QS-9000 Element 4.10.5
jcricehf
:confused: If a procedure states that a sign-off on a job operation is the quality record that identifies whether product passed or failed. Can we cease collecting in-process inspection results, provided the control plan does not state that we are recording results?
My interpretation of 4.10.5 is that we must record the results of these individual in-process inspections. The QS-9000 Revision 3 states that (paraphrase) " the supplier must show clearly whether the product passed or failed the inspection or test". A single sign-off on an operation does not "clearly show" whether any particular sample in any individual periodic inspection "passed or failed the inspection or test". :frust:
Maybe I need to clarify my point. If our control plans state that 5 samples are to be taken every hour, are we not required by the QS-9000 standard to provide documentation of the results of the inspection of those 5 samples for each hourly inspection? The standard (QS-9000) supersedes any procedure, work instruction, or control plan specified documentation of inspection results. If this is not the case, where does one acquire the data to establish process cycles for preventive adjustment of the process?:bonk:
D.Scott
Hi jcricehf
Welcome to the Cove.
If your procedure states that it is the quality record that identifies pass/fail, then why would it not be clear?
You need to show that all of the inspections/tests required in your process are done and that they pass (or fail). If you state that is how you will verify and document it, why would it be challenged?
I may be missing something but it sounds like you are doing fine.
An afterthought would be that if your sign-off documents a pass/fail, it may be argued that you would have to state which it was (pass or fail) when you sign-off. To fix that I would state that the sign-off was to identify pass only. Failures would require some other action than the sign-off (we would use a nonconformance report form and isolate the parts for disposition).
Dave
jcricehf
D.Scott
I think I see what you are doing. 5 samples every hour - tested - not recorded. Your sign off is at the end of the job and includes all the processing and tests/inspections.
In that case, I think you will need to have a sign-off for each set of samples (the individual results would seem redundant if the sign-off was for "pass") showing that it was done and the result. QS-9000 does require you to clearly show the result (pass/fail, not to be confused with a numerical result).
Next point is where would you get your data? The best case for me would be to chart the hourly samples and use the collected data for process analysis. If your hourly tests require any kind of computer input, it may be possible to save the data for analysis and it would double as documentation of the result.
Am I getting any closer to making sense for you? If not, keep posting - we will get there eventually and I'm sure others will jump in once we paint a clear picture.
Dave
J Do I have to write a procedure for every element in QS-9000? QS-9000 - American Automotive Manufacturers Standard 13
J QS 9000 Element 4.15 ( 4.15.6.4 Shipment Notification System) QS-9000 - American Automotive Manufacturers Standard 2
J TL 9000 - Element 4.9 Significant Change TL 9000 Telecommunications Standard and QuEST 6
M Record Retention - QS-9000 Element 4.5 Records and Data - Quality, Legal and Other Evidence 7
B Element 4.1.8 of Ford's MS-9000 requires a system of house keeping Customer and Company Specific Requirements 4
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
Q Choosing between ISO 9001 (2015) & TL 9000 certifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
qualprod In ISO 9000, Standard vocabulary - Competitors , interested parties? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Happy 30th Birthday, ISO 9000! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO 9000 Standard "standard" definition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M What is the difference between ISO 9000 and ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J QS 9000 Internal Audit Booklet required Internal Auditing 2
Q TL 9000 Measurement Requirements TL 9000 Telecommunications Standard and QuEST 3
Q TL 9000 8.4.V.1 Quality Manual in a Service Company Service Industry Specific Topics 3
T Where to purchase ISO 9001:2008 and ISO 9000:2005? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W QS 9000 to TS 16949 Transition Questions IATF 16949 - Automotive Quality Systems Standard 1
M ISO 9000 World Conference and Draft changes to new revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Moving steps from ISO 9001 to TL 9000 TL 9000 Telecommunications Standard and QuEST 4
I ISO 9000 series, 13485:2003, 15378:2006 - Small Compounding Pharmacy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S TL 9000 Certified Companies - REMINDER - TL 5.0 Measurements Effectivity - July 2013 TL 9000 Telecommunications Standard and QuEST 1
O ISO 9000 section 7.2.1(c) Compliance help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Exploding the Myths Surrounding ISO 9000: A Practical Implementation Guide Book, Video, Blog and Web Site Reviews and Recommendations 28
Q How to correlate the 8 Quality Management Principles to ISO 9000 standards ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Quality Software TQS-9000 Family of Products Quality Manager and Management Related Issues 3
R Is ISO 9001 a prerequisite to TL 9000 certification? TL 9000 Telecommunications Standard and QuEST 5
optomist1 ISO 9001 vs TL 9000 - Looking for a comparison matrix Other ISO and International Standards and European Regulations 3
Q ISO 9000 Conference Istanbul-Turkey - Looking for Speakers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S New to ISO/TS16949 - Our QS-9000 certification has expired IATF 16949 - Automotive Quality Systems Standard 3
D TL 9000 Lead Auditor Training & Certification TL 9000 Telecommunications Standard and QuEST 1
M PS 9000:2001 significance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M PS 9000: 2001 - What are the Salient Features Various Other Specifications, Standards, and related Requirements 4
Project Man What is the most current ISO 9000 standard? I heard there is an ISO 9100 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M "ISO 9000 Quality Systems Handbook" by David Hoyle Book, Video, Blog and Web Site Reviews and Recommendations 24
N How does a company determine what ISO standard (9000 or 9001) to register to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Full Job Description and Responsibilities in ISO 9000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Documents required to display/keep during ISO 9000 Audit in EPCC firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
K Developing an TL 9000 Audit Checklist - Help required TL 9000 Telecommunications Standard and QuEST 2
apestate Question on wording in DOD RFQ regarding ISO 9000 Various Other Specifications, Standards, and related Requirements 7
T TS 16949 Continual Improvement Requirements vs. QS-9000 Requirements IATF 16949 - Automotive Quality Systems Standard 16
R New 13485 Registration questions - Currently registered to ISO 9001 and TL 9000 ISO 13485:2016 - Medical Device Quality Management Systems 2
L Copies of ISO 9000:2005 and ISO 9004:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna The ISO 9000 ecosystem - a clear(?) vision for the future of the ISO 9000 family ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T ISO 9000 / Lean Six Sigma Survey - University Study - Seeking Respondents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Sidney Vianna I Married a Monster from ISO 9000 Coffee Break and Water Cooler Discussions 2
Scott Catron Dilbert and ISO 9000 Funny Stuff - Jokes and Humour 0
V Opinions of those who have used/read David Hoyle's ISO 9000 Handbook Book, Video, Blog and Web Site Reviews and Recommendations 2
M ISO 9000/Lean Six Sigma Conference - Orlando March 2010 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Changes I have to make in the QMS - ISO 9000:2000 to ISO 9000:2008 Software Quality Assurance 4
T STR-ISO 9000 - "Super ISO' audit that the Navy performs every 3 years Various Other Specifications, Standards, and related Requirements 11
N TL 9000 Starter - Please let me know if anyone has worked on TL 9000 Software Quality Assurance 1
