Quality Plan at a small Medical Device Company - Is the quality plan a DMR document
snoopy2017
Hi everyone,
This has been such a helpful forum.
I am planning to work on a quality plan at our small medical device company. Is the quality plan a DMR document? Where should it exist?
Thank you very much. :thanx:
Ronen E
Problem Solver
Moderator
Re: Quality Plan at a small Medical Device Company - Is the quality plan a DMR docume
The quality plan is not normally a part of the DMR, although there may be some overlap (and the QP may reference the DMR instead of duplicating). Normally the QP is an independent item, one of the top-level documents of the QMS.
From the FDA’s QSIT (inspection guidance):
Much of what is required to be part of the plan may be found in the firm's quality system documenta-tion, such as, the Quality Manual, Device Master Record(s), production procedures, etc. Therefore, the plan itself may be a roadmap of the firm's quality system. The plan in this case would need to include reference to applicable quality system documents and how those documents apply to the device(s) that is the subject of the plan.
Quality plans may be specific to one device or be generic to all devices manufactured at the firm. Quality plans can also be specific to processes or overall systems.
For a small company (with a single or a few device models) I would recommend having a single, generic QP for all device models designed and manufactured by the company, with a statement that all referenced QMS documents apply to all these devices. Some details may be added as necessary but I wouldn’t go into too much detail as this is supposed to be a high-level document (“roadmap”, as above), and to avoid the need for frequent updates.
L
locutus
For a small company, I usually suggest an "annual quality plan" basically a document that is created each year that talks about what the company is doing. This can be general routine things or very specific activities. Also, highly recommend obtaining and reviewing ISO 10005 standard as this is quite helpful and provides some examples in the Appendix.
An annual quality plan could address things like:
- Reference to the audit programme
- When management review meetings are held
- When external audits are held (ISO cert audits)
- Documentation review
- Regulatory review
- Regulatory license renewals
Then if you need create specific quality plans for activities like a company acquisition or moving facility. Personally, my own thoughts are that a DMR is kind of like a quality plan because it tells how to make the product - bit of a stretch for the definition, but many also term their "quality plan" as the DMR. No problem referencing a quality plan from the DMR though.
Ronen E
Problem Solver
Moderator
Reading 21 CFR 820 and QSIT I find it a little difficult to see how the QP can be termed DMR or vice versa. I also don’t understand why the DMR should reference the QP (the QP described in part 820 and QSIT; I’m not familiar with 10005). At most, the DMR would reference documents that the QP may reference too (which is not the same as referencing the QP itself).
Hello
Could anyone possibly help me in preparing Quality plan (as per ISO 13485:2016) for AI enabled Medical software company by providing some sample/ template of the same?
Thank you
yodon
First off, 13485 doesn't require a quality plan but does require a Quality System. Do you have a Quality System? If that's what you're asking for, I would caution against using someone else's templates - they may not be a fit for your company - especially an AI-driven device company (mostly uncharted territory). If you're trying to put together a quality system and you don't have the background, I would suggest engaging with a consultant.
I don't know of any general guidance docs on AI systems. In general, though, in addition to 13485, you'll want a quality system compliant with IEC 62306 (Medical Device Software lifecycle processes). You'll want to conduct risk management per ISO 14971.
The FDA (with full recognition this is posted under the 13485 forum) has a proposed regulatory framework paper. That will likely drive some of your processes.
Cybersecurity is on everyone's mind these days so you'll want to find and incorporate applicable cybersecurity guidance. Pretty much every country / jurisdiction now has something.
The point is, doing what you ask is not a trivial matter by any means. There are very few AI systems on the market so you're unlikely to get anything very appropriate for your company.
Thank You for your reply. And yes I was asking about Quality plan only and wasn't sure if it's mandatory. I have already considered IEC 62304 and ISO 14971 for QMS implementation but was looking for particular guidance for AI-driven software.
Anyways, Thank you so much for your post. I got somewhat better idea for implementation of ISO 13485:2016.
N AQL (Acceptable Quality Level) Sampling Plan for Small Lots AQL - Acceptable Quality Level 8
J Quality Plan template needed - Small machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Customer Care Quality Assurance Plan in a Small Computer Desktop Assembly Company World News 6
F EU MDR Quality Plan template CE Marking (Conformité Européene) / CB Scheme 3
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
R Electrical contractor Project Quality Management Plan Quality Manager and Management Related Issues 1
qualprod Annual SWOT for 4.1? I plan to revise quality objectives and strategic route ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
L Quality Manual for a Quality Plan (Manufacturing secrets?) Request Misc. Quality Assurance and Business Systems Related Topics 1
D API 5CT Compliant Quality Plan for Manufacturing Manufacturing and Related Processes 0
Q What is a Quality Charter and how does it differ from a Quality Plan? Quality Manager and Management Related Issues 4
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
L Quality Plan to decommission a Medical Device Facility Decommissioning and Transfer Quality Manager and Management Related Issues 1
S Quality Assurance Plan template for CNC Milling Industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Need suggestion on Software or App for Tracking Quality Plan Status Software Quality Assurance 1
A Quality Plan - Inspection method, equipment list for inspection of a Spur Gear Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K NPI (New Product Introduction) Quality Plan Outsourced Manufacturer/Supplier APQP and PPAP 3
L Difference between a Quality Plan and Inspection & Test Plan (ITP) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P What should a Quality Plan Include and Examples Misc. Quality Assurance and Business Systems Related Topics 3
M Large Construction Project Quality Plan - ISO 9001-2008 using ISO 10006 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G QMS Quality Plan Documents Software Document Control Systems, Procedures, Forms and Templates 4
M Business Plan vs Quality Plan in the TS16949 standard Benchmarking 5
I Contingency Plan that meets requirements of API Q1 Quality Management System Other ISO and International Standards and European Regulations 3
A Quality Plan for Plastic Industry for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Requirements of a TS 16949 Quality Plan IATF 16949 - Automotive Quality Systems Standard 2
R Quality Plan for Cookies and Crackers - Baking Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Quality Plan Template for producing a New Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 8
5 MDD Quality Plan Templated Wanted Document Control Systems, Procedures, Forms and Templates 2
L Electrical Cable Harness Quality Control - Sampling Plan for Pull Test Manufacturing and Related Processes 4
Z Quality Assurance Plan for Engineering Service Industry Quality Manager and Management Related Issues 1
V Improvement Plan for existing QUALITY TEAM Quality Manager and Management Related Issues 6
Q PQP (Project Quality Plan) and QCP (Quality Control Plan) Differences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Quality Plan Revisions and Numbering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
I Quality Assurance Business Plan & Strategy Quality Tools, Improvement and Analysis 3
C Quality Management Plan example wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Quality Manual and Quality Plan for Customer Experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B QCP (Quality Control Plan) from client with EN 10204 type 3.1 Material Certificates Various Other Specifications, Standards, and related Requirements 2
M What is a Quality Assurance Plan? Help with Content for a Sea Port QA Plan Misc. Quality Assurance and Business Systems Related Topics 8
somashekar Can Documents of External Origin be a Quality Plan? ISO 13485:2016 - Medical Device Quality Management Systems 2
K I need a Quality Plan template Document Control Systems, Procedures, Forms and Templates 3
I Business Plan for Setting Up a Quality Department Quality Manager and Management Related Issues 4
Q Vendor (Supplier) Quality Plan vs. Our QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Y Improvement Projects and Quality Plan (Examples and Advice needed) ISO 13485:2016 - Medical Device Quality Management Systems 6
V Quality Plan (Inspection, Recording and Corrective Actions) Records and Data - Quality, Legal and Other Evidence 2
P EASA 145 (145.A.30) Man Hour Plan for Quality Monitoring EASA and JAA Aviation Standards and Requirements 2
E Quality Plan for Relocation of our Production Document Control Systems, Procedures, Forms and Templates 8
K ISO 9001 Compliant Project Quality Plan Requirements Misc. Quality Assurance and Business Systems Related Topics 4
A Supplier Quality Plan for Service Providers - Assistance and advice wanted Supplier Quality Assurance and other Supplier Issues 2
