Qualification of sterilization indicators as medical devices with the EU MDR 2017/745
xcanals_tecno-med.es
Dear all
as you know the EU definition of medical device is changed in the MDR 2017/745 and include now "products specifically intended for the cleaning, disinfection or sterilization of devices" as for example sterilizers.
As indicated in the last version of the MANUAL ON BORDERLINE AND CLASSIFICATION version 1.22 (05-2019) for the MDD "these do not fulfil teh definition of medical device or accesory".
Do you think that now does not fulfil the definition of accessory of a STERILIZER ?
‘accessory for a medical device’ means an article which, whilst not being itself a medical device, is intended by its manufacturer to be used together with one or several particular medical device(s) to specifically enable the medical device(s) to be used in accordance with its/their intended purpose(s) or to specifically and directly assist the medical functionality of the medical device(s) in terms of its/their intended purpose(s);
I see that no manufacturers are until now commercializating sterilization controls as BI, BowieDick, ... with CE mark, are all waiting the application date 26 may 2020?
Jane_S
Well I wouldn't say the BI's are intended for cleaning or sterilising a device, but to control the process, which is different, BIs don't ensure the sterility/cleanliness of the product by themselves. I am more concerned about the manufacturers of sterilisation chambers, as I got a chance to speak with QM from one and they were completely oblivious to this change.
There are additional controls possible (excluding) BIs. But the manufacturers of sterilisation chambers are a real concern.
Which entry are you looking at in the Manual?
The manual is https://ec.europa.eu/docsroom/documents/35582/attachments/1/translations/en/renditions/native and is related to MDD
and the entry
7.4. Sterilization indicators
- Background
The sterilization procedure is monitored routinely by using chemical and biological indicators to evaluate the sterilizing conditions and indirectly the microbiologic status of the processed items.
- Outcome
Sterilization indicators monitor the performance of the sterilizer. They do not affect the sterilization procedure and only provide additional information to the user. Sterilization indicators do not fulfil either the definition of a medical device laid down in Article 1(2)a of Directive 93/42/EEC or the definition of an accessory laid down in Article 1(2)b of Directive 93/42/EEC as they are not intended specifically to be used together with a device to enable it to be used in accordance with its stated use.
AS THE STERILIZER IS A MEDICAL DEVICE ACCORDING THE MDR DEFINITION, THE LAST SENTENCE UPDATED TO MDR WILL BE :
- Outcome
Sterilization indicators monitor the performance of the sterilizer. They do not affect the sterilization procedure and only provide additional information to the user. Sterilization indicators do not fulfil the definition of a medical device laid down in Article 2(1) of MDR but they fulfill the definition of an accessory laid down in Article 2(2) of MDR as they are intended specifically to be used together with a device (the sterilizer) to enable it to be used in accordance with its stated use.
Regards
Xavier Canals
pkost
I disagree that the indicator enables the steriliser to be used in accordance with it's stated use - the lack of indicator does not affect the sterilisation and it is not intended to be used to to demonstrate that sterilisation has been successful to the user of the steriliser (other methods are used for this e.g. temperature, dose, duration etc).
The indicator should only be used to show that the item has gone through the process, not that it is sterile and that the process was effective.
dgrainger
The Borderline entries apply specifically to the MDD/IVDMDD. You can't assume that they will apply to the MDR/IVDMDR.
However, the definition of accessory has changed. The manufacturer of the steriliser would have to identify the sterilization indicator as an accessory in the IFU/technical file though!
A Qualification of clinical assessment scales EU Medical Device Regulations 0
K Supplier Qualification for Engineering Consultant? Supplier Quality Assurance and other Supplier Issues 3
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
R Qualification list of businesses approved to Off-Shore Aerospace work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
E Qualification for non gmp service providers Supplier Quality Assurance and other Supplier Issues 1
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 8
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
Y Examples of TRB Reports for MIL-PRF-31032 Qualification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
K PQ validation qualification - Asked to write a PQ protocol ISO 13485:2016 - Medical Device Quality Management Systems 6
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
T Qualification testing of Lead acid batteries Reliability Analysis - Predictions, Testing and Standards 0
Z Qualification of AzureDevOps in Gxp Qualification and Validation (including 21 CFR Part 11) 12
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
B VDA 6.3 Qualification as Process Auditor training course and exam VDA Standards - Germany's Automotive Standards 0
D Performance Qualification per GHTF Guidance Other Medical Device Related Standards 12
M Informational EU – Guidance on Qualification and Classification of Software in Regulation (EU) 2017/745 – MDR and Regulation (EU) 2017/746 – IVDR Medical Device and FDA Regulations and Standards News 2
dgrainger Informational MDCG 2019-11: Guidance on Qualification and Classification of Software in Regulation (EU) 2017/745 – MDR and Regulation (EU) 2017/746 – IVDR Medical Device and FDA Regulations and Standards News 0
H How to prepare Performance Qualification (PQ) for autoclave General Measurement Device and Calibration Topics 2
D ISO 13485 - Equipment validation , qualification Qualification and Validation (including 21 CFR Part 11) 6
DuncanGibbons Qualification vs Certification in an Aerospace context AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Z Operational Qualification for Injection Molding Supplier Quality Assurance and other Supplier Issues 6
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
R Qualification of Distributors such as McMaster-Carr and Digikey to Medical Device Companies ISO 13485:2016 - Medical Device Quality Management Systems 3
Z Training Qualification Matrix for ISO 9001:2015 Audit General Auditing Discussions 8
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
J Qualification of a Software as a Medical Device (SaMD) guidance under MDR EU Medical Device Regulations 9
I Compressed air system qualification and 1 micron particle analysis Other Medical Device Regulations World-Wide 0
S Medical Device Supplier Component Qualification Service Industry Specific Topics 0
O Clean room performance qualification (pq) - How many times can I do each test? Manufacturing and Related Processes 8
K Is Mold qualification / process validation always required? Manufacturing and Related Processes 7
Rameshwar25 IATF ADP - How to proceed for new auditor qualification IATF 16949 - Automotive Quality Systems Standard 17
S Do suppliers of prototyping components need to undergo supplier qualification? ISO 13485:2016 - Medical Device Quality Management Systems 3
P Qualification of weights used for curing epoxy Manufacturing and Related Processes 3
M Qualification of Freezer with IQ and PQ but no OQ Qualification and Validation (including 21 CFR Part 11) 2
S Supplier Qualification - How do we determine which suppliers to qualify? ISO 13485:2016 - Medical Device Quality Management Systems 9
J Installation Qualification (IQ) and Operational Qualification (OQ) for Laser Marking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Qualification of Evaluator - Clinical Evaluation Report MEDDEV 2.7.1 Rev 04 CE Marking (Conformité Européene) / CB Scheme 3
J Simple supplier evaluation qualification process form that includes Risk Assessment Document Control Systems, Procedures, Forms and Templates 2
D What should an ISO 14644 Clean Room PQ (Performance Qualification) look like? Manufacturing and Related Processes 3
P Qualification of a Temperature Controlled Unit have to be empty? Qualification and Validation (including 21 CFR Part 11) 5
R Qualification of Evaluator - Clinical Evaluation Report MEDDEV 2.7.1 Rev 04 Other Medical Device and Orthopedic Related Topics 1
O AS9100 AQMS AEA Qualification Audits 4 Full QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C MSA for Non Manufacturing - Design Validation, Characterization and Qualification Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L Heated Sealed Packages - Sample Size for OQ (Operational Qualification) and PQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
Z Is PPAP Re-qualification needed in case of not quoted dimension change? APQP and PPAP 4
