QS 9000 based ISO 9000:2000 or ISO 9000:1994
I
Internet-101
How much is appropiate to search obtain Qs9000 Certification based in ISo 9000:2000 instead of ISO 9000:1994.
And When will be last month to search obtain certification QS9000 based in ISO 9000:1994 according Ford, General Motors and Chrysler?
Please be good and answer me.
Thanks in advance for your help.
:bigwave: :bigwave:
Smile is good for your health!
D.Scott
Internet - QS-9000 will never change to ISO-9000:2000. It is based on the 1994 version and will not be revised. You cannot get a certification to QS-9000 with a 9000-2000 base.
Technically, you can still get a QS certification but why would you bother? Chrysler has already stated you must be certified to 16949 (tier 1 suppliers) and Ford and GM have advised a switch to 16949 although they haven't mandated it yet.
If you are a tier 1 supplier to any of the big 3, go for 16949 now and forget about QS-9000. QS will no longer exist past Dec. 2006 and it appears certifications to it will end Dec. 2003 (the certification is for 3 years).
This is my opinion but I am sure you will find similar advice elsewhere.
Dave
Casana
Blueberry Nut
Confused!!
We have two certifications (for two sister groups), one for ISO 9000 and one for QS9000.
During the ISO 9000:2000 upgrade audit for our one group, we discussed the other group's QS certification status. The registrar's auditor told us that for our QS certified group, we will need to upgrade our quality system to ISO 9000:2000 as well as still stay compliant with QS9000.
Personally I think he's wrong and was bluffing - 'cause it doesn't make sense to do both the 1994 & the 2000 standard at the same time.
My understanding all along (from another registrar I talked to in a previous job) was that QS is staying the way it is, and the certificate will still read as QS9000 & ISO 9k:1994 until we switch over to TS16949.
What have others heard on this topic?
Angela-2007
Just to clarify. You are not QS9000 certified you are QS9000 registered. GM has mandated TS by 2004 and Ford is mandating by 2006. Better bet that if you are a supplier to Ford that they will jump the gun soon and up their date to 2004. After 2006 you can be compliant to QS but not registered. 9000-2000 will be a stand alone cerficate.
Casana
Blueberry Nut
I understand that.
What I'm asking is - what happens to our QS certificate between now and 2004? Our current certificate says we're certified to QS9k and ISO 9K:1994. But after 2003 it will not be valid to claim to meet ISO 9k:1994 requirements. :confused:
NOTE - Registered/ Certified - to me its all the same - just a piece of paper, sorry if I mix them up. ;)
tomvehoski
This is from the latest QS-9000 intrepretation at www.qs-9000.org:
R8 Expiration of ISO 9001:1994 and ISO 9002:1994 on December 15, 2003 - certificate language for QS-9000 certificates to be recognized after December 15, 2003 (07/01/02)
Any new or renewed QS-9000 certificate issued after July 1, 2002 shall not reference ISO 9001:1994 or ISO 9002:1994 other than in one of the following statements which must be included on the certificate: “Registered to QS-9000:1998 (Based on and including ISO 9001:1994)” or “Registered to QS-9000:1998 (Based on and including ISO 9002:1994)”. All QS-9000 certificates with dates extending beyond December 15, 2003 shall comply with this wording by December 15, 2003. [All other aspects of Appendices G.A.13, I.18, and I.23 shall remain in effect.]
The Registrar may provide a letter to suppliers indicating that the above statement confirms the supplier is certified to ISO 9001:1994 or ISO 9002:1994 until December 15, 2003.
QS-9000:1998 certificates shall not reference ISO 9001:2000. Note: ISO 9001:2000 requires a separate certification.
QS-9000:1998 certificates shall not show an ending date later than December 14, 2006. Note: the current version of QS-9000 (TE supplement) and the current version of the semi-conductor supplement to QS-9000 shall also remain in effect until December 14, 2006.
Tom
QS and 9K2K
I have several clients that are currently QS and have non-automotive customers that demand ISO. For these clients I suggest upgrading the ISO stuff, and still meet all the "shalls" of QS. This is not a big of a task as it seems because QS actually complements 9K2K. As Tom mentioned it would result in two separate certificates.
BTW, not all QS companies will be able to upgrade to TS, so 9K2K may be the better choice.
T ISO 9000 and 14000 Companies - Standards Based Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9000 - Based on 8 management principles - What are they? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Laboratory Capabality Verification based upon QS-9000 Third Edition QS-9000 - American Automotive Manufacturers Standard 13
I ISO 9000 Where to Start ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 81
D Deltas ISO9001 to TL 9000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Sidney Vianna Informational Changes to Terms and Definitions in ISO/TC 176 Standards since ISO 9000:2015 was issued. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
Q Choosing between ISO 9001 (2015) & TL 9000 certifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
qualprod In ISO 9000, Standard vocabulary - Competitors , interested parties? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Happy 30th Birthday, ISO 9000! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO 9000 Standard "standard" definition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M What is the difference between ISO 9000 and ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J QS 9000 Internal Audit Booklet required Internal Auditing 2
Q TL 9000 Measurement Requirements TL 9000 Telecommunications Standard and QuEST 3
Q TL 9000 8.4.V.1 Quality Manual in a Service Company Service Industry Specific Topics 3
T Where to purchase ISO 9001:2008 and ISO 9000:2005? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W QS 9000 to TS 16949 Transition Questions IATF 16949 - Automotive Quality Systems Standard 1
M ISO 9000 World Conference and Draft changes to new revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Moving steps from ISO 9001 to TL 9000 TL 9000 Telecommunications Standard and QuEST 4
I ISO 9000 series, 13485:2003, 15378:2006 - Small Compounding Pharmacy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S TL 9000 Certified Companies - REMINDER - TL 5.0 Measurements Effectivity - July 2013 TL 9000 Telecommunications Standard and QuEST 1
O ISO 9000 section 7.2.1(c) Compliance help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Exploding the Myths Surrounding ISO 9000: A Practical Implementation Guide Book, Video, Blog and Web Site Reviews and Recommendations 28
Q How to correlate the 8 Quality Management Principles to ISO 9000 standards ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Quality Software TQS-9000 Family of Products Quality Manager and Management Related Issues 3
R Is ISO 9001 a prerequisite to TL 9000 certification? TL 9000 Telecommunications Standard and QuEST 5
optomist1 ISO 9001 vs TL 9000 - Looking for a comparison matrix Other ISO and International Standards and European Regulations 3
Q ISO 9000 Conference Istanbul-Turkey - Looking for Speakers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S New to ISO/TS16949 - Our QS-9000 certification has expired IATF 16949 - Automotive Quality Systems Standard 3
D TL 9000 Lead Auditor Training & Certification TL 9000 Telecommunications Standard and QuEST 1
M PS 9000:2001 significance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M PS 9000: 2001 - What are the Salient Features Various Other Specifications, Standards, and related Requirements 4
Project Man What is the most current ISO 9000 standard? I heard there is an ISO 9100 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M "ISO 9000 Quality Systems Handbook" by David Hoyle Book, Video, Blog and Web Site Reviews and Recommendations 24
N How does a company determine what ISO standard (9000 or 9001) to register to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Full Job Description and Responsibilities in ISO 9000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Documents required to display/keep during ISO 9000 Audit in EPCC firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
K Developing an TL 9000 Audit Checklist - Help required TL 9000 Telecommunications Standard and QuEST 2
apestate Question on wording in DOD RFQ regarding ISO 9000 Various Other Specifications, Standards, and related Requirements 7
T TS 16949 Continual Improvement Requirements vs. QS-9000 Requirements IATF 16949 - Automotive Quality Systems Standard 16
R New 13485 Registration questions - Currently registered to ISO 9001 and TL 9000 ISO 13485:2016 - Medical Device Quality Management Systems 2
L Copies of ISO 9000:2005 and ISO 9004:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna The ISO 9000 ecosystem - a clear(?) vision for the future of the ISO 9000 family ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T ISO 9000 / Lean Six Sigma Survey - University Study - Seeking Respondents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Sidney Vianna I Married a Monster from ISO 9000 Coffee Break and Water Cooler Discussions 2
Scott Catron Dilbert and ISO 9000 Funny Stuff - Jokes and Humour 0
V Opinions of those who have used/read David Hoyle's ISO 9000 Handbook Book, Video, Blog and Web Site Reviews and Recommendations 2
M ISO 9000/Lean Six Sigma Conference - Orlando March 2010 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Changes I have to make in the QMS - ISO 9000:2000 to ISO 9000:2008 Software Quality Assurance 4
T STR-ISO 9000 - "Super ISO' audit that the Navy performs every 3 years Various Other Specifications, Standards, and related Requirements 11
