QS9000 Tier 2 for 12 Years - Transitioning to ISO9001 - Where do I start?
Coury Ferguson
Moderator here to help
#11
I see I typed the wrong date of cert, it should read 12-15-06. Re-writing the manual does make more sense so we will most likely go that route.I have a question on control plans if someone can answer it. Currently we have at least a few thousand control plans ( one for every part number) and electronic routing with both having almost identical information. To stream line the system we are considering dropping control plans and use the e-routing which has the ability to show everything the control plans do. So my question is under ISO can we use a cutoff point where we stop using CP and use e-routing only? Once we start doing this we will start working backward through old CP converting them to e-routing as time permits.
ISO9001:2000 does not require "Control Plans" that is a TS specific requirement. So eliminating "Control Plans" would reduce costs based upon updating as the changes occur.
There is nothing wrong with using Control Plans even though it isn't required by ISO9001:2000. You may want to review the existing Control Plans and see if they are still needed to control the critical processes, in my opinion.
#12
Even if you were still under the automotive requirements, if your router does indeed include all of the control plan form information, you wouldn't have to use the AIAG control plan form unless there were a customer-specific requirement to do so. The AIAG APQP manual, (Feb 1995), page 33 says:
The intent of the control plan form...is to provide an example of how this information can be documented. An alternate format may be used as long as it contains the same information, as minimum.
Remember, the control plan isn't the form, it's the contents of the form.
V
Valeri
#13
Here is a TS vs QS matrix I did several years ago. Maybe it will help get started. We had no trouble transitioning to TS as we had a good system under the QS umbrella; just added the additional requirements, some process maps and performed audits via "process" auditing - was not a big deal.
If I remember correctly, and don't hold me to this :nope:, the red in the matrix are new requirements, the blue indicates QS difference. Lines 233 and below are not identified in the TS standard.
qcman
Registered Visitor
#15
Thank you for the matrix.I have been looking over the one in the AIAG implementation guide. I was unaware till this afternoon that do have certain customers who requirer the use of the AIAG control plan form. We can however streamline the current CP's we use. Main reason I wanted to drop the current CP's is they do not allow global changes to be made on one document. In some cases I would need to change 500+ CP's to stay compliant to QS.
Coury Ferguson
#16
If you can streamline your Control Plans, you have already improved the QMS. You seem to be on the right track.
Helmut Jilling
Auditor / Consultant
#17
Remember, if you are doing automotive parts, the requirement is to become certified to ISO and COMPLIANT to TS. Control plans and FMEAs would likely still be required by the automotive customer.
Helmut Jilling
#18
The best way to tart, in my opinion, is by defining the processes and the items described in cl 4.1. Fill in the procedures and stuff later in the process.
ISO and TS focus is on the processes, not the procedures.
qcman
Registered Visitor
#19
It is my understanding tier2's do not *have* to be TS compliant per an ISO instructor at the local collage.If someone knows this to be incorrect please speak up. Our customers know we are going ISO and have not indicated to us we need to be TS compliant. Lets say after we are ISO certified we find we do need to be TS compliant will our QMS have to include TS language or can we just prove we are compliant? BTW :thanx: all for the input you have given.
Helmut Jilling
#20
Well, let's see...The standard states (7.4.1.2) that the goal is "supplier conformity with this Technical Specification...and an "instructor at a local college" says it is not required....ummm, let's see...I think my money is on the Standard! :notme:
S Was QS9000 replaced by ISO/TS 16949 since December 2006? Document Control Systems, Procedures, Forms and Templates 4
M Where can I buy a copy of the QS9000 standard? QS-9000 - American Automotive Manufacturers Standard 16
P ISO/TS16949 Lead Auditor requirements - Transitioning from QS9000 to ISO/TS16949 General Auditing Discussions 6
I AS9100 vs. QS9000 vs. ISO-TS16949 - Similarities and Differences AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L 7.3 excluded from Scope in QS9000, back in TS16949? IATF 16949 - Automotive Quality Systems Standard 1
B Converting from QS9000 to TS 16949 ... HOW? WHO? HOW MUCH? IATF 16949 - Automotive Quality Systems Standard 2
S TS16949 - QS9000 Gap Analysis and comparison matrix IATF 16949 - Automotive Quality Systems Standard 10
Q Promoted to "Maintenance Manager - What should I expect in an ISO / QS9000 audit? QS-9000 - American Automotive Manufacturers Standard 6
B Does anyone have a good cross reference from QS9000 to TS16949? IATF 16949 - Automotive Quality Systems Standard 2
Z ISO / TS16949 Quality Manual needed - Changing from QS9000 to ISO / TS16949 IATF 16949 - Automotive Quality Systems Standard 17
S SOP Numbering - About to change over from QS9000 to ISO 9001 Document Control Systems, Procedures, Forms and Templates 13
J Getting Rid of QS9000 Procedures that are no longer necessary with TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
C QS9000 TE vs. TS16949 - Registration Applicability and Requirements Conflicts IATF 16949 - Automotive Quality Systems Standard 3
Manix Template of Supplement K from the QS9000 APQP manual APQP and PPAP 11
T qs9000 standard QS-9000 - American Automotive Manufacturers Standard 2
B TS 16949 Implementation - Upgrade from QS9000 - What are the Steps? IATF 16949 - Automotive Quality Systems Standard 1
M Advertising - Trucks with ISO9002, TS16949, ISO14001, & QS9000 written on them IATF 16949 - Automotive Quality Systems Standard 2
M ISO 9001 vs. QS9000 vs. ISO 14001 - Job interview tomorrow night for a QM position Career and Occupation Discussions 4
K The "Shalls" of QS9000 T&E Supplement QS-9000 - American Automotive Manufacturers Standard 4
J QS9000 Management Review - Review every section and sub-section of the manual? Management Review Meetings and related Processes 3
J Powerway Software - We are moving from QS9000 to TS 16949 Quality Assurance and Compliance Software Tools and Solutions 2
S QS9000 to TS16949 Transition - How difficult was it, REALLY?? QS-9000 - American Automotive Manufacturers Standard 4
Raffy ISO9001:2000 Transition from QS9000 - Or Both? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Raffy Training to QS9000 QS-9000 - American Automotive Manufacturers Standard 1
S TS16949 Prerequisite - An organization must already be QS9000 certified? QS-9000 - American Automotive Manufacturers Standard 19
Y QS9000 officially obsolete and replace by TS 16949? QS-9000 - American Automotive Manufacturers Standard 3
J Big 3 can hold your QS9000 registration hostage! QS-9000 - American Automotive Manufacturers Standard 22
R QS9000 Software - Has anyone heard about QSP a UK Package QS-9000 - American Automotive Manufacturers Standard 0
A ISO 9001:2000 Vs QS9000 QS-9000 - American Automotive Manufacturers Standard 0
M Six Sigma - Las similitudes entre six sigma y qs9000 Six Sigma 2
R Writing QM for QS9000 & ISO9K2K QS-9000 - American Automotive Manufacturers Standard 5
P QS9000 manuals revision outdated QS-9000 - American Automotive Manufacturers Standard 7
H FMEA Comparison QS9000 and VDA 4.2 FMEA and Control Plans 2
R Ford, QOS and QS9000 QS-9000 - American Automotive Manufacturers Standard 3
S iso 9001/qs9000/iso14001 QS-9000 - American Automotive Manufacturers Standard 2
C QS9000:1998 TO ISO 9001:2000 + ISO-TS 16949:2002 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J QS9000 supplier reqts Supplier Quality Assurance and other Supplier Issues 3
B Product ID, Inspection and Test Status, - QS9000 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M QS9000 to TS16949 QS-9000 - American Automotive Manufacturers Standard 11
J Calibration lab reqts for QS9000 (TS also?) QS-9000 - American Automotive Manufacturers Standard 2
D QS9000 "compliant" QS-9000 - American Automotive Manufacturers Standard 5
W SPC all the time? Does QS9000 require statistical control on all processes? QS-9000 - American Automotive Manufacturers Standard 3
D Red, Yellow, and Green and QS9000 Suppliers - Visual evaluation of the status QS-9000 - American Automotive Manufacturers Standard 2
M Sample Business Plans meeting QS9000 Requirements QS-9000 - American Automotive Manufacturers Standard 5
R Simplest way to make transition Iso 9001 ->QS9000 QS-9000 - American Automotive Manufacturers Standard 1
Kevin Mader QS9000 Video QS-9000 - American Automotive Manufacturers Standard 4
D QS9000 - Changes in personel requirements to match the job description QS-9000 - American Automotive Manufacturers Standard 5
Casana QS9000 vs. TL9000 - What are the differences? TL 9000 Telecommunications Standard and QuEST 4
J Differences between VDA6.1 and VDA6.2 vs. QS9000 VDA Standards - Germany's Automotive Standards 6
S What are the differences between TS16949 and QS9000? QS-9000 - American Automotive Manufacturers Standard 3
