Qualifying commercial off the shelf (COTS) external suppliers
We are a wood manufacturing organization that is implementing ISO9001:2015.
Most of our products are low risk. Our customers tells us they want a shipment pallet but do not describe the type of material or any details in how to create the pallet. Of course there are no requirements for material traceability or measurement traceability.
We buy standard products from commercial external providers.
Our question is what evidence would the ISO9001:2015 standard expect for the qualification of our commercial external providers?
Our plan is to give purchasing the authority to select external providers and we will not retain and documented evidence of the selection process.
The reason we are implementing ISO9001:2015 is to attract more sophisticated customers and we fully expect to use a formal external provider qualification process and will retain the documented evidence as needed. Currently we do not have any of these customers.
Thank you in advance for your help.
Tagin
The standard is intentionally mute on specifics, because each industry & company will have their own requirements for providers.
So, think about what criteria your company uses now to decide who to use as a provider of materials for your manufacturing. E..g., you may want to only deal with top-tier providers, or those within a certain radius, or those that comply with certain requirements of yours, those that are financially healthy, etc. Don't make up new requirements - just formalize the requirements you've been using all along. Then, the evidence you need is whatever is needed to show that the selected providers meet those reqmts.
Likewise, on the re-evaluations of providers, implement criteria that is relevant to you. E.g., they deliver on time, product is good quality, they respond to order change requests in a timely manner, they bill you properly, etc. Whatever it is, use those criteria.
You can refine these criteria over time, so don't feel too restricted by your initial criteria, as long as it makes reasonable sense with respect to the providers you actually use.
But...you have to: 8.4.1:"The organization shall retain documented information of these activities and any necessary actions arising from the evaluations."
ScottK
Not out of the crisis
As Tagin says, the standard allow for the flexibility to meet the organizations needs.... so i you want to give purchasing the authority of certain items you can do that. Just document that justification in the top level procedure or the supplier selection work instruction or whatever document you have for that process.
I would phrase it something like "for low risk, commercial, off-the-shelf or catalog components purchasing agents have the authority to select the best supplier on a case by case basis. This will generally be based on lead time, price, and/or availability."
You may want to have a matrix that gives examples of components of various risk.
tony s
Information Seeker
That's your organization's prerogative, if it wants purchasing to have the full authority to select. In selecting suppliers, I don't think purchasing will just pick any supplier randomly. There must be criteria e.g. cost, type of material, etc. Comparing supplier quotations (thru canvassing) is a good answer to your question "... what evidence would the ISO9001:2015 standard expect for the qualification of our commercial external providers?"
normzone
How about "COTS suppliers must be able to provide material per our specification and to our schedule at an appropriate price" ?
If we can make it any simpler please let me know.
Ninja
Looking for Reality
I would add on the end of this, "...or other criteria" to keep the doors open...
"generally" covers it already..."or other criteria" slams the door on the auditor with a chip on his/her shoulder.
ScottK
ahh -but you should write for your organization, not for an auditor.
but your point is certainly taken. I've butted heads with many auditors over the years because of phrasing.
Ninja
Looking for Reality
Agreed. I write loopholes where I want loopholes...it benefits my company because I don't have to waste time in audits for silly stuff.
The point is to give freedom to do business, and the phrasing is easy enough.
Candi1024
I would state that suppliers that provide material or services that are a low risk to the product quality are not required to go through the supplier qualification process. Then ensure there is a process where the risk to product quality is examined prior to adding that supplier. You may also want to add a matrix to help the person responsible for such determination to decide.
GreatNate Qualifying a CNC machine Manufacturing and Related Processes 3
H Require PPAP Before Qualifying Vendor? (Packaging) APQP and PPAP 2
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
K DFARS (Defense Federal Acquisition Regulations) Certs for a Qualifying Country Various Other Specifications, Standards, and related Requirements 2
I Requirements for Qualifying a Stability Chamber Qualification and Validation (including 21 CFR Part 11) 4
triathlonx13 Plastic Injection Molding Specification (Purchasing, Qualifying, validation) examples Document Control Systems, Procedures, Forms and Templates 2
P Pointers for qualifying the probes using the Calypso Software on a Zeiss General Measurement Device and Calibration Topics 4
R Method for Dew Point and Oil content - Qualifying our Compressed Air System (CAS) Qualification and Validation (including 21 CFR Part 11) 7
M Supplier Qualification - Qualifying small suppliers and trading houses IATF 16949 - Automotive Quality Systems Standard 3
A Qualifying and Approving Equipment for Welding AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Are you Qualifying your own Gageblocks and Pin Sets? General Measurement Device and Calibration Topics 16
L Qualifying an Interapid 312b-3 Indicator - Disappointment General Measurement Device and Calibration Topics 6
A Qualifying a CMM Star Probe - Brown/Sharpe CMM Model Gage 2000 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
B Procedure or form for Qualifying New Materials - Fiberglass company Document Control Systems, Procedures, Forms and Templates 3
M Inspector Qualifications - Qualifying someone to be an inspector Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
K CMM Qualifying Sphere Calibration General Measurement Device and Calibration Topics 9
Q Qualifying Persons to Reflow Solder by hand - Circuit boards Various Other Specifications, Standards, and related Requirements 3
J Weld Penetration - ANSI/AWS D14.3-94 - Qualifying welding procedures Various Other Specifications, Standards, and related Requirements 8
S Qualifying TS2 Internal Auditors & Refresher Training Internal Auditing 3
E Grand Fathering Clause - Qualifying senior, experienced personnel as competent Misc. Quality Assurance and Business Systems Related Topics 15
C Qualifying audits General Auditing Discussions 3
J Qualifying Suppliers of Calibration Services General Measurement Device and Calibration Topics 12
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
DMLqms Country of Origin on Commercial Invoices EU Medical Device Regulations 2
P Medical Device not on commercial distribution but installed in the establishment. 510k? Other US Medical Device Regulations 10
DuncanGibbons To what extent are NASA standards applicable to commercial aviation? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B IATF 16949 Cl. 4.3.2 - CSR vs Commercial Agreements IATF 16949 - Automotive Quality Systems Standard 8
shimonv Creating a new commercial product based on a modification to an existing product Other US Medical Device Regulations 4
Ajit Basrur How do I label this commercial product ready for clinical study? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Design exclusion in AS9100D for commercial products AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P What is expected in a Medical Device Commercial Release Procedure Design and Development of Products and Processes 3
F Definition Commercial Distribution - Definition - Scope of Commercial Distribution Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
M Commercial tablet as an "accessory" for a medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Control of COTS (Commercial Off The Shelf) Specifications ISO 13485:2016 - Medical Device Quality Management Systems 2
S COTS (commercial off-the-shelf) Validation FDA Requirements Software Quality Assurance 4
E Commercial Laboratory Audit Tips ISO 13485:2016 - Medical Device Quality Management Systems 2
C Commercial Grade Supplier Surveys - Not qualifed 10CFR50 Appendix B or NQA-1 Other ISO and International Standards and European Regulations 2
S ISO 15189 - When commercial QC Material is not available Hospitals, Clinics & other Health Care Providers 4
B Commercial Calibration Laboratory Software Recommendations Calibration and Metrology Software and Hardware 1
T ISO 17025 - 4.1.5b Internal/External commercial, financial, and other pressures ISO 17025 related Discussions 3
B List of all Auto Parts in a Commercial Vehicle Manufacturing and Related Processes 11
C Apostille of French Commercial Documents for the Republic of Turkey EU Medical Device Regulations 5
H Certification of a large commercial helicopter acc. AC29-2C / CS29 EASA and JAA Aviation Standards and Requirements 1
V Common Root Cause for Failures in Scaleup & Commercial (Validation) Batches 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Regulatory Value of Commercial Documents (Brochures, Marketing Leaflets, etc.) EU Medical Device Regulations 2
M Everything to AS9100 vs. ISO 9001? Commercial Jobs require AS9100 "Extras"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Regulatory requirements for Commercial Medical Devices for sale in Europe ISO 13485:2016 - Medical Device Quality Management Systems 2
B Ideas on how to differentiate jobs (AS9100 jobs vs. "commercial" jobs) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
