Quality Plan for ISO 9001 and ISO 13485 - Template or Example Needed
Coury Ferguson
Moderator here to help
Re: Quality Plan template
Qualityalways said:
Hi all,
I searched through the Cove for a good Quality Plan but could not find one. Can some one share ?
You will need to be more specific on your request. Quality Plan is pretty general.
Ajit Basrur
Re: Quality Plan Template or Example Needed
No I tried different search words but didnot come across a good template for Quality Plan in the Cove. When I searched the internet for quality plans, came across Batch History records.
Are Batch History records similar to Quality plans. If yes, what is the difference between Batch History Record, Device History Record and Quality plan ?
F
favqty
Quality plan should be generated as a sum of all the control plans defined to assure customers satisfaction.
It is usefull to define control plans for each process you think are critical to satisfy your customers, them you relates, sequentially, all of them and woila, you get your quality plan.
It is some easy and accurate way to generate it. There may be some other ways. This is the method I would like to recommend. I hope helps you.
Have a good one!!
G
Greg B
Hi all,
Why do you want a Quality Plan??? Where does it say in the Standard that you require one? If your registrar asks for one tell them that you don't require one!!!!
Does your company have a business plan? Do they use a balanced Score card? Do they have business KPI's? This is the information that runs your business. This is the information that will make or break your business! These are the integral parts of your, so called, Quality Plan. It is your Business Plan! Don't try and bend your business systems to the standard ,rather, build your quality system around your business.
Ajit Basrur
We are ISO 9001 and ISO 13485 certified. One of our customers wanted us to have a Quality Plan as a High level document.
G
Greg B
Ask the customer WHY????. Send them a copy of your certification certificate and that should be enough. I ,truly, do not understand why a CUSTOMER would want OR need another company's Quality Plan (if such a thing existed). If they insist then send them a copy of your Quality Manual and Policy. These are the per-eminent documents in your Quality System and spell out how you go about your business. If they persist then get them to show you a copy of THEIR quality Plan.
PS: If you get it, then please post it here (minus their name) so I can dissect it. :D
Added a little later
5.4 Perform Quality Planning
5.4.1 Define company Quality Objectives (aka Business KPIs)
Measurable Targets and Objectives must be defined:
1. For each part of your Quality Policy.
2. For each functional area in your company.
3. To help with product realization.
4. At each of the company's organizational levels.
5.4.2 Plan Quality Management System. (aka 'Management Review Meetings')
1. QMS implementation must be planned and implemented, if it is not already in place.
2. QMS improvements must be planned and implemented over time, as necessary.
IF they really, really really want a plan then give them a copy of your 'Management Review Schedule and an agenda' (Here is my procedure for it)
M Large Construction Project Quality Plan - ISO 9001-2008 using ISO 10006 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Quality Plan for Plastic Industry for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K ISO 9001 Compliant Project Quality Plan Requirements Misc. Quality Assurance and Business Systems Related Topics 4
R ISO 17025 sufficient enough to drop ISO 10005 Quality Plan? ISO 17025 related Discussions 1
S Quality Auditing System - Audit Plan per guidance from ISO 19011 Internal Auditing 8
N Template for a Quality Plan upgrading to ISO 13485 from ISO 9001 ISO 13485:2016 - Medical Device Quality Management Systems 2
J Internal Audit NC ISO 9001 Clause Mapping - Quality Objective Achievement Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 in construction organization: Your thoughts (quality control plan, etc) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
P Looking for Quality Plan Examples - Medical Devices - ISO 13485 Misc. Quality Assurance and Business Systems Related Topics 3
B Quality Plan for ISO 9001-2000 - Assembly and Custom Build process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Quality Objectives ISO 9001:2000 - Is an action plan required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G What is an ISO 9000 Quality Assurance Plan? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A ISO 9001 Quality Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO 9001:2000 Process Based Internal Quality Audit Plan General Auditing Discussions 11
C Example ISO 9001 Quality Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 41
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
R Electrical contractor Project Quality Management Plan Quality Manager and Management Related Issues 1
qualprod Annual SWOT for 4.1? I plan to revise quality objectives and strategic route ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
L Quality Manual for a Quality Plan (Manufacturing secrets?) Request Misc. Quality Assurance and Business Systems Related Topics 1
S Quality Plan at a small Medical Device Company - Is the quality plan a DMR document ISO 13485:2016 - Medical Device Quality Management Systems 6
D API 5CT Compliant Quality Plan for Manufacturing Manufacturing and Related Processes 0
Q What is a Quality Charter and how does it differ from a Quality Plan? Quality Manager and Management Related Issues 4
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
L Quality Plan to decommission a Medical Device Facility Decommissioning and Transfer Quality Manager and Management Related Issues 1
S Quality Assurance Plan template for CNC Milling Industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Need suggestion on Software or App for Tracking Quality Plan Status Software Quality Assurance 1
A Quality Plan - Inspection method, equipment list for inspection of a Spur Gear Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K NPI (New Product Introduction) Quality Plan Outsourced Manufacturer/Supplier APQP and PPAP 3
L Difference between a Quality Plan and Inspection & Test Plan (ITP) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P What should a Quality Plan Include and Examples Misc. Quality Assurance and Business Systems Related Topics 3
G QMS Quality Plan Documents Software Document Control Systems, Procedures, Forms and Templates 4
M Business Plan vs Quality Plan in the TS16949 standard Benchmarking 5
I Contingency Plan that meets requirements of API Q1 Quality Management System Other ISO and International Standards and European Regulations 3
M Requirements of a TS 16949 Quality Plan IATF 16949 - Automotive Quality Systems Standard 2
R Quality Plan for Cookies and Crackers - Baking Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Quality Plan Template for producing a New Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 8
5 MDD Quality Plan Templated Wanted Document Control Systems, Procedures, Forms and Templates 2
L Electrical Cable Harness Quality Control - Sampling Plan for Pull Test Manufacturing and Related Processes 4
Z Quality Assurance Plan for Engineering Service Industry Quality Manager and Management Related Issues 1
V Improvement Plan for existing QUALITY TEAM Quality Manager and Management Related Issues 6
Q PQP (Project Quality Plan) and QCP (Quality Control Plan) Differences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Quality Plan Revisions and Numbering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
I Quality Assurance Business Plan & Strategy Quality Tools, Improvement and Analysis 3
C Quality Management Plan example wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Quality Manual and Quality Plan for Customer Experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B QCP (Quality Control Plan) from client with EN 10204 type 3.1 Material Certificates Various Other Specifications, Standards, and related Requirements 2
M What is a Quality Assurance Plan? Help with Content for a Sea Port QA Plan Misc. Quality Assurance and Business Systems Related Topics 8
somashekar Can Documents of External Origin be a Quality Plan? ISO 13485:2016 - Medical Device Quality Management Systems 2
