Quality records kept "off site", is it ok or not?
Martijn
Dear Covers, here's a question for you:
Is it ok to have a quality record (in this case a registration of calibration) that is not available on the location where the certificate is issued for (our sales HQ) but is only available at the place where it's being used (in this case our salespeoples home offices, from which they work).
My certifying auditor said the lack of these records in HQ was a non conformance because he couldn't audit it, but if he wants to audit our sales process shouldn't he have decided to audit the salesperson on site at a customer or in his home office? In other words, do we have to keep a double record, just for the certifying auditors ability to audit then.
Coury Ferguson
Moderator here to help
Martijn,
As long as they are readily retrievable I don't see a problem, in my opinion. Would they be able to fax the copies when requested or deliver them within a reasonable amount of time?
Coury Ferguson
There is no requirement to maintain the records on-site. However, you do have to reasonably accommodate an auditor. All auditors that I have dealt with only require that the records be available for audit within a reasonable time.
This reasonable time has varied from "by the end of the day" to "before the auditors adjourn to prepare for the closing meeting". A faxed copy has always been acceptable.
Martijn said:
...not available on the location where the certificate is issued for (our sales HQ) but is only available at the place where it's being used ...
Like the others, I would happily accept a faxed copy of the record. I also think it is reasonable that equipment and record can be found in close proximity to each other...
Martijn said:
My certifying auditor said the lack of these records in HQ was a non conformance because he couldn't audit it.
Did he really? If so, I wonder how he was planning on checking the equipment? Would he like a copy of that at HQ as well?
Martijn said:
...do we have to keep a double record, just for the certifying auditors ability to audit then.
Absolutley not. As always, the system should fit the users needs, and I can see no point in double records.
/Claes
RoxaneB
Bingo. The organization determines the process that works for them and if that means the records are maintained at the point-of-use, so be it. However, as Miner said, having the ability to provide the record to the auditor is the main issue...and this could mean either visiting Mr. Sales Person or having the record faxed in.
That being said...what does your procedure for record control state? Do you say that calibration records will be maintained on site? If so, then the finding sounds like it could be legit.
ScottK
Not out of the crisis
When it's time for re-calibration how does that work? Does the item come back to HQ where it is either calibrated or sent for calibration? If so then you should have a record in order to maintain traceability.
If it was sent for recalibration to a 3rd party then purchasing should have a record of the PO, specifying the calibration standard(s), and an invoice even if the actual record travels with the device.
If it was calibrated in-house, then the calibration lab should have at least a copy of the calibration results.
Martijn
Thank you all for your replies. I'm probably going for a digitally/faxible calibration record from home offices. Might even make some sort of lotus notes database out of it.
You're right about this one, this is how it became a finding to begin with, but then i told him i was considering changing the record procedure stating calibration records can be kept at home offices as well, and then he said that won't do for him.
edit: and all the calibrations are done at home/in the car (not while driving)/at the customers lab
:thanx:
RoxaneB
:thanx:
It sounds as if there is a finding here but not quite the way the auditor phrased it. I would have identified the gap between the documented procedure and the acutal practice.
From there, as part of your action plan to address it, you could revise the document to reflect the actual proces...or re-instill the process to match the document.
As to where the records are maintained, as long as they are readily retrievable and safe from harm, there shouldn't be a problem. I think that your auditor's problem is not so much with their physical location, but how you will be able to guarantee that the records will be safe from damage if kept at the sales person's home/car.
Fire? Theft? Flooding? Accident?
Do these sales people have in-house safes or some other means by which to guarantee the safety of the records?
ScottK
:thanx:
just to play devil's advocate:
since the devices are calibrated by the user... what about the standards that they are calibrating to?
but I must also ask... are the devices actually being calibrated by the sales guys or are they just verifying calibration in the field?
There's no difference between the two; calibration doesn't necessarily imply adjustment.
H Must I mention "records kept" in the Quality Manual itself ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
U Manufacturing solutions and keeping records on quality Content CE Marking (Conformité Européene) / CB Scheme 3
I Date of Quality Management System - Training Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q Do hard copies of quality records have to be retained? ISO 13485:2016 - Medical Device Quality Management Systems 2
R Custom Records and Quality Systems - Products that change frequently Other US Medical Device Regulations 3
B Quality Records - Should any record be signed? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Records Destroyed - Hurricane Harvey has likely destroyed our Quality Systems Records Records and Data - Quality, Legal and Other Evidence 10
R 21 CFR Part 820.186 - Types of Quality System Records Document Control Systems, Procedures, Forms and Templates 1
S Retention time requirement for various for quality records Records and Data - Quality, Legal and Other Evidence 1
S Atlassian and Plugins for Quality System/Records? Quality Assurance and Compliance Software Tools and Solutions 1
C Incremental revisions to Quality Manual, and Training Records Document Control Systems, Procedures, Forms and Templates 2
M Contractors with poor Quality Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Integrating acquired existing product into Quality Management System Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Are all In-Process Quality Records required in final QA Batch Record Review. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Quality Records (QR) Control Codes Records and Data - Quality, Legal and Other Evidence 13
J Quality Records Register Requirements - ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 31
L Storage Cabinets for Quality Documentation (Procedures and Records) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P NQA-1 Requirement 17 Quality Records - Facility Types and Temporary Storage Various Other Specifications, Standards, and related Requirements 5
M Suggestions for Handling Quality Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What to do about missing Quality Records? Records and Data - Quality, Legal and Other Evidence 11
M Quality Records Matrix Content and Revision Records and Data - Quality, Legal and Other Evidence 6
N Quality Records - Password and Anti-virus Protection Records and Data - Quality, Legal and Other Evidence 3
H Review and Approval in Quality Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Creating a "Records Policy" - Control of Quality Records Records and Data - Quality, Legal and Other Evidence 13
P Obsolete Quality Records - Approval Prior to Disposal Records and Data - Quality, Legal and Other Evidence 15
I Do ALL Quality Records Require Approval? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Quality formats - ISO 13485 Design and development related records and formats ISO 13485:2016 - Medical Device Quality Management Systems 7
S Retention Periods of Quality Records Records and Data - Quality, Legal and Other Evidence 1
A Examples of Quality Records Master List ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Corrective Action for lost project quality records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Are environmental compliance documentation quality records? Document Control Systems, Procedures, Forms and Templates 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
S Retention time of quality records for parts with Critical (safety) Characteristics? Document Control Systems, Procedures, Forms and Templates 2
C Need a procedure or outline on Good Practices for Completing Quality Records/Document Document Control Systems, Procedures, Forms and Templates 2
Q Signature on Management Review Minutes - Quality Records ISO 13485:2016 - Medical Device Quality Management Systems 5
T Sample Retention Requirements - Quality Records procedure - ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 8
A Action on Quality Records - Approve, Update and Carry Out Revision Control Records and Data - Quality, Legal and Other Evidence 10
T Is there a minimum retention time for any of the Quality Records? ISO9001 Records and Data - Quality, Legal and Other Evidence 8
K Records - Are weekly purchasing reports, backlog reports, etc., Quality Records? Records and Data - Quality, Legal and Other Evidence 4
R Procedure does not adequately identify quality records - Audit Minor NC - Why? General Auditing Discussions 8
H Formats for Master List of Quality Records (MQR) & Document Change Request Form (DCR) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Minimum Quality records required by ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
C How often will I update the quality records list? We have about 189 quality records Document Control Systems, Procedures, Forms and Templates 6
M Defined retention time of quality records - ISO 9001:2000 Paragraph 4.2.4 Records and Data - Quality, Legal and Other Evidence 10
N What are the minimum quality records required by QS-9000? Records and Data - Quality, Legal and Other Evidence 1
G Trigger Point - Determining When We Can Dispose of Quality Records Records and Data - Quality, Legal and Other Evidence 11
L Good Documentation (Quality Records) Practices - Dittos? Arrows? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Identification of Quality Records (ISO9001 - 4.2.4) - How? Records and Data - Quality, Legal and Other Evidence 32
C New company - How much quality records history required? Records and Data - Quality, Legal and Other Evidence 3
