QMS Training - Purchasing Process - Seeking suggestions and comments
P
piney
Our purchasing department has undergone restructuring recently with several new (green) buyers added. It was determined during our most recent internal audit that this area of the company was in dire need of some form of ISO 9001:2000 QMS training to keep us on track.
Are there available training presentations out there which I could use as the basis for our own? What we are looking for is a training session covering the basics of quality management systems, with a focus on the purchasing process.
Thank you in advance.
ralphsulser
There are tons of trainers for ISO9001, some are frequent commentators on this site. Like Randy, Sidney, Dave, Vanputten, Hjilling, etc. sorry if missed others.Search around and send them private e-mails to get their specific info
Marc
Fully vaccinated are you?
Training because they don't know your company's procedures or because purchasing's procedures are not ISO 9001 'compliant'? Could you be more specific?
Wes Bucey
Prophet of Profit
Yes! Marc makes an interesting point. What is there about current operation that makes you think it needs some ISO 9001:2000 input versus some plain old common sense?
In my experience, Purchasing functions tend to get fouled up in one of two major directions:
  1. There are no Procedures - essentially Purchasing merely funnels EVERY purchase request to the most convenient supplier (sometimes just auctioning at lowest bid) without investigation or approval; OR
  2. There is too much red tape and EVERY purchase, from paper clips up to the most sensitive custom component, has to go through a wearisome pile of redundant paperwork (think government toilet seats at $600.)
When the purchasing department abdicates control over supplier selection and approval, downstream in-house customers often have to work around bad situations which erodes profits.
When the controls are overly tight, the inefficiencies of doing "busy work" in dealing with forms and approvals increases non-value-added costs, also eroding profits.
Caster
An Early Cover
Business not Quality
piney[/SIZE said:
Well, this is what I have put together so far. Each block will be turned into a slide in a MS PowerPoint presentation. I would appreciate any feedback / suggestions you may have.
Piney
I tend to take a much different approach, so this is offered for what it is worth.
I have found over the years that as soon as I start talking ISO, Quality, and clause numbers, the game is over.
I try to get through all such presentations by saying the word quality only once. I always substitute "business". I have even asked people to yell "business" if I accidentily slip and say quality (then I say it quite often to keep 'em awake)
Anything to get this out of the "ISO is mandated by quality - I'll do it after I get my REAL job done, if I have time" swamp.
Purchasing is a perfect example...what right does "quality" have to tell them how to run their department? None!
So I pitch ISO as some good common sense business ideas to help the Purchasing department perform better. I remind them that ISO was developed from decades of things gone wrong. There is no need to repeat the most common purchasing mistakes, if we take the advice ISO offers.
Your benefits slide is also something I have tried and failed with. It is motherhood. I now take very specfic examples of purchasing problems that cost money and try to lead people to discover that ISO already had that covered. Use caution because this is a minefield of egos and politics, someone in the room made that mistake!
Parts ordered to the wrong spec. New suppliers not able to achieve quality and cost targets, POs without enough information for the supplier to make the required part, and so on.
I have also done a quick workshop at the start to get people to list their top 10 problems. I then try to tie each one to an ISO clause. And lead people to perhaps see that there might be something in this for them. This is pretty hard to do, you really need to be fast on your feet, or send people for a coffee break to buy some time...
I hold up the ISO book as the cheapest consultant money can buy...$35.00 gets you a list of every mistake a business is likely to make...
So, I try to get people thinking that there may be some good things in this for them, even if it is customer mandated, and driven by thouse annoying people in Quality
It doesn't always work..mostly people go back to their busy day doing exactly what they have always done. But, I'll make 1 convert at a time....
Good luck to you!
Helmut Jilling
Auditor / Consultant
Caster said:
Piney
Good luck to you!
Caster - Very well stated. Excellent!
Peter Fraser
How about making it a workshop / discussion, based around the "process approach", and focussing on the procurement process and the Purchasing Dept's role in that, rather than looking at it as a departmental issue?
What kicks off the procurement process (eg sales order, stock reorder levels ...)?
What all is covered (goods, services, call-off contracts ...)?
Where (and who) does the request come from?
What is it they are trying to achieve?
What is the objective of the procurement process?
How does that fit with other (corporate) objectives (eg cutting stock levels, buying on price alone ...)?
What resources are needed for it to work effectively and efficiently (physical, staff, skills and knowledge etc)?
How do you measure success?
What can influence how well it works / what can go wrong?
How can you avoid things going wrong?
How do you fix things after they have gone wrong?
Is it clear who is responsible for each step?
Is it clear who else should be involved (consulted, informed)?
How will you improve?
A New to QMS and regulatory... advice on training/certification? ISO 13485:2016 - Medical Device Quality Management Systems 1
BeaBea QMS/ Training Management Software Service Industry Specific Topics 6
R ISO 13485 QMS Implementation Training ISO 13485:2016 - Medical Device Quality Management Systems 7
R ISO 13485 and QMS related concepts Training - Small medical device startup company ISO 13485:2016 - Medical Device Quality Management Systems 9
S Is Annual QMS Training Required? ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
T QMS Training for my organization - IATF16949 and also AS9100 or 9145 Manufacturing and Related Processes 2
J Training Personnel on the QMS - 7.3 Awareness or Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Log Files (Training, CAPA, Complaint, for example) & Lists in QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Who can provide a ISO 9001 Lead Auditor QMS training course? Training - Internal, External, Online and Distance Learning 2
Colin QMS IA Training Course in UK - 21st/22nd February 2013 Internal Auditing 4
Y Training on the Basics of a QMS (Quality Management System) for ISO 13485 Training - Internal, External, Online and Distance Learning 4
Q QMS (Quality Management System) Fundamentals Training Training - Internal, External, Online and Distance Learning 4
K Quality Management System (QMS) Echo Training or Refresher ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F Training Employees on the QMS (Quality Management System) Training - Internal, External, Online and Distance Learning 4
GStough Should a Training Matrix Be Approved Into the QMS? Training - Internal, External, Online and Distance Learning 9
J Software for tracking QMS training - Database to track training requirements Quality Tools, Improvement and Analysis 2
N Training on QMS (Quality Management System) for field employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
V QMS Lead Assessor Training Organization Recommendations General Auditing Discussions 21
C QMS and ISO 9001 Orientation training - How in depth this needs to be? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R ISO 9001 QMS Training - Accredited correspondance courses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Nawal QMS Quality Management System (QMS) Manuals 2
J INTERNAL COMMUNCATION OF QMS Quality Management System (QMS) Manuals 2
A QMS Roll out with guidance from ISO 9001 Quality Management System (QMS) Manuals 8
E QMS references in Safety Assurance Case? US Food and Drug Administration (FDA) 4
A Matrix to determine what's needed to create a QMS v ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N ERP for ISO 13485 QMS solution, your experience, reviews ? ISO 13485:2016 - Medical Device Quality Management Systems 1
Tagin Incorporating Large Language Model (LLM) AI into a QMS Coffee Break and Water Cooler Discussions 14
Vader22 INTELEX software for their IATF 16949 QMS IATF 16949 - Automotive Quality Systems Standard 0
B QMS language EU Medical Device Regulations 2
Q Where to place our Safety Program in our QMS? Occupational Health & Safety Management Standards 9
rivariva MDSAP audit QMS preparation Other Medical Device Regulations World-Wide 10
B How much staff input into the QMS is expected? Quality Manager and Management Related Issues 6
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B AS9100 Certification Audit Accounting for Additional Customer QMS Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
T Relation between ISMS and QMS for a SaMD Medical Information Technology, Medical Software and Health Informatics 3
T Errors & Omissions in Creating QMS Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T QMS Compliance Department KPIs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
A E-signatures for QMS? ISO 13485:2016 - Medical Device Quality Management Systems 4
A Document control system for QMS in Google Drive? Document Control Systems, Procedures, Forms and Templates 6
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
B Does anyone copyright their internal QMS documents? Document Control Systems, Procedures, Forms and Templates 24
M Possible topic for Master thesis topic - MDR and QMS ISO 13485:2016 - Medical Device Quality Management Systems 4
A Help understanding what it takes to implement a QMS that is ISO 13485 compliant ISO 13485:2016 - Medical Device Quality Management Systems 4
Q UK QMS Requirements UK Medical Device Regulations 2
B QMS On-Boarding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Questions concerning QMS and/or company specific nonconformance Customer Complaints 2
B ISO cl. 5.3 - Ensuring that the integrity of the QMS is maintained ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Scalable QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Using an online software to maintain your QMS Quality Assurance and Compliance Software Tools and Solutions 7
I QMS and ISO 9001 Misc. Quality Assurance and Business Systems Related Topics 11
