Quality Manual - Where does Revision History Section go?
MissTSmith
I have taken a Quality Manual over from someone else. My question is does the Revision History section go in the front or the back of the document? I'm used to putting in up close to the title page before the TOC, but others have mentioned it should go at the back which is what we do with SOPs and WIs.
Thanks.
JimS
I agree, I've seen both, as well. I prefer at the end but as with so many things, it's all in what works for you. I would suggest that all document types be as consistent as possible, however, so people know where to look.
Technically, the revision history doesn't even have to be on the document, as long as you have a clear and convenient way to get to it in your DMS. We actually use a link to the change record in the footer instead of a revision table and it's working fine. And it doesn't clutter up the last pages with tables (especially on printed forms). This certainly isn't for everyone but don't be afraid to think outside the box and just make it work for your environment.
John C. Abnet
Teacher, sensei, kennari
Good day @MissTSmith ;
Keep in mind that an actual "revision" level is not necessary. There are many ways to show whether or not a document is current issue or not. For example, some organizations simply have a discrete sequential number in the change point control data base/tracking log. For instance...
CPC# Reason for change Result of change Approved by Date Implemented
CPC -0012 blah blah blah blah blah blah blah blah blah blah blah blah
CPC-0013 blah blah blah blah blah blah blah blah blah blah blah blah
CPC-0014 blah blah blah blah blah blah blah blah blah blah blah blah
This method ensures that the CPC # on the document provides tracing back to all the necessary history/tracking information, without needing to maintain all that information on the document itself.
Any way you choose (as mentioned by others) is acceptable as long as it provides this type of historical information.
Hope this helps.
Be well.
Cari Spears
I like to put things that the reader needs to know in order to understand the document at the beginning - such as the scope and purpose, and definitions and abbreviations that will be used. Other stuff - like referenced documents and the revision history - I put at the end.
I get annoyed at having to scroll through pages of revision history in some of our customers' documents.
Ninja
Looking for Reality
We kept our revision history outside of the document, in the form of old copies in a file folder (typically pdf, sometimes paper in a hanging file no one ever looked at).
The standard does not require that you have the doc (as Randy said)...but many customers do require that you have it and send them a copy (that they then put in a file folder and never look at).
Since it was mainly a thing to send to customer's SQE's, we found no value in incorporating a rev history...it simply would have been more fuel to the fire.
hogheavenfarm
I keep ours in the front, mainly because customer SQE's typically ask "when was it revised last?" so I made it easy to find. Apparently if you havent revised it recently enough, they get worried...
JimS
We put a code in our footer that has the number of the DCR (Document Change Request) releasing the current revision and the date (MMYY) that it was released. The DCR number is an active link to the actual DCR where the change data is listed. So the code might look like "422-1220" if it was released this month via DCR #422. The date tells you at a glance how old the revision is and the link gives you direct access to the change information. Everyone seems happy with this and it looks clean on the documents.
We have a separate tool that tells us when a document hasn't been revised or reviewed in 11 months, then 12 months (our SOP says we review all docs annually). The tool then lets you either accept as-is, resetting the clock, or revise it if it needs it. This gives the evidence that we have checked the document for validity, etc even if the date in the footer says it's three years old.
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
S Annual Stock Check - Where to add it into our Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Where to define Process Tailoring Form used in CMMI in the ISO 9001 Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Procedures and Quality Manual written - Where next? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
5 Honda Supplier Quality Manual - Where to Obtain? Supplier Quality Assurance and other Supplier Issues 12
D Quality Manual - Where the cross referenced procedures fit in? Quality Management System (QMS) Manuals 4
A Please tell me where to start - ISO 9001:2000 Quality Manual 'Upgrade' Quality Management System (QMS) Manuals 9
M Daimler Chrysler SQM (Supplier Quality Manual) - Where to obtain a copy Quality Management System (QMS) Manuals 9
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
B Quality manual for automotive industry wanted Quality Management System (QMS) Manuals 2
F Quality manual for trading company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Quality Manual for 2nd site Quality Management System (QMS) Manuals 3
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A Supporting Site Quality Manual and References Requirements IATF 16949 - Automotive Quality Systems Standard 14
L ISO 9001 - 2015, is the Quality Manual needed? Please advise ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Quality Manual for a Quality Plan (Manufacturing secrets?) Request Misc. Quality Assurance and Business Systems Related Topics 1
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
R ISO 9001:2015 Transition Quality Manual Update - Redundant Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P AS9100 rev D Quality Manual wanted - 2017 Quality Management System (QMS) Manuals 4
B Integrated Quality Manual ISO 13485:2003 ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 6
I Concerning procedures within Quality Manual ISO 17025 related Discussions 10
I Quality Manual Upgrade from AS9100 C to D Quality Management System (QMS) Manuals 10
GStough Have You Had to Write a NC Against a Quality Manual in a Supplier Audit? General Auditing Discussions 12
A AS9100D Quality Manual & Procedures needed Quality Management System (QMS) Manuals 4
J AS9100 Rev D Quality Manual Rewritten - Feedback Appreciated Quality Management System (QMS) Manuals 13
M IATF:16949 Common Quality Manual - Company is in Country A and Country B Quality Management System (QMS) Manuals 5
Y Quality Management System Manual (Wood Manufacturing Company) Quality Management System (QMS) Manuals 4
Q Do we really need a traditional Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B AS9100 Rev D Quality Manual - How are you organizing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J IATF 16949 Quality Manual Template IATF 16949 - Automotive Quality Systems Standard 25
K Quality Manual for a Virtual Company (Medical Device) Quality Management System (QMS) Manuals 2
T Has anyone completed the AS9100D Quality Manual transition? Quality Management System (QMS) Manuals 1
F Quality Manual Updates - ISO 9001:2015 and API Q1 9th Editition Quality Management System (QMS) Manuals 14
W Extensive Quality Manual Changes Quality Management System (QMS) Manuals 7
smryan Why would a Quality Manual be "Proprietary"? Quality Management System (QMS) Manuals 11
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
S How many times do you have the term 'Requirements' in your Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Is there any difference between QUALITY SYSTEM RECORD & QUALITY MANUAL 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
J Service Industry Quality Manual and Product Realization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Printing a single Page from a Quality Manual Document Control Systems, Procedures, Forms and Templates 3
M Is correlation matrix required for Customer Specific Requirements in Quality Manual? IATF 16949 - Automotive Quality Systems Standard 3
G Quality Manual - Taking a Different Approach Quality Management System (QMS) Manuals 11
S Quality Manual and ISO TS 16949 Standard IATF 16949 - Automotive Quality Systems Standard 5
M Making Amendments to a Quality Manual Quality Management System (QMS) Manuals 2
S Addition in the Scope of Quality Manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What is the difference between an API Q1 and API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 5
