QS9000 Tier 2 for 12 Years - Transitioning to ISO9001 - Where do I start?
qcman
Registered Visitor
We are a tier2 and have been QS9000 for at least 12 years now and are going ISO.It's our hope that we can drop a lot of the unnecessary things we have in our otherwise good system during the switch. I know this is a broad question but where does one start on a task like this? Time is a big factor since we need to rewrite the manual,do an internal audit and get certified by 10/15/06 - yes - 10/15/06
It' not simply a case of dropping the unnecessary things, it's more a case of what's been added or changed and having time to show they're effective. What's so special about the deadline?
Unless you had a pretty effective qms in place under QS-9000, it's not likely you will be able to make the change over. It's more complex than simply re-writing the manual and doing a bunch of audits. A significant change is Management Review - what did you do before? Did you review progress to objectives etc? How long ago was your last review? I'd have to say that it's a practical impossibility to get there from here, even with an army.
Your best hope is to contact your registrar and postpone the visit until later this year. You might get something audit-worthy in two months. Even so, you should expect a hit with a number of nc's just because it takes time to show effectiveness. Sorry to be blunt, but I'm afraid it's not going to be very likely without getting a 'bloody nose' at the audit.............
Anyone got a different idea?..........
Andy
jeffrey_Chang
Hi QCMan,
If you are already in compliance to QS9000 for 12 over years and to do a switch over to ISO9000, I don't foresee that a drastic change is needed here. For a start, I would recommend you to perform a gap analysis of your system so as to assess what are the gaps in the current system that are missing in order to comply to ISO9000. Then you will know better how much work more is needed to be in compliance. With that, you will be able to estimate the resources needed to patch up the system.
BTW, are you already familiar with ISO9000 requirements, if not, you would need training and if you have the budget, then you might want to consider a consultant.
Out of curiosity, why do you want to comply with ISO9000 instead of TS16949.
thks.
jeffrey.
Hi QCMan,
There is a fundamental difference here - ISO9K2K is about 'processes' and not 'procedure' for each requirement. The processes have to be measured against objectives. This wasn't a requirement of QS-9000. Don't forget that TC 176 recommended organizations have 3 years to make the transition. Yes, QS had more in common with the the 2000 version, e.g conti uous improvement, but what about competencies, process measurement, management commitment etc, etc.......These are not likely to be able to be made robust enough to pass an audit in a few days.......
Oh, and you're right about getting training too....
Andy
jeffrey_Chang
Hi Andy,
Thks for the info.
However, my previous company was once upon a time in compliance to
ISO9000-1994. The company then get themselves converted to QS 9000 and was certified to it.
Later, we switched over to TS16949 and was certified.
If I'm correct, TS16949 baseline its requirement to ISO9000-2000 with the automotive industry specific requirements. Pls bear with me, I'm not an expert in this subject matter.
However, the transition from QS9000 to TS16949 in conjunction with ISO9000-2000 was surprisingly not a drastic change for us. True enough it don't take a few days to get the system in compliance, maybe weeks but the overall changes impact was not really such a big deal.
thks.
jeffrey.
P
potdar
Get yourself a good consultant. Today. And start working. Dont waste a minute reading my next sentence.
qcman
Registered Visitor
Cost is the time factor here since switching certs is cheaper than recert so I'm told. The powers to be have decided ISO is what we need so we have no input there. The QS system we have in place is pretty good and we have always done good as far as audits go.
Martijn
If I understand the situation correctly you're planning a move from a procedure QMS to a process oriented QMS a la ISO 9001:2000. Here's one big tip (I've been there myself a few times).
Start from scratch, define the processes, then look at the ISO 9001 requirements concerning that process, take the parts from the old procedures that are still required by the ISO 9001, fit them in, throw the rest out.
Rewriting existing material that was written in a different mind set will give you much more work, and you will most definitely regret it once you're done.
Good luck!
Coury Ferguson
Moderator here to help
Andy
Fundamentally yes. But the TS requirement was based upon ISO9001:2000, but added "customer specifics" I believe. So, would not having a system that has complied with TS meet the ISO9001:2000 requirements? It would allow the transitioning time from the TS to ISO9001:2000, and in my opinion wouldn't require a change in the timing of the audit. :notme:
qcman
Registered Visitor
I see I typed the wrong date of cert, it should read 12-15-06. Re-writing the manual does make more sense so we will most likely go that route.I have a question on control plans if someone can answer it. Currently we have at least a few thousand control plans ( one for every part number) and electronic routing with both having almost identical information. To stream line the system we are considering dropping control plans and use the e-routing which has the ability to show everything the control plans do. So my question is under ISO can we use a cutoff point where we stop using CP and use e-routing only? Once we start doing this we will start working backward through old CP converting them to e-routing as time permits.
S Was QS9000 replaced by ISO/TS 16949 since December 2006? Document Control Systems, Procedures, Forms and Templates 4
M Where can I buy a copy of the QS9000 standard? QS-9000 - American Automotive Manufacturers Standard 16
P ISO/TS16949 Lead Auditor requirements - Transitioning from QS9000 to ISO/TS16949 General Auditing Discussions 6
I AS9100 vs. QS9000 vs. ISO-TS16949 - Similarities and Differences AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L 7.3 excluded from Scope in QS9000, back in TS16949? IATF 16949 - Automotive Quality Systems Standard 1
B Converting from QS9000 to TS 16949 ... HOW? WHO? HOW MUCH? IATF 16949 - Automotive Quality Systems Standard 2
S TS16949 - QS9000 Gap Analysis and comparison matrix IATF 16949 - Automotive Quality Systems Standard 10
Q Promoted to "Maintenance Manager - What should I expect in an ISO / QS9000 audit? QS-9000 - American Automotive Manufacturers Standard 6
B Does anyone have a good cross reference from QS9000 to TS16949? IATF 16949 - Automotive Quality Systems Standard 2
Z ISO / TS16949 Quality Manual needed - Changing from QS9000 to ISO / TS16949 IATF 16949 - Automotive Quality Systems Standard 17
S SOP Numbering - About to change over from QS9000 to ISO 9001 Document Control Systems, Procedures, Forms and Templates 13
J Getting Rid of QS9000 Procedures that are no longer necessary with TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
C QS9000 TE vs. TS16949 - Registration Applicability and Requirements Conflicts IATF 16949 - Automotive Quality Systems Standard 3
Manix Template of Supplement K from the QS9000 APQP manual APQP and PPAP 11
T qs9000 standard QS-9000 - American Automotive Manufacturers Standard 2
B TS 16949 Implementation - Upgrade from QS9000 - What are the Steps? IATF 16949 - Automotive Quality Systems Standard 1
M Advertising - Trucks with ISO9002, TS16949, ISO14001, & QS9000 written on them IATF 16949 - Automotive Quality Systems Standard 2
M ISO 9001 vs. QS9000 vs. ISO 14001 - Job interview tomorrow night for a QM position Career and Occupation Discussions 4
K The "Shalls" of QS9000 T&E Supplement QS-9000 - American Automotive Manufacturers Standard 4
J QS9000 Management Review - Review every section and sub-section of the manual? Management Review Meetings and related Processes 3
J Powerway Software - We are moving from QS9000 to TS 16949 Quality Assurance and Compliance Software Tools and Solutions 2
S QS9000 to TS16949 Transition - How difficult was it, REALLY?? QS-9000 - American Automotive Manufacturers Standard 4
Raffy ISO9001:2000 Transition from QS9000 - Or Both? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Raffy Training to QS9000 QS-9000 - American Automotive Manufacturers Standard 1
S TS16949 Prerequisite - An organization must already be QS9000 certified? QS-9000 - American Automotive Manufacturers Standard 19
Y QS9000 officially obsolete and replace by TS 16949? QS-9000 - American Automotive Manufacturers Standard 3
J Big 3 can hold your QS9000 registration hostage! QS-9000 - American Automotive Manufacturers Standard 22
R QS9000 Software - Has anyone heard about QSP a UK Package QS-9000 - American Automotive Manufacturers Standard 0
A ISO 9001:2000 Vs QS9000 QS-9000 - American Automotive Manufacturers Standard 0
M Six Sigma - Las similitudes entre six sigma y qs9000 Six Sigma 2
R Writing QM for QS9000 & ISO9K2K QS-9000 - American Automotive Manufacturers Standard 5
P QS9000 manuals revision outdated QS-9000 - American Automotive Manufacturers Standard 7
H FMEA Comparison QS9000 and VDA 4.2 FMEA and Control Plans 2
R Ford, QOS and QS9000 QS-9000 - American Automotive Manufacturers Standard 3
S iso 9001/qs9000/iso14001 QS-9000 - American Automotive Manufacturers Standard 2
C QS9000:1998 TO ISO 9001:2000 + ISO-TS 16949:2002 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J QS9000 supplier reqts Supplier Quality Assurance and other Supplier Issues 3
B Product ID, Inspection and Test Status, - QS9000 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M QS9000 to TS16949 QS-9000 - American Automotive Manufacturers Standard 11
J Calibration lab reqts for QS9000 (TS also?) QS-9000 - American Automotive Manufacturers Standard 2
D QS9000 "compliant" QS-9000 - American Automotive Manufacturers Standard 5
W SPC all the time? Does QS9000 require statistical control on all processes? QS-9000 - American Automotive Manufacturers Standard 3
D Red, Yellow, and Green and QS9000 Suppliers - Visual evaluation of the status QS-9000 - American Automotive Manufacturers Standard 2
M Sample Business Plans meeting QS9000 Requirements QS-9000 - American Automotive Manufacturers Standard 5
R Simplest way to make transition Iso 9001 ->QS9000 QS-9000 - American Automotive Manufacturers Standard 1
Kevin Mader QS9000 Video QS-9000 - American Automotive Manufacturers Standard 4
D QS9000 - Changes in personel requirements to match the job description QS-9000 - American Automotive Manufacturers Standard 5
Casana QS9000 vs. TL9000 - What are the differences? TL 9000 Telecommunications Standard and QuEST 4
J Differences between VDA6.1 and VDA6.2 vs. QS9000 VDA Standards - Germany's Automotive Standards 6
S What are the differences between TS16949 and QS9000? QS-9000 - American Automotive Manufacturers Standard 3
