Greetings,
My audit check list is blatantly plagiarized from our accreditation audit; therefore, I cannot pass it on to you.
Check with your AB and or your auditor. They should be able to give you what you need.
Remember if this is for your internal audit, you do not need a lot of the check points. You will need to add those points which for your company will “connect the dots” for the clauses, not necessarily just prove you mention them in your documents.
You may find it is time well spent on the project of making your own check list.
Ours includes safety issues, vehicle issues, DOT issues, as well as an audit of our technicians as they are working in the field.
