probably already on your computers.
dianamendes
Hi!
Thanks for your reply.
We have a QMS system thought and planned (meaning we have a policy, manual, goals, procedures, indicators, etc).This "exercise" of understanding IF and WHY we need a QMS was already done with our management.
I developed all the documentation in Word and Excel with no problems. The thing is it requires quite a lot of time and probably 1 person full time to make sure you can control all the versions, updated when necessary, calculate indicators, take care of NC, etc. That would be the Quality Manager but in this case the Quality Manager will need to also perform other tasks.
so what we are looking for is a software that can do the following:
- to centralize all the info regarding the QMS (templates, procedures, reports, NC, complaints, etc);
- to helps us to easily define access restrictions to documentation;
- to make sure only the right version is used (this is quite important because we have several employees working out of the office and is difficult to ensure they always have the most updated information and are using it)
- to easily "spread de word" about a new update, version, procedure, etc;
- to collect data and calculate KPI?s (now I can do this with excel but will take me a lifetime....);
- to have a module to have all the info about suppliers and suppliers evaluations;
- to have all info about clients, complaints,etc;
- to have all info and attached documentation on employee training and evaluations
- flexible enough to allow us to add or change our processes when needed
When I say we don?t really have time to train our employees in a software I meant the "common users", the users that will only access some documents and insert few data in the system. Of course that for me or for other person that will be in charge of maintaining the system we must have time for a proper training.
I don?t see why our pre-conditions are a concern, as Jackbey said...isn?t it normal that you want to purchase something HMI friendly and affordable? I mean after all, the purpose of having a system like this is to make your life easier...if it?s even more complicated and at the same time expensive then you have it for nothing....
sagai
Diana,
I tend to say there is no single software that would fulfil your expectation, at least I have not come across with such.
I would set some priorities first to carry on.
Cheers!
Mikishots
Hi!
Your requirements are best served using Excel, Access and a simple server system with permissions. To be honest, getting software to do all of this under one system won't work - I know of no system that can do all of this better than using basic spreadsheet and database packages available to everyone.
Some examples:
Distribution of documentation is easily accomplished using a portal or Intranet; by keeping the versions of documentation current on the portal, staff can't use the wrong version, because they simply won't see them. "Hey Bob, what's the current revision of this instruction?" "Look on the Portal". Done.
Restrictions is a non-issue: revise permissions in folders, post public info on the Intranet.
You have 20 people. Spreading the word doesn't require software other than email.
Collecting data and calculating KPIs is best done in Excel. I know of no canned software that is easier to use or has better flexibility in data organization.
We have a staff of 650. We use training management software because we are a regulated industry (aircraft manufacturing), we use document control software because we have over 500,000 drawings and thousands of irreplaceable documents going back 70 years, and we use an ERP system for planning and scheduling manufacturing (you can't build an $8M aircraft without powerful ERP software). This level of software is simply not warranted by the activities you've described. You can modify canned software suites to do what you're asking, but I speak from experience of QMS implementation over 20 years - you're walking into a dark place if you're set on having a single canned system to do all these basic tasks. No company is going to spend hundred of thousand of dollars to produce software that does what Excel, Access and Word can do. It just makes no sense.
I'm in full agreement of looking at your preconditions. Sure, people want a one-stop-shop that is easy to use and affordable...but it's a pipe dream. You'll be pulling your hair out after three months.
mguilbert
I agree with others. I have not used wiki's but our company use sharepoint to store controlled documents. Like wiki's we can set permission levels. That is to say who can change or add documents, who can read only. Also we can set up RSS or email alerts based on the users needs. For example when document X is changed or modified. It sends an email or RSS alert to those who use the document.
drgnrider
I agree about using MS-Office and server permissions. We have about 200 employees and a multitude of ISO documents.
Server permissions on our ISO documents are set so only the QMR has full access, everyone else has read-only.
All of our documents are Word-based and forms are mixed Word and Excel, and the objectives are charted in Excel. All of these documents are individually password protected from editing.
When a document is changed, it is because the DOC owner has agreed to it and approved the changes. The QMR adds the revised document to the server, then an e-mail notification is sent to all the Managers for them to disperse it accordingly.
:2cents:
A relatively inexpensive software (although it might not fit all your needs) is Quality Link. It seems to be fairly straight forward and simple to use.
In case you are wondering, I have no relationship with the company, other than a couple of my clients have it and seem to like it.
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
QIE QMS and PLM software recommendations Medical Information Technology, Medical Software and Health Informatics 6
P QMS software recommendations for a small ISO 13485 company Quality Manager and Management Related Issues 5
K QMS Software Recommendations for an Analytical Laboratory General Measurement Device and Calibration Topics 2
E Recommendations for the Best TS 16949 QMS Software Quality Assurance and Compliance Software Tools and Solutions 2
W What Commercial (off the shelf) QMS Software are you using - Any Recommendations? Quality Assurance and Compliance Software Tools and Solutions 14
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
B We need a QMS: file-based templates or software Other Medical Device Related Standards 23
H QMS Software Recommendation (US based, Hemp) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Benefits of electronic QMS software Software Quality Assurance 5
T Risk analysis of QMS software - Validating software we use for QMS ISO 13485:2016 - Medical Device Quality Management Systems 5
I QMS documents required at each stage of Software development IEC 62304 - Medical Device Software Life Cycle Processes 5
J Choosing QMS Software for Aerospace Company Quality Assurance and Compliance Software Tools and Solutions 5
G Looking to move to an electronic QMS software Software Quality Assurance 11
J Does anyone here use ISOXpress/IMSXpress QMS software? Software Quality Assurance 11
M Switching (Migrating) to a new QMS Software Package Document Control Systems, Procedures, Forms and Templates 14
S QMS software validation - Documentation ISO 13485:2016 - Medical Device Quality Management Systems 5
A Process Validation of QMS Software ISO 13485: 2016 Cl. 4.1.6 ISO 13485:2016 - Medical Device Quality Management Systems 26
A ISO 13485:2016 - Validate our use of software that impacts on the QMS ISO 13485:2016 - Medical Device Quality Management Systems 10
Q QMS Software for Startup Medical Device Company Other Medical Device and Orthopedic Related Topics 7
D Anyone using a cloud based QMS software? Document Control Systems, Procedures, Forms and Templates 12
I How much does an eQMS (Electronic/Software QMS) cost? Quality Assurance and Compliance Software Tools and Solutions 1
A Software Suggestions for Engineering Change/QMS Design and Development of Products and Processes 2
W QMS and/or ERP software choices for both US and China Quality Assurance and Compliance Software Tools and Solutions 2
Q Finding the best QMS Software Quality Assurance and Compliance Software Tools and Solutions 4
G QMS Quality Plan Documents Software Document Control Systems, Procedures, Forms and Templates 4
J General QMS questions in regard to Medical Software ISO 13485:2016 - Medical Device Quality Management Systems 8
Marc What QMS and Regulatory Compliance Software are you using? Quality Assurance and Compliance Software Tools and Solutions 7
A Software Tools for managing a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N Best Custom Software (To Track QMS & Processes) Provider Quality Assurance and Compliance Software Tools and Solutions 9
D FDA Compliant QMS Software Recommendation for Small Company Quality Assurance and Compliance Software Tools and Solutions 3
T Quality Compliance Software to meet ISO 13485 QMS and 21 CFR 820 Requirements Quality Assurance and Compliance Software Tools and Solutions 3
E Cheap, Cheerful Software QMS System Quality Assurance and Compliance Software Tools and Solutions 7
J0anne QPulse 5 - QMS - Software Opinion and help Quality Assurance and Compliance Software Tools and Solutions 11
G Various ?QMS? packages on the market - Which software package? Quality Assurance and Compliance Software Tools and Solutions 35
B Using Job Shop ERP Software for a QMS Quality Assurance and Compliance Software Tools and Solutions 2
J QMS Software Checklist and Comparisons Matrix Quality Assurance and Compliance Software Tools and Solutions 2
K What are some of the best QMS Software Packages available? Quality Tools, Improvement and Analysis 5
K QMS Software - EtQ vs Trackwise Quality Assurance and Compliance Software Tools and Solutions 5
M MRP/QMS Software Package to replace our current Paper QMS - Help Quality Assurance and Compliance Software Tools and Solutions 4
A QMS and Computerized Software Compliance with Standards US Food and Drug Administration (FDA) 6
D Medical Devices Company QMS Software - Recommendation for an off the shelf software ISO 13485:2016 - Medical Device Quality Management Systems 13
L Mac OS X Compatible CFR Part 11 Complaint QMS Software Other US Medical Device Regulations 5
somashekar Software for QMS administration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Should Purchased Software for both SPC and Gage R&R be documented in the QMS? Quality Assurance and Compliance Software Tools and Solutions 2
Sidney Vianna AS9115 - Aerospace QMS Standard for Deliverable Software AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
