Quality Manual and Standard Operating Procedures - File attached
#11
All great ideas. We are a 3 man shop and work instructions are scarce; however, we will look at referencing related forms. Thank you for your response.
Marc
#12
If anyone has any more, please do share them. Many people will appreciate it.
K
kgott
#13
Just a query; sorry if I'm being negative here but why on earth do people use abbreviations? They are the most useless things ever. I fail to understand why they are used. Are to words to expensive to type or say?
I gave up reading a professional journal I once subscibed to because of abbreviations. I would get midway through some point the writer was trying to make in an article and I'd have to back to the begining to see what the abbreviation meant and by the time I got back to my place in the article I had lost the whole point.
Abbrevaitions also increase risk because poeple don't want to appear an idiot by asking what a particular abbreviation stands for only to be told it stands for a some common term or form used. This can lead to risk of nonconformances and risk of unwanted events to people and plant.
Well; thats why abbrervaitions are in the procedure, I hear your cry!!
Well; 6 pages into the manual or any other document riddled with abbrevaitions are you really going to go back to the first few pages and thumb through it to find out what some particular abbrevaition means?
If I have to do that with this document or any other document..... well; shove it, I'd rather risk an injury to someone else or see the company get a non-conformance rather than go back through the document to see what the abbrevaitions means or look like an idiot for asking what it means. Sorry mate but I got work to do, cya later! (Thats the way people think)
I thought procedures are meant to convey clear unambigious information to the reader not confusion.
cheers
subodhshah
#14
Hi, thanks
I was stuckup in few procedures while preparing it
your format will help me to solve that
G
Groo3
#15
Abbreviations are a risk, especially when you use a lot of them... If you use them, you should make sure to define them ALL. Too many abbreviations drive me nuts, but whatever works for your business is fine. Quality Manual's are not there to make an outside auditor's life easier, they are there because they are required by a standard and to help your business to organize and meet the requirements of a standard.
Your QM does appear to have one or two abbreviations that are not defined, for example what does MTP mean? (you do say Medical Technical Products on the cover, but you do not define that on your acronyms page, is that what the acronym means? I found MTP on page 7 + 13 + 18) Never assume others will understand acronyms that are common to your industry, and if you are going to use an acronym, make sure it is defined. You should also use caution using acronyms where they are not used in your final version of the QM (I saw FSCA defined under abbreviations, but could not find it elsewhere in your document - then again, it's early and I haven't had my first cup of tea yet).
Other than that, I like it... concise, directs you to the correct documents, gives you a sense of how the processes work. :agree1: :2cents:
PS: http://www.abbreviations.com/MTP
#16
<snip> I gave up reading a professional journal I once subscibed to because of abbreviations. I would get midway through some point the writer was trying to make in an article and I'd have to back to the begining to see what the abbreviation meant and by the time I got back to my place in the article I had lost the whole point. <snip>
This is the type of constructive criticism I was hoping for. Thank you for taking the time to reply.
S Quality Manual and ISO TS 16949 Standard IATF 16949 - Automotive Quality Systems Standard 5
R NQA-1 Quality Manual vs. Standard - How much should they differ Quality Management System (QMS) Manuals 7
I Short SOPs (Standard Operating Procedures) or Add to Quality Manual? Quality Management System (QMS) Manuals 10
Z How to Establish Quality Manual Not Following the Structure of the Standard? Quality Management System (QMS) Manuals 3
P Quality manual none standard Quality Management System (QMS) Manuals 1
Q Quality Manual vs. ISO9001:2000 Standard - Quality Manual doesn't address all of 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Quality Manual - Duplicate wording from the standard? Quality Management System (QMS) Manuals 22
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
B Quality manual for automotive industry wanted Quality Management System (QMS) Manuals 2
F Quality manual for trading company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Quality Manual for 2nd site Quality Management System (QMS) Manuals 3
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A Supporting Site Quality Manual and References Requirements IATF 16949 - Automotive Quality Systems Standard 14
L ISO 9001 - 2015, is the Quality Manual needed? Please advise ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Quality Manual for a Quality Plan (Manufacturing secrets?) Request Misc. Quality Assurance and Business Systems Related Topics 1
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
R ISO 9001:2015 Transition Quality Manual Update - Redundant Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P AS9100 rev D Quality Manual wanted - 2017 Quality Management System (QMS) Manuals 4
B Integrated Quality Manual ISO 13485:2003 ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 6
I Concerning procedures within Quality Manual ISO 17025 related Discussions 10
I Quality Manual Upgrade from AS9100 C to D Quality Management System (QMS) Manuals 10
GStough Have You Had to Write a NC Against a Quality Manual in a Supplier Audit? General Auditing Discussions 12
A AS9100D Quality Manual & Procedures needed Quality Management System (QMS) Manuals 4
J AS9100 Rev D Quality Manual Rewritten - Feedback Appreciated Quality Management System (QMS) Manuals 13
M IATF:16949 Common Quality Manual - Company is in Country A and Country B Quality Management System (QMS) Manuals 5
Y Quality Management System Manual (Wood Manufacturing Company) Quality Management System (QMS) Manuals 4
Q Do we really need a traditional Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B AS9100 Rev D Quality Manual - How are you organizing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J IATF 16949 Quality Manual Template IATF 16949 - Automotive Quality Systems Standard 25
K Quality Manual for a Virtual Company (Medical Device) Quality Management System (QMS) Manuals 2
T Has anyone completed the AS9100D Quality Manual transition? Quality Management System (QMS) Manuals 1
F Quality Manual Updates - ISO 9001:2015 and API Q1 9th Editition Quality Management System (QMS) Manuals 14
W Extensive Quality Manual Changes Quality Management System (QMS) Manuals 7
smryan Why would a Quality Manual be "Proprietary"? Quality Management System (QMS) Manuals 11
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
S How many times do you have the term 'Requirements' in your Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Is there any difference between QUALITY SYSTEM RECORD & QUALITY MANUAL 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
J Service Industry Quality Manual and Product Realization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Printing a single Page from a Quality Manual Document Control Systems, Procedures, Forms and Templates 3
M Is correlation matrix required for Customer Specific Requirements in Quality Manual? IATF 16949 - Automotive Quality Systems Standard 3
G Quality Manual - Taking a Different Approach Quality Management System (QMS) Manuals 11
M Making Amendments to a Quality Manual Quality Management System (QMS) Manuals 2
S Addition in the Scope of Quality Manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What is the difference between an API Q1 and API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 5
