Quality Manual - Taking a Different Approach
G
glenn0004
I’m trying to find a way of making our quality manual a more useful document. At present it would appear that the only time it is referenced or downloaded is during our external audits.
It’s been suggested that the 9001 requirements are split across several key policies that will provide department heads with the direction that they need regarding quality management within their departments as opposed to a set of responses to the 9001 requirements that are maintained within one manual.
i.e. Policy for Process Planning / Monitoring Measurement and Review / Document Control…..
Any feedback on this idea or other past experience would be gratefully received.
L
lk2012
Re: Quality Manual - different approach
hi,
I assume that you mean 'procedure / instructions / manual' where you say 'Policy'. If that's the case, you might want to encourage the heads of individual departments to use these as part of training.
I also do a refresher for everyone once a year (admittedly, it's usually about a month before our external audit). Everyone's asked to read the procedures (and associated instructions / forms) and let me know if they're still valid and relevant. It refreshes people's awareness of QMS and also gives us a chance to catch out any development / changes that haven't been recorded up to that point.
hope this helps
AndyN
Moved On
I have three "example" quality manuals which I will scan and upload. I'm not able just at this moment, but will do it as they are close to hand...:popcorn:
P
PaulJSmith
I?m trying to find a way of making our quality manual a more useful document.
Why?
Your Quality Manual should be a reflection of your management system. In what way do you need it to be "more useful" than that?
Not being combative here, just wondering what exactly you're wanting it to do for you.
Pancho
wikineer
I?m trying to find a way of making our quality manual a more useful document. At present it would appear that the only time it is referenced or downloaded is during our external audits.
It?s been suggested that the 9001 requirements are split across several key policies that will provide department heads with the direction that they need regarding quality management within their departments as opposed to a set of responses to the 9001 requirements that are maintained within one manual.
i.e. Policy for Process Planning / Monitoring Measurement and Review / Document Control?..
The standard calls for your manual to contain three items, (1) the scope of your system, (2) description of the interaction of your processes and (3) either references to your documented procedures, or the procedures themselves. (1) and (2) are important, but near trivial compared to (3).
If your procedures are useful, and if (3) above is met with references, your manual could be indispensable even if a single page long. Making it indispensable is a matter of making sure that the references are good. Place your manual in a shared website and make the references hyperlinks to the procedures. Then the manual will be the hub of your qms. Folks will go through the manual to get to their procedures.
But if your procedures aren't useful, meaning that they are not "documents required for the effective planning, operation and control of your processes", then no change to your manual will make it useful. Your procedures are useful only if they are actually used day to day: for consultation, training, editing and improvement. Many organizations write procedures only to meet the basic requirements of the standard. External auditors can be satisfied with this. You won't be, even if it gets you a certificate.
Charge process owners with making their procedures useful and give them the tools to do so. Also, make sure your Continuous Improvement process is agile, and that the results from that process always get documented in your procedures. With those actions, your management system will soon live up to its name. And your manual will become the heart of your organization.
John Broomfield
Glenn,
I'm not sure why you think several policies are useful. Only one is required.
A manual that drops the structure of the standard in favor of describing how the organization works with its customers and suppliers as a system to fulfill its mission or purpose is possibly of more value.
It could also usefully describe how the leaders ensure their management system assures quality and delivers improvements for the organization to remain competitive.
A conformity matrix usefully assures users and guides the auditor as to which system docs contribute to the conformity with each clause.
And you could do all this in four pages or less.
John
Peter Fraser
Glenn
Bear in mind that the 2015 revision will not require a manual at all (and the current version doesn't indicate why you need one now, and doesn't require your quality policy to be included!) so don't get hung up on it as a required document.
Far better to structure your management system documentation to make it easy for users (including managers!) to find the information they need to do their work.
Don't do anything for 9001 that you would not do for the business - defining clear and concise processes, making documents easily accessible and defining a logical structure and navigation for your system is key.
L
lokeky1
My reply is slightly off the topic. But since the title was "Quality Manual - Taking a Different Approach", I was engaged to think about using infographics. I once made a GMP training card similar to the "emergency instruction card" used by the airlines. My aim was to make the training fun and easy to follow.
Now that you asked, I might consider preparing an entire QM in graphics.
Cheers
Loke
L
lk2012
Hi Loke,
what a great idea! Seriously. Making some of the processed more visual may be the key to better understanding in areas where people speak different languages.
In a graphic QMS, what would the Quality superhero be called?
Lil
L Quality Manual Help for Service Sector/Service Organization (Government Contractor/IT Services) Quality Management System (QMS) Manuals 5
E Where can i get latest toyota and honda Supplier Quality Assurance Manual (SQAM) Customer and Company Specific Requirements 3
M AS9100 examples of procedures, quality manual, etc. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Stellantis supplier quality manual Supplier Quality Assurance and other Supplier Issues 5
H Quality planning sign-off in AIAG APQP Manual IATF 16949 - Automotive Quality Systems Standard 5
Q BMW Supplied Parts Quality Management -> Is there any new supplier quality manual? Customer and Company Specific Requirements 0
J ISO 17020 Quality Manual Other ISO and International Standards and European Regulations 3
S ISO9001 QMS: Quality Manual Examples & Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 6
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
B Quality manual for automotive industry wanted Quality Management System (QMS) Manuals 2
F Quality manual for trading company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Quality Manual for 2nd site Quality Management System (QMS) Manuals 3
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A Supporting Site Quality Manual and References Requirements IATF 16949 - Automotive Quality Systems Standard 14
L ISO 9001 - 2015, is the Quality Manual needed? Please advise ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Quality Manual for a Quality Plan (Manufacturing secrets?) Request Misc. Quality Assurance and Business Systems Related Topics 1
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
R ISO 9001:2015 Transition Quality Manual Update - Redundant Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P AS9100 rev D Quality Manual wanted - 2017 Quality Management System (QMS) Manuals 4
B Integrated Quality Manual ISO 13485:2003 ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 6
I Concerning procedures within Quality Manual ISO 17025 related Discussions 10
I Quality Manual Upgrade from AS9100 C to D Quality Management System (QMS) Manuals 10
GStough Have You Had to Write a NC Against a Quality Manual in a Supplier Audit? General Auditing Discussions 12
A AS9100D Quality Manual & Procedures needed Quality Management System (QMS) Manuals 4
J AS9100 Rev D Quality Manual Rewritten - Feedback Appreciated Quality Management System (QMS) Manuals 13
M IATF:16949 Common Quality Manual - Company is in Country A and Country B Quality Management System (QMS) Manuals 5
Y Quality Management System Manual (Wood Manufacturing Company) Quality Management System (QMS) Manuals 11
Q Do we really need a traditional Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B AS9100 Rev D Quality Manual - How are you organizing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J IATF 16949 Quality Manual Template IATF 16949 - Automotive Quality Systems Standard 25
K Quality Manual for a Virtual Company (Medical Device) Quality Management System (QMS) Manuals 2
T Has anyone completed the AS9100D Quality Manual transition? Quality Management System (QMS) Manuals 1
F Quality Manual Updates - ISO 9001:2015 and API Q1 9th Editition Quality Management System (QMS) Manuals 15
W Extensive Quality Manual Changes Quality Management System (QMS) Manuals 7
smryan Why would a Quality Manual be "Proprietary"? Quality Management System (QMS) Manuals 11
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
S How many times do you have the term 'Requirements' in your Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Is there any difference between QUALITY SYSTEM RECORD & QUALITY MANUAL 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
J Service Industry Quality Manual and Product Realization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Printing a single Page from a Quality Manual Document Control Systems, Procedures, Forms and Templates 3
M Is correlation matrix required for Customer Specific Requirements in Quality Manual? IATF 16949 - Automotive Quality Systems Standard 3
S Quality Manual and ISO TS 16949 Standard IATF 16949 - Automotive Quality Systems Standard 5
M Making Amendments to a Quality Manual Quality Management System (QMS) Manuals 2
