Quality Manager Weekly Report Template
brossbach1
I looking for some help. Looking for a Quality Manager weekly report template that could make reporting a little bit easier on a weekly basis. I hoping to find; if someone has a Quality Manager weekly reporting template or somethan i can use to modify to capture the necessary information that is needed in this report.:thanks:
qusys
here below some ideas, but I think it depends on the tasks and activities where the Quality Mgr is owner.
The item of the weekly report could be:
1. number of the internal audit done and the percentage of completion vs annual plan
2. number of non conformities still open
3. number of non conformities closed
4. number of supplier audit done with status of the corrective actions closed
5. number of procedures reviewed and approved
6. number of PPAP reviewed and signed off
7. number of customer issues and complaints solved
8. number of non closed conformities of the registrar audit
9. number of customer audit managed and corrective actions closed and still open
10. status of capable process ( check for Cp/ Cpk)
11. status of the preventive action ( action implemented and still open)
12. value of the cost of poor quality based upon scrap, rework, supplier issues, delivery on time
13. status of the major continuos improvement projects of the organization to improve QMS process and customer satisfaction
14. update of the customer requirements if any
15. monitoring of the internal quality awareness by means of ad hoc surveys
The list could be continued but I would like to share ideas with you and other expert Covers.
hope this helps:bigwave:
Wes Bucey
Prophet of Profit
  1. How big is your organization?
  2. How many things happen out of the ordinary?
  3. What will happen with the report after you make it?
Here's my take:
I understand weekly, daily, even hourly production reports - they help an organization manage the business aspect of the business.
In my machining organization, a nonconformance was a rare event and it triggered a whole lot of activity. (See this post.) The data was recorded for all to see - no separate report summary of the activity was necessary.
If the quality guys are running inspections and they detect nonconformance, what use are the data of finding nonconformances without the whole enchilada of root cause investigation and subsequent resolution of the finding? I have trouble envisioning a viable organization where there are enough open investigations that they need to be summarized in a report. If there are so many new events each week they need to be summarized in a report, it must either be a super giant international summarizing events at all locations or the most fouled up organization in the world.
Why does a quality report have to be weekly? If the report is just data (how many this, how many that), why bother with a report, unless there are "events" which show the system is not working? I cringe at the forests which have been depleted over the years to generate "reports" that said [essentially] "no change."
Note: a report is different from a record in that a report usually is just a summary of records. In no way am I advocating "no records," just fewer "no action" reports.
If the report just contains the "same old, same old," there is probably no action called for. Some managers might even begin to suspect a QM of creating busy work to justify his existence.
For a report to be worthwhile, it probably should engender concern and subsequent action, else it just gets filed away as a record the QM didn't think the bosses were capable of accepting the fact the system was running the way it should.
RoxaneB
I'd also consider the possibility of including $$$ in the report (be it weekly or monthly).
For example, the # of customer complaints is a good starting point. # of customer complaints / 1000 widgets produced is better for comparing performance over time. And there is the $$$ of the complaints (actual complaint, processing time, etc.).
Depending on the audience of the report, $$$ can speak volumes!
Just my :2cents: ... ;)
harry
Who is the recipient and what is the objective or purpose of the report?
If it is top management, I agree that '$' is relevant including 'key' indicators and perhaps items you want their attention. Bear in mind that don't have much time for it so keep it simple and short.
If it is meant for communication / information to the various areas, their performance measures with +/- percentages should be useful for them as wake up calls or to formulate strategies to catch-up, etc in case they are lagging behind.
qusys
Agree with Harry.
I only gave some ideas, also saying that we should know the job description of Quality Manager.
Besides, the frequence of the report could be monthly or quaterly to have a major number of topics and also make some trends.
Besides, the ideas could come from 5.5.2 of ISO 9001 for Manegement representative. Assuring to meet the clause is equivalent to have item to put in report aimed at management.:bigwave:
What you haven't told us is what the necessary information consists of. What are you expected to report?
brossbach1
The information that qusys mentioned is good information, the QM report is a weekly event in a staff meeting that consist of salary personnel, engineers, accounting, production, MP&L, Human resources, quality. I'm trying to put somethan together to make it simple but as mentioned from others to get the point across and actions. Cost not a factor for this type of meeting. Thank you all for responding. I want the factors which to separate what QE's report vs QM report. I hope this gives some clarity what i'm looking for.
C Quality Manager as part of Management - 13485 ISO 13485:2016 - Medical Device Quality Management Systems 9
B Quality Manager Retiring IATF 16949 - Automotive Quality Systems Standard 5
S Quality manager considering data science Quality Manager and Management Related Issues 19
C Quality Manager vs Warranty (service) Manager - Authorities & Responsibilities Customer Complaints 2
F Position of Quality Manager - Can the organization's Quality Lead be shown as Quality Manager of the lab as well? ISO 17025 related Discussions 5
T New role Quality Manager IATF 16949, new company, advise how to get started IATF 16949 - Automotive Quality Systems Standard 2
CCaantley Stepping Down from my quality manager position soon After Work and Weekend Discussion Topics 18
A ISO 9001 Help - New Quality Manager - Upper Management Support Issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
Kronos147 Quality Manager's Role in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Corporate Quality Manager keeping me out of the Management Review Meeting Management Review Meetings and related Processes 28
I Auto Industry Resume Template for a Quality Manager Career and Occupation Discussions 2
F Quality Manager - Conflict of interests in organisational structure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Quality Assurance Manager ? Next Steps? Quality Manager and Management Related Issues 10
S Quality Assurance Manager involvement in Management Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L What are some SOPs that a Quality Manager should have? Document Control Systems, Procedures, Forms and Templates 6
P Leadership Standards - New job as Quality Manager Quality Manager and Management Related Issues 9
K New Quality Manager Role Quality Manager and Management Related Issues 13
A Shall I apply for this job position (Quality Manager)? Career and Occupation Discussions 5
J Lead Auditor and Quality Manager - Conflict of Interest? Career and Occupation Discussions 4
M Can a Quality Manager be a Lead ISO 9001 Auditor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
L Quality Manager wants Internal Auditor to softgrade the findings - What shall I do? Internal Auditing 23
R Root Cause Analysis of Audit Findings - New Quality Manager Quality Manager and Management Related Issues 20
J Quality Manager's role in Customer and Supplier Complaints Customer Complaints 10
Y New Quality Manager looking for Tips and Quality Methodologies Quality Manager and Management Related Issues 8
K What would you do in the first 90 days of a new job as the Quality Manager Quality Manager and Management Related Issues 33
1 Quality VP/Manager left - Educating his replacement Quality Manager and Management Related Issues 9
F What Training should a Quality Manager have? Training - Internal, External, Online and Distance Learning 32
L Product Manager vs. Quality Manager: Who is right? Misc. Quality Assurance and Business Systems Related Topics 14
D Designing a Training Course called "Role of the Laboratory Quality Manager" Training - Internal, External, Online and Distance Learning 13
J Is this practice common? 1 Quality Manager covering QA, QC, QE, SQE IATF 16949 - Automotive Quality Systems Standard 20
M What qualifications should a Quality Assurance Manager have? Misc. Quality Assurance and Business Systems Related Topics 3
G Definition Quality Manager - What is the definition of a Quality Manager? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 16
R Quality Manager Reporting to Director of Manufacturing - Conflict of Interest? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
R Distinction between Management Representative vs. Quality Manager Responsibilities IATF 16949 - Automotive Quality Systems Standard 5
L How to improve Product Quality - New Job as Quality Manager Quality Manager and Management Related Issues 3
C New Quality Manager - Establishing Teams in different Business Units Quality Manager and Management Related Issues 4
P Does the Quality Manager have to be a Senior Manager? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
R Quality Manager Training Methods - Learning and Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
C Is a "Designee" List needed? For example: "Quality Manager or designee" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S HR Manager refusing to create Quality Objectives - Is this a Non-Conformity? Quality Manager and Management Related Issues 11
Q ASQ CQM (Certified Quality Manager)/OE Certification Exam Preparation Materials Professional Certifications and Degrees 3
K Goal - Quality Manager at Global Company Career and Occupation Discussions 9
J Annual Strategic Planning Session - How can a Quality Manager contribute? Quality Manager and Management Related Issues 4
J Quality Manager Exam Reference Material that would be Worth the Investment Professional Certifications and Degrees 1
A Advice for a barely promoted Quality and Compliance Manager Quality Manager and Management Related Issues 1
P Daily Rate to bill for a Site Quality Manager - Construction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Taking over duties from a Quality Manager who left - Taken for a ride? Career and Occupation Discussions 8
K Calibration questions from newly appointed quality manager General Measurement Device and Calibration Topics 10
B Small company where the Quality Manager and HR manager is the same person ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Advice for future QM (Quality Manager) in automotive Career and Occupation Discussions 29
