Quality Management Principles Working Group
Paul Simpson
I am aware a small working group has been established within ISO to look at the relevance of the current list of 8 Quality Management Principles.
If you were able to influence the principles that underpin the ISO 9000 series of standards what would you want to have and why?
If this thread has legs we might break it into a thread for each of the current 8 principles and a separate thread for suggested new topics.
Principle 1: Customer focus
Principle 2: Leadership
Principle 3: Involvement of people
Principle 4: Process approach
Principle 5: System approach to management
Principle 6: Continual improvement
Principle 7: Factual approach to decision making
Principle 8: Mutually beneficial supplier relationships
I look forward to your contributions.
Sidney Vianna
Post Responsibly
Thanks, BorisS. I hope this thread gets traction and people chime in. As time allows, I will try to contribute to this discussion in more depth. For the time being, my initial thoughts are that the principles are still worthy and current. However, they only exist in the 9004 sphere. In 9001, they are either excessively tenuous or non-existent. For example the principle of mutually beneficial relationships: if we really want that principle to be implemented in the real world, we need to "translate" it into some actionable something. Such as, and just an example, should ISO 9001 have a requirement for periodic assessment of supplier satisfaction? As organizations need to manage the risks of their supply chains, having a critical supplier ceasing to do business with us, due to their utter disgust on how we treat them has clear a negative impact and a (likely small) likelihood. So, managing supplier satisfaction would be a way of minimizing the chances of supplier "divorce".
Slightly :topic: In the years preceding the release of ISO 9004:2009, some of the TC176 constituents went on the record saying this would be the "last chance" for ISO 9004 to gain interest. If 9004 continued it's path to oblivion, the TC176 would pull the plug and eventually cancel it, like previous documents the TC 176 has cancelled over the years. It would be interesting to know if the TC 176 is monitoring the sales of 9004:2009. After all, the factual approach to decision making should be also exercised by the TC, isn't it? :tg:
Paul Simpson
Thanks as ever, Sidney. You make a good point about the 'Mutually beneficial ... ' principle.
Request for the moderators - would it be possible to have 9 sub threads as I suggested so we can have a clear thread - one for each of the existing principles and another for the 'We would like to have ...' thread?
Pretty please? :D
Sturmkind
Excellent thread! Especially if some of the Cove ideas can influence the iteration of the next document!
Actionable items for Mutually Beneficial supplier relationships does need a clearer definition. Chrysler tried to contribute to that in the '90s with the the Extended Partnership Enterprise concepts but it does not seem to have 'stuck'. Unfortunately, so long as Purchasing [lowest] Cost is the driver without true supplier development efforts, some concrete actions may be unattainable.
One high impact area would be the inclusion of the entire supply chain for input at the Advanced Quality Planning and Design Stage for commodities whose success requires seamless and effective interaction.
-Example: Show surface chromed steel relies upon the surface quality and sub-surface stress level of the steel rolling process and chemistry, the success of the blank flat polish process, the stamping/forming process, chroming process, and post-chrome buffing. All of these suppliers need to be in the same room at the same time with the die shop folks to minimize development misunderstandings and maximize specific requirements for potential chrome appearance defects.
The takeaway may be evidenced by joint and jointly signed FMEA. GM does seem to be taking positive strides in this area on their latest programs. It is likely that the domestic 3 OEMs will continue to devlolve direct design responsibility onto the Tier I supply base so this discipline may become increasingly critical.
ScottK
Not out of the crisis
Pretty please? :D
You can start all the threads you feel you need without moderators' help, but I think if you separate them some will get lost in the press of other topics unless someone is diligent about maintaining links.
I think what you're really looking for is a sub-forum to keep it all together.
That's up to Marc, but I'm sure he'll listen if enough people speak up about it.
Colin
I find it difficult to separate out 'Process Approach' and 'System Approach'. I find them so similar that I wonder if they would be better combined.
My wish for another principle would be preventive action - as a principle that runs through much of the standard rather than a 'stand-alone' clause.
John Broomfield
BorisS,
How about a ninth quality management principle?
Consider velocity - the system and its processes are meant to add value faster and prevent loss sooner. why not measure velocity: the rate at which the system's core process adds value in monetary units per unit of time (for example, $/minute)?
Applying this principle could help leaders to appreciate their management systems and those of their supply chains.
John
Stijloor
BorisS,
Measurement of system and process performance - the system and its processes are meant to add value faster and prevent loss sooner. This requires measurement of velocity: the rate at which the system's core process adds value in monetary units per unit of time (for example, $/minute).
John
John,
That's covered in Principle 7.
Stijloor.
John Broomfield
John,
Stijloor.
Here is principle 7 in full with its sales blurb:
Effective decisions are based on the analysis of data and information
Key benefits:
■Informed decisions.
■An increased ability to demonstrate the effectiveness of past decisions through reference to factual records.
■Increased ability to review, challenge and change opinions and decisions.
Applying the principle of factual approach to decision making typically leads to:
■Ensuring that data and information are sufficiently accurate and reliable.
■Making data accessible to those who need it.
■Analysing data and information using valid methods.
■Making decisions and taking action based on factual analysis, balanced with experience and intuition.
I do not see any reference to a principle of measuring velocity.
Stijloor
Key benefits:
Yes, I know. But I look at Principle 7 as data, measuring and decision-making activities. You can include any measuring activity as you wish.
Stijloor.
D Quality Management Principles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S ISO 9001 Clauses which reference the 8 Principles of Quality Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to correlate the 8 Quality Management Principles to ISO 9000 standards ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Quick Reference for the 8 Quality Management Principles in ISO 9000 IATF 16949 - Automotive Quality Systems Standard 2
Stijloor Quality Management Principles Assessment Tool ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G Quality Principled Quality Manual based on the eight Quality Management Principles Quality Management System (QMS) Manuals 1
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
M Unique Quality Management System for 2 sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
John Broomfield CIOB - Code of Quality Management Misc. Quality Assurance and Business Systems Related Topics 1
D Big companies suffer from quality management system? ISO 13485:2016 - Medical Device Quality Management Systems 1
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R How would you work without a quality management system? IATF 16949 - Automotive Quality Systems Standard 3
P Conformity assessment based on a quality management system or production quality assurance EU Medical Device Regulations 3
R Electrical contractor Project Quality Management Plan Quality Manager and Management Related Issues 1
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P How to develop executable quality management system for rookies? IATF 16949 - Automotive Quality Systems Standard 9
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
M Quality management certification required by Health Canada Canada Medical Device Regulations 3
A Building up a global quality management system ISO 13485:2016 - Medical Device Quality Management Systems 2
A Building up a global quality management system 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
John Broomfield Informational Terms used in quality management [Deleted] Misc. Quality Assurance and Business Systems Related Topics 6
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 3
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
A Supplier Quality Standard vs Senior Management Direction Supplier Quality Assurance and other Supplier Issues 2
J Quality Assurance in China - Developing a quality management system for a California company Misc. Quality Assurance and Business Systems Related Topics 9
I Date of Quality Management System - Training Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Procedure on Privacy Policy in the ISO 13485 quality management system ISO 13485:2016 - Medical Device Quality Management Systems 3
John Broomfield Informational Chartered Institute of Building - Code on Quality Management Service Industry Specific Topics 2
M Informational TGA – Guidance on Therapeutic Goods (Conformity Assessment Standard for Quality Management Systems) Order 2019 Medical Device and FDA Regulations and Standards News 0
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
M CMQ/OE or SSGB? I'm Quality management rather than process improvement oriented Career and Occupation Discussions 1
D Templates for Environmental, Safety and quality Management System wanted Document Control Systems, Procedures, Forms and Templates 3
B Quality Management System documentation identification Document Control Systems, Procedures, Forms and Templates 11
eule del ayre Lean Six Sigma for Quality Management System Lean in Manufacturing and Service Industries 10
Sidney Vianna ISO/TS 30411:2018 Human resource management - Quality of hire metric Other ISO and International Standards and European Regulations 1
J Implementation of Total Quality Management/Starting a Quality Department Reliability Analysis - Predictions, Testing and Standards 9
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
John Predmore Explain Quality Management System (QMS) for the uninitiated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What are you looking for in an automated quality management system? Quality Assurance and Compliance Software Tools and Solutions 8
R Quality Management Software Recommendations ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W Can 2 different sites under different Quality System have a common management review? ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO 9001 Help - New Quality Manager - Upper Management Support Issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Supplier Control - Supplier quality management certificates (ISO, etc) ISO 13485:2016 - Medical Device Quality Management Systems 2
J Support and guidance with supplier quality management system Supplier Quality Assurance and other Supplier Issues 1
