Quality Manuals on the web - TS 16949
  • Thread starter peteroldfield1971
  • Start date
P
peteroldfield1971
I have been tasked with bringing our company Quality Manual up to TS 16949 Spec (from iso 9000: 2000).
We are a UK automotive supplier. I have read much advice in the cove but having researched the web I have found many Quality Manuals which simply just repeat the text from TS 16949. Is this acceptable? Or should these companies be referencing supporting documents?
Any pointers on implementing TS 16949 would also be advantageous.
Many thanks.
jmp4429
If all you needed was the text of TS 16949, you wouldn't be required to have a quality manual. The quality manual should basically be your own version of the TS 16949 standards, as it applies to you, and including customer-specific requirements.
P
peteroldfield1971
Thats what I assumed but having read many US company manuals on the web, I have found many manuals that simply replace the words "The organisation shall..." with "Company XXXXXXX Inc have....." and find that there is no reference to supporting documents or procedures. I my self will not follow suit as the company have procedures in place with reference to the majority of TS 16949. I was just curious as to why some companies simply did it and if they passed audits.
jmp4429
We Americans are inherently lazy
Probably.
From an auditing standpoint, I guess technically there's nothing wrong with copying the standard word-for-word, as long as it covers everything it needs to. Kind of like in school when you'd ask a teacher how they wanted a research paper to be and they said "As long as it needs to be"
Marc
Hunkered Down for the Duration
The reason many companies parrot the standard is simple - It *used* to be that the auditors would go through the standard and ask where and how a clause was addressed. In the early days of implentation in the 1990's it was easiest to 'parrot' the standard so that the auditor couldn't say that a company failed to address part of the standard, or even that they simply didn't address a certain sentence, phrase or paragraph. I myself used to HIGHLY recommend it. I found too many auditors would ask about something and the company would say something like "We don't do that so we didn't write anything about it" to which the auditor would respond with a nonconformance for "...not addressing it in some way even if you don't do it...". So - It wasn't all laziness. It forced you to look at every sentence of the standard and address the requirement by reference or otherwise (such as making a statement like "We don't do this").
Times have changed and so have how auditors audit (not to mention changes in the standard). None the less (get ready to throw rocks) I have no problem with a company parroting the standard in their 'quality' systems manual (I prefer to call it a business systems manual) and addressing each applicable section, paragraph (what ever breakdown you like) by reference to the appropriate company document, or to address the requirement in the manual its self. It makes it very easy to ensure everything is addressed and ties everything together.
surendro - 2009
I don't think quoting the standard would be the right thing. You need the standard as a guide to develop your quality manual. Therefore, all that you have to do is carry out a gap analysis between what the standard requires through its various clauses and your present documents. Wherever, you find any gap create additional documentation to meet the requirements of the standard. I hope, I am clear.
thanks,
Surendro
Mike S.
Happy to be Alive
Marc said:
The reason many companies parrot the standard is simple - It *used* to be that the auditors would go through the standard and ask where and how a clause was addressed. So - It wasn't all laziness.
I agree it wasn't all laziness. Often it was people trying to get by the best way they knew how -- overworked QM's trying to keep their jobs, make picky auditors happy, and get their bosses off their backs. Walk in those shoes and you will understand.
Totumfrog
I recommend using the same numbering scheme for your quality manual as the ISO/TS numbering scheme so you know that you have addressed all of the necessary requirements but the way that each requirement is met should be unique to your company and shouldn't simply "parrot" the ISO standard overall. There may be some instances when you simply restate that you will do something, (I.E. stating that your management review input will include results of audits, customer feedback, process performance etc per 5.6.2) but ultimately your manual should be an overview of your unique processes. I've seen manuals on the net that are roughly 12-15 pages long. Ours is 43. Some may say that is too long but we have written our manual to represent our company and not some cookie cutter outline.
ralphsulser
Well said Mike, ...been there done that
M 2 Quality Manuals after merging with another company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D What is the basis for having 1 or 6 Quality Manuals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Combining Quality Systems (Manuals, etc.) in two Companies Document Control Systems, Procedures, Forms and Templates 3
K Separate Quality Manuals for Different Sites Quality Management System (QMS) Manuals 3
K Different Food Safety and Quality Management System Manuals Food Safety - ISO 22000, HACCP (21 CFR 120) 9
A I need some quality manuals for quality system - Tire or polymer and rubber industry Quality Management System (QMS) Manuals 1
B Are all quality manuals essentially the same? Quality Management System (QMS) Manuals 14
P Example ISO 13485 Quality Manuals/Systems Quality Management System (QMS) Manuals 6
D Customer's Supplier Quality Manuals used by Auditor in a TS 16949 Audit IATF 16949 - Automotive Quality Systems Standard 54
D Exclusions and Conflicting Quality Manuals between Plants and Divisons Quality Management System (QMS) Manuals 10
M How many Quality Manuals does your company have? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
M Totally confused over changes to issue numbers - Quality & procedures manuals Document Control Systems, Procedures, Forms and Templates 12
J Quality Manuals and Quality Plans - Whats the difference? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
P Simple Quality Systems Manual - Do we really need bloated Quality Manuals Quality Management System (QMS) Manuals 9
D Customer Quality Manuals - Document of external origin and must be controlled? Document Control Systems, Procedures, Forms and Templates 14
J Two locations, one is a Remote Site - 1 or 2 Quality Manuals? Quality Management System (QMS) Manuals 3
I Could I see a few sample Quality Manuals Quality Management System (QMS) Manuals 7
WALLACE Are there any flowchart type quality manuals available for viewing? Quality Management System (QMS) Manuals 15
A Calling / Referencing National Standards in Quality Manuals Quality Management System (QMS) Manuals 1
D Consolidation of Quality Manuals Quality Management System (QMS) Manuals 3
K Two Quality Manuals? ASME wants it's own manual! Quality Management System (QMS) Manuals 1
M Quality Metrics Questions Lean in Manufacturing and Service Industries 2
F Quality manual for trading company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
John Broomfield Informational Terms used in quality management [Deleted] Misc. Quality Assurance and Business Systems Related Topics 6
D Imaging/Image Quality Standards Other Medical Device Related Standards 1
D Quality Team Structure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
C Quality assurance in Pharmacovigilance Document Control Systems, Procedures, Forms and Templates 0
I Quality Policy and Objectives examples Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 4
Miner Quality checks of product QR codes FMEA and Control Plans 2
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 15
M Operational (free) simulation games for manufacturing and quality Lean in Manufacturing and Service Industries 5
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
F Risk for Quality Assurance Department in a Hospital - Hospital Incident Reporting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I New to LEAN but not to Quality - How to run Kaizen events Lean in Manufacturing and Service Industries 1
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 8
S Cost of Poor Quality (CoPQ) - Scrap element of calculation includes lost margin? Misc. Quality Assurance and Business Systems Related Topics 7
S Quality manager considering data science Quality Manager and Management Related Issues 19
M Specific Values of Quality Objectives Benchmarking 5
J How to make Quality Control plans Quality Tools, Improvement and Analysis 4
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
T Question about Quality Department employee position titles Quality Manager and Management Related Issues 7
C Quality Manager vs Warranty (service) Manager - Authorities & Responsibilities Customer Complaints 2
S Proposed Quality Improvement - Thoughts? Medical Device and FDA Regulations and Standards News 3
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
was named killer CLOUD BASED QUALITY DOCUMENTATION vs. SERVER BASED Document Control Systems, Procedures, Forms and Templates 5
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 3
W Air Quality Measurement Hardware and Software General Measurement Device and Calibration Topics 11
