Quality System Manual Revision Control when the manual has sections
assyrian47
A QSM is made up of a number of sections. Typically changes to the QSM are made on a section by section basis. When a QSM is released ISO says make it REV A. QA-QSM-900 Rev A is the document number I have assigned our QSM manual.
If in the next month I change two sections, they are revised to REV B. Do I have to publish a new QA-QSM-900 Rev B or can I use a QSM revision history page after the table of contents that will list the Rev Level and Date for all sections in the manual.
TIA
TIA
Sounds like you're overcomplicating the issue. Why do you need separate control for the various sections of your manual? If you have a contiguous manual (i.e., all of the sections are kept together), you need only top-level revision control. If, on the other hand, your "sections" are actually documented procedures that are maintained and kept separate from the manual, you need control over the manual and each documented procedure. When you reference the procedures in the manual, you don't need to cite the current revision of the procedures, which obviates the need to "bump" the revision level of the manual when procedures are changed.
Randy
1st....ISO doesn't say to do anything other than to ensure that changes and current revision status of documents are identified.........You say how it is to be done.
2nd.........Is the document Rev B the same as document Rev A? Your statement and this question answer that, if the document is not the same as to content or whatever the history record alone isn't going to cut it.
Big Jim
As others pointed out, you get to choose how to control your documents. Revising just the sections to Rev B is certainly one way to do it You could also call the revised section Rev A1 and continue numbering in that manner until you revise the entire manual to Rev B.
Figure out an easy system that works for you and then make sure your documentation of how you do it is compatible with your practice.
Y Quality Management System Manual (Wood Manufacturing Company) Quality Management System (QMS) Manuals 4
S Is there any difference between QUALITY SYSTEM RECORD & QUALITY MANUAL 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G AS9100 Rev C QMSM (Quality Management System Manual) Template Required AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Combine ISO 9001 and AS9100 into a single Quality Manual and System? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Quality Management System - Manual Document Control Systems, Procedures, Forms and Templates 3
D Quality System Manual - Exclusions from ISO 13485 Clause 7.5 ISO 13485:2016 - Medical Device Quality Management Systems 4
K Quality System Manual question - Adding Satellite Facility ISO 13485:2016 - Medical Device Quality Management Systems 2
E Starting to write a Quality System Manual - Import/export medical devices - Need help ISO 13485:2016 - Medical Device Quality Management Systems 1
L Business Operations Manual & Quality Management system Quality Management System (QMS) Manuals 6
D How to Reorganize the existing Quality System Manual Quality Management System (QMS) Manuals 4
L AS9100B Quality System Manual: Need an example! Quality Management System (QMS) Manuals 7
W Supplier Quality Manual and Supplier Quality System Audit Format Supplier Quality Assurance and other Supplier Issues 3
Q Writing a QMS (Quality Management System) Manual from Scratch Quality Management System (QMS) Manuals 2
L Integrated Quality System Manual for ISO 9001 - ISO 17025 ISO 17025 related Discussions 7
J Quality System Manual - We have a section of our QSM entitled Servicing ISO 13485:2016 - Medical Device Quality Management Systems 1
K Quality Management System Manual question - References at the end of each section Quality Management System (QMS) Manuals 11
S Seeking: Example TS 16949 QMS (Quality Management System) Manual Quality Management System (QMS) Manuals 1
D Has anyone written a Quality Manual for a Small Company Quality System? Quality Management System (QMS) Manuals 13
D QMS (Quality Management System) Manual - The Boss Wants a 4 Page Manual - What to Do? Quality Management System (QMS) Manuals 455
M Unique Quality Management System for 2 sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Quality System Functional Safety Checklist / Guidance IATF 16949 - Automotive Quality Systems Standard 0
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D Big companies suffer from quality management system? ISO 13485:2016 - Medical Device Quality Management Systems 1
R How would you work without a quality management system? IATF 16949 - Automotive Quality Systems Standard 3
P Conformity assessment based on a quality management system or production quality assurance EU Medical Device Regulations 3
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
P How to develop executable quality management system for rookies? IATF 16949 - Automotive Quality Systems Standard 9
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
A Building up a global quality management system ISO 13485:2016 - Medical Device Quality Management Systems 2
A Building up a global quality management system 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 3
B Include cost of quality (and other wastes) in an ISO 9001 system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
J Quality Assurance in China - Developing a quality management system for a California company Misc. Quality Assurance and Business Systems Related Topics 9
I Date of Quality Management System - Training Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Procedure on Privacy Policy in the ISO 13485 quality management system ISO 13485:2016 - Medical Device Quality Management Systems 3
S Defining a Quality System from scratch - Preferred system and documentation names Document Control Systems, Procedures, Forms and Templates 4
B EU MDR Quality System Requirements - Applicable to Class I? EU Medical Device Regulations 5
M Informational US – National Evaluation System for Health Technology Coordinating Center (NESTcc) Solicits Public Comments for Data Quality and Methods Frameworks Medical Device and FDA Regulations and Standards News 0
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
D Templates for Environmental, Safety and quality Management System wanted Document Control Systems, Procedures, Forms and Templates 3
B Quality Management System documentation identification Document Control Systems, Procedures, Forms and Templates 11
M Quality System Processes without Documented Procedures Document Control Systems, Procedures, Forms and Templates 39
QIE Anyone have experience with BPA Quality (QMS system based on Office365/Sharepoint) Quality Assurance and Compliance Software Tools and Solutions 1
eule del ayre Lean Six Sigma for Quality Management System Lean in Manufacturing and Service Industries 10
S Quality System Induction Training for New Employees Training - Internal, External, Online and Distance Learning 16
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
