QSR 820.120 labeling and packaging control
celia4237
QSR820 has a special requirement about the labeling and the packaging control, that is, the requirement about the label integrity, label inspection, label storage and label operation.
I think ISO13485 does not have a clear requirement about this, and QSR820 require us to establish a labeling and packaging control procedure.
Is there anyone who can give me a template of the labeling and packaging control procedure? I really get no idea about this procedure.
Chris Ford
Re: QSR820.120 labeling and packaging control
Hi Celia,
This is another area that's highly dependent on your device classification and level of concern.
What kind of device is this for?
celia4237
It is a Blood pressure monitor.
Could you give me some suggestions about how to establish the labeling and packaging procedure?
Chris Ford
Hi Celia,
First, consider labels and labeling, and packaging the same as any other component for the device - they're subject to your design control system. In other words, include your labeling requirements in your requirements documents, create specifications for them, validate them, etc.
There are general and specific requirements for the information FDA expects to see on packaging and labeling under 21CFR801. In general, FDA requires much of the same information as other countries... name of business, location, intended use, instructions for use, etc. are required for all devices.
See also http://www.fda.gov/cdrh/devadvice/331.html
Also consider the required labeling for your device. A Blood Pressure monitor is an over the counter (non-prescription) device. There are specific labeling requirements for OTC devices. If the device has been cleared on a 510(K), your labeling statements have already been reviewed by FDA when you submitted your 510(K), but be sure that your packaging is designed to meet the requirements at 21CFR801.60, 801.61 and 801.62.
See also http://www.fda.gov/cdrh/devadvice/3311.html
Then, you need to control packaging and labeling operations in production. I asked what kind of device you were dealing with to determine the level of control you'd want for your packaging / labeling operations. I've worked at companies that controlled labeling like Fort Knox, where other companies didn't need the same stringent controls.
Your procedures for control of packaging and labeling should be appropriate for your device.
Labeling in manufacturing operations extends beyond the labels that go onto your device. Labeling will include ID tags, and labels on equipment, and any labeling used in the manufacturing of the device as well as on the device itself. You don't need to go crazy developing a master labeling control plan for your type of device, but you need to make sure that labels are designed appropriately for the device and in accordance with the requirements above, and that they are inventory controlled (e.g. issued and tracked through production).
You'll want to establish labeling review and approval requirements, and address things such as incoming inspection, proper application, over-labeling, etc.
In your case, I would suggest paying closer attention to how labels/labeling are designed, and how they're reviewed / approved, and inspected, but you need to control labeling activities throughout the organization. Something like this:
  • Include labeling design requirements in your design control system. You should have some general labeling requirements written into your system. (e.g. labels shall be designed to remain legible for the life of the product.... etc.)
  • Include labeling changes in your document control system (some companies create a separate doc control just for labels)
  • Make sure that Regulatory Affairs is included in the review and approval of labeling
  • Establish inspection requirements for first articles and incoming inspection. This can be done as a separate labeling inspection procedure, or by your general inspection procedure with your typical sampling plans and inspection criteria. Make sure you include proof reading as part of your incoming inspection. This can be done with transparancies or actual proof-read
  • Make sure your inventory control procedures - storage / handling, etc. include instructions for the storage of labeling. If you have pre-printed serial numbers or lot numbers for the wrap on labels, describe how they will be issued.
  • Part of your normal manufacturing process most-likely already includes the application of labeling. If not... be sure that it does.
  • Your calibration system should include requirements defining how your calibrated equipment is labeled.
  • If you use status labeling through inventory control and manufacturing, you'll need to define the labeling in your procedures. You'll use the same controls for status labeling that you'd use for device labeling. In other words, status labels (e.g. accepted, rejected, pass, fail, etc) should be designed to be legible, remain affixed, and perform as intended. Maintain the same controls relative to over-labeling, destruction of labels, etc. that you would for your device labeling.
  • Make sure your rework procedures address how labels are handled. If they have to be removed and replace, what's your policy?
  • Make sure your nonconforming material system addresses how labels will be handled if they are scrapped. What steps will you take to prevent the possible mis-use of rejected / scrapped labels? How will labels be segregated to prevent mis-use? If scrapped, how will they be discarded? They should be somehow obliterated or destroyed to prevent any possibility of misuse.
I may have missed some points here... This is off the top of my head, and as you can see will vary from company to company. The one thing to keep in mind is that with a device like yours, the design and content of the labels, and how you control rejects is more important than controlling the quantity issued. Some companies need to control labels so stringently, they keep them locked in separate inventory cages within secured warehouses. Then when they issue them, they're double-counted and countersigned. You wouldn't need to do anything like that. Again, it's all very specific to the type of device you're manufacturing. Focus on making sure you show strength in design, review / approval, handling changes, incoming inspection, and a little emphasis on scrapped labels. The rest you can handle like any other inventory really.
A really great explanation of the quality system requirements for labeling can be found here: http://www.fda.gov/cdrh/devadvice/334.html
I hope I didn't confuse matters more for you. Read the links, and I'm sure you'll get a better picture of this. Be sure to consult with your regulatory affairs manager, though. That person is a significant stakeholder in all things related to labeling.
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
B Classes/ Online Training on ISO 13485:2016 and FDA QSR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 5
Y ISO 13485:2003 &FDA QSR (21 CFR 820) Quality Manual,34 Procedures and Form Book, Video, Blog and Web Site Reviews and Recommendations 8
shimonv Classification of Complaints from Beta Sites - Complaints Definition per QSR 820.3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
T Can I approve my own Documentation per FDA QSR 21 CFR Part 820? ISO 13485:2016 - Medical Device Quality Management Systems 1
S OEM Supplier of Accessories Registration and 21 CFR 820 QSR Controls Applicability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
G Understanding Identification of Design in QSR 21 CRF Part 820.30 Design Control (f) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Does any one have FDA 21 CFR Part 820 QSR training material? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
G Legacy Product - Do we need follow QSR 820? Design Verification and Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
W Injection Molding Validation Required or Not - FDA QSR 820.75 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
A QSR (820.30 part e) Design Review and Design Control Responsibilities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S FDA 21 CFR 820 QSR Quality Manual example wanted 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W What is "Design Input" by QSR, 21 CFR Part 820 ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
C Definition Design Transfer - New requirement of QSR 820 - What is Design Transfer? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
S 21 CFR 820 QSR 820.25 Statistical Techniques Procedures Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
J ISO 13485 vs. FDA QSR (21 CFR Part 820) - Differences - Includes Spreadsheets ISO 13485:2016 - Medical Device Quality Management Systems 64
M Purchasing Procedure - QSR ?820.50 and ISO 9001:1994 Clause 4.6 ISO 13485:2016 - Medical Device Quality Management Systems 3
M Informational From Medtech Insight – QSR/ISO 13485 Harmonization Update: FDA Enforcement Discretion Likely When New Rule Stands Up; Draft Reg Coming By Year’s End; Medical Device and FDA Regulations and Standards News 0
D FDA QSR task checklist based on inspection citations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Supplier Evaluation - Is a supplier score card a requirement under ISO and QSR? ISO 13485:2016 - Medical Device Quality Management Systems 7
V QMS / QSR - Reference to Framework - Templates - Procedures for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
A How to obtain Preamble to Quality System Regulation (QSR) ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P FDA QSR Inspection Consultant Recommendations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H USFDA -QSR Audit Check List 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
I Recording of In Process Data to Meet FDA QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A How many processes for an FDA Quality System (QSR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
P What's the difference between ISO13485 and FDA/QSR? ISO 13485:2016 - Medical Device Quality Management Systems 16
D Off-the-shelf SW S.O.P. for non-product QSR regulated and non-regulated applications IT (Information Technology) Service Management 6
Q How Demings Point 9 (of his 14 points) is related to the FDA QSR Quality Tools, Improvement and Analysis 3
M ISO 13485 and FDA QSR Employee Training Requirements when Procedures are Revised Manufacturing and Related Processes 5
B FDA QSR Data Analysis & Trending Requirements US Food and Drug Administration (FDA) 5
A Purchasing Information Requirements - ISO 13485 Clause 7.4.2 and FDA QSR Supplier Quality Assurance and other Supplier Issues 2
W Auditing to multiple standards & requirements - CMDR, MDD, ISO13485, QSR. General Auditing Discussions 3
Q ISO 13485, FDA's QSR, CMDR, MDD: Seeking Internal Audit Correlation Matrix Various Other Specifications, Standards, and related Requirements 3
M FDA QSR Requirements - Checklist for Class II Medical Device Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D How to Measure QSR Training Effectiveness? Training - Internal, External, Online and Distance Learning 6
M Practical Reasons Behind The ISO 13485/QSR Regulations ISO 13485:2016 - Medical Device Quality Management Systems 6
C Questions about the "change control procedure" in FDA's QSR manual 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M CLIA vs. QSR Audit Differences - and - Audit templates for CLIA audits ISO 13485:2016 - Medical Device Quality Management Systems 3
D Definition Q - Definitions of all the Q's - QM, QMS, QP, QSR, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 18
T What would the FDA expect to see when they ask for our QSR? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 20
D Administrative personnel training - ISO 13485 and FDA QSR requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
W FDA QSR Inconsistency? Design Validation Design and Development of Products and Processes 17
GStough FDA QSR (Quality System Regulation) Training Needed in the Southeastern USA Training - Internal, External, Online and Distance Learning 7
D Presentation on Subject: Potatoes (QSR interested in the potato market) Misc. Quality Assurance and Business Systems Related Topics 17
H Sample Design Plan that complies with FDA QSR, ISO 13485 & 14971. ISO 14971 - Medical Device Risk Management 5
A Re-manufactured vs. Refurbished under FDA QSR ISO 13485:2016 - Medical Device Quality Management Systems 2
K QSR Sections for a Medical Device - Seven questions ISO 13485:2016 - Medical Device Quality Management Systems 9
C Software recommendations for CAPA that will meet the FDA QSR & Part 11 Quality Assurance and Compliance Software Tools and Solutions 4
