QTC Requirement as per API 6A-21st Edition
Hello All,
Could you please provide the QTC size requirements to be followed for the below case :
Items to be manufactured : Blind Flange 20-3/4" 3K PSL 3 and Spacer Spool 20-3/4" 3K x 20-3/4" 3K PSL 3 (Max OD of equipment will be 33-3/4") For this we shall be using Forged Round Bar with 35" OD. So what should be the QTC requirement in case of Batch Furnace and Continuous Production Furnace.
Also as per Addendum 2 any one can elaborate the requirements listed below (Section 6.4.2.3.2)
EXCEPTION At the manufacturer’s option, a 1 25 mm (5 in. ) ER QTC shall be permitted for parts with an
ER greater than 1 25 mm (5 in. ) provided that:
— design documentation provides the stress distribution and demonstrates that the part meets the design
acceptance criteria of Section 5 where the mechanical properties are lower than the requirements
specified in 6.3 for the QTC;
— a qualification forging or a sacrificial part is used to validate the mechanical properties that satisfy the acceptance criteria of the analysis at a depth of 63 mm (2.5 in.) or T/4, whichever is less, at the critical section(s) as identified by the stress distribution in the design documentation;
— a qualification forging or a sacrificial part is used to document that the part meets the Charpy impact requirements of this specification at a depth of 63 mm (2.5 in.) or T/4 of the critical section(s) of the parts, whichever is less; and
— a qualification forging or a sacrificial part having the same heat-treat geometry, material grade, and heat-treat parameters as defined by the manufacturer is used to qualify all the production parts covered by the analysis.
Thanks in advance.
Regards,
Jay
jmech
If it is heat treated in a continuous furnace, the requirement in 6.4.1 applies: "For material heat-treated in a continuous furnace, the QTC shall consist of a sacrificial production part or a prolongation removed from a production part. The sacrificial production part or prolongation QTC shall qualify only production parts having an identical size and shape." So if you are using heat-treated bar (and not rough-machining and then heat-treating), you have to use a length of the full-size bar as your QTC. If you are rough-machining and then heat-treating, you need to use a rough-machined part of each configuration as a QTC (i.e. test both a rough-machined spool and rough-machined blind flange).
For batch furnace, it is more complicated and the wording has also been revised in Addendum 2. The reason behind the requirement is that 4130 (and similar steels) don't harden to a great depth, so the center of a 35" OD 4130 bar is not accurately represented by a 5"ER QTC and is pretty much guaranteed to be below 75K strength, which could result in a failure if 75K strength is required near the center of the part (and the impact values also tend to be low, which could increase the risk of brittle failure). If any of the following apply, you can use a QTC with a 5" ER (i.e. 4" x 4" x 8" separately forged QTC or 5" trepan):
1. The material is 2 1/4 Cr1Mo or another material other than carbon or low-alloy steel.
2. The required design yield strength is less than 75K. [note that per Table 7, 60K material is allowable for 3000psi-rated bodies, flanged integral end connectors, and blind loose connectors, so this likely applies in your case]
3. The part weight during heat treat is less than 454kg (1000lb).
4. You use the complicated exception.
If none of the above apply, then you are required to use a QTC with at least a 10" ER (i.e. 8" x 8" x 10" separately forged QTC or 10" trepan). Note that you can always use a QTC with a larger ER than these minimums.
The exception is complicated and despite having been involved in drafting it, I'm not sure what it specifically requires when I read it now. The intent of it is that your design documentation needs to show that the part won't be over-stressed even if it has not been effectively through-hardened during heat treating, and that this can justify the use of a 5" ER QTC, but the specific wording of the requirements is unclear.
J NADCAP Root Cause - Misinterpretation of Checklist Requirement Various Other Specifications, Standards, and related Requirements 5
eldercare Multi-Site ISO/AS Certification Requirement for some sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
H FAI Requirement After Moving CNC Machine? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
S Biocompatibility requirement for electrode adapters Other Medical Device Related Standards 1
briteme4 AS9102 FAIR Requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Put on escalation by customer? is there a requirement to notify registrar? IATF 16949 - Automotive Quality Systems Standard 6
E Translation requirement labels EU Medical Device Regulations 4
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
A MDR requirement where unit of use packaging is too small for UDI carrier EU Medical Device Regulations 1
C Requirement for Revision of Standard in all Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K ROHs compliance requirement REACH and RoHS Conversations 1
E Language requirement DoC EU Medical Device Regulations 3
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Requirement for Signature on Document Document Control Systems, Procedures, Forms and Templates 13
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Y 510k requirement for bringing in gloves Medical Device and FDA Regulations and Standards News 0
S PSUR - MDR First Submission Requirement? EU Medical Device Regulations 8
J When PPAPs are not a contractual requirement APQP and PPAP 9
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 10
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Clinical Trial Requirement - No equivalent devices in the market CE Marking (Conformité Européene) / CB Scheme 3
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T ISO 17025: Lockout/Tagout Requirement ISO 17025 related Discussions 1
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
P Regulatory or registration requirement for disinfectant in ASEAN Registrars and Notified Bodies 1
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Stage 2 audit - Requirement for 3 months of records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
I Laboratory Fridge / Freezer Inventory - Requirement(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
