Definition Quality - The ISO definition of Quality
Which is the definition of quality?
  • Quality (noun)
    Votes: 1 33.3%
  • Quality (adj.)
    Votes: 1 33.3%
  • None of the above
    Votes: 1 33.3%
  • Total voters
    3
  • Poll closed .
jasonb067
There are two primary definitions of quality in the Merriam – Webster dictionary.
Quality (noun)
1
a : peculiar and essential character : nature <her ethereal quality — Gay Talese> b : an inherent feature : property <had a quality of stridence, dissonance — Roald Dahl> c : capacity, role <in the quality of reader and companion — Joseph Conrad>
2
a : degree of excellence : grade <the quality of competing air service — Current Biography> b : superiority in kind <merchandise of quality>
3
a : social status : rank b : aristocracy
4
a : a distinguishing attribute : characteristic <possesses many fine qualities> b archaic : an acquired skill : accomplishment
5
: the character in a logical proposition of being affirmative or negative
6
: vividness of hue
7
a : timbre b : the identifying character of a vowel sound determined chiefly by the resonance of the vocal chambers in uttering it
8
: the attribute of an elementary sensation that makes it fundamentally unlike any other sensation
Quality (adj)
: being of high quality
My question is which (if either) of these two definitions are the ISO using in defining Quality management systems? If none of the above then what definition do you suppose is being used?
P.S. I feel that this is something which has been discussed here before but I can not find it. If it is here somewhere I am sorry.
Re: ISO definition of quality
One thing that struck me immediately with the latest revision of ISO 9001, is they removed the language of product quality to product conformity to requirements.
It is kinda interesting that a Qualtiy Management System - Requirements standard removed the word quality from the language. :notme:
JQuality
The term "quality" is a lot more subjective than saying "requirements specified by the customer" or, "conform to product requirements". I think that it's an important distinction.
Pancho
wikineer
I personally like Robert Pirsig's definitions (or non-definitions) of Quality from his book Lila, Ch. 5:
Quality doesn't have to be defined. You understand it without definition, ahead of definition. Quality is a direct experience independent of and prior to intellectual abstractions...
To the intellect the process of defining Quality has a compulsive quality of its own. It produces a certain excitement even though it leaves a hangover afterward...
What the Metaphysics of Quality would do is take this separate category, Quality, and show how it contains within itself both subjects and objects. The Metaphysics of Quality would show how things become enormously more coherent — fabulously more coherent — when you start with an assumption that Quality is the primary empirical reality of the world . . .
Yup, that's the assumption to make.
:D
jasonb067
This exactly why I vote number 2. This standard is directing a management system which the ISO believes is a quality methodology of management. I know this is obvious to those that know the contents but too many make assumptions of scope based on title alone.
Big Jim
From ISO 9000:2005
quality: degree to which a set of inherent characteristics fulfills requirements.
If you want to dig deeper into that definition, they reference definitions for both requirements and characteristics.
There are also notes showing that "quality" can be used with adjectives such as poor, good, or excellent; and that quality is "inherent" as opposed to "assigned".
Another definition that I often run across is consistency.
V
vanputten
If one does not look at ISO 9000:2005, how would you know if ISO provided a defintion?
The Technical Comittees within ISO use the Oxford English Dictionary if the term is not already defined in a standard.
Parsig's book "Zen and the Art of Motorcycle Maintenace" should be required reading for anyone in the "Quality" field. The book is about trying to define what "Quality" is.
L Definition Quality Management System (QMS) as per ISO 9000:2005 - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 9
B Include cost of quality (and other wastes) in an ISO 9001 system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
S Procedure on Privacy Policy in the ISO 13485 quality management system ISO 13485:2016 - Medical Device Quality Management Systems 3
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
F ISO 13485:2016 Quality Policy Requirements Other ISO and International Standards and European Regulations 18
N ISO 13485 Quality Record Retention Period ISO 13485:2016 - Medical Device Quality Management Systems 4
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
Sidney Vianna ISO/TS 30411:2018 Human resource management - Quality of hire metric Other ISO and International Standards and European Regulations 1
V Discussion of ISO 9001:2015 - "Quality Objectives" term ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
L ISO 9001 - 2015, is the Quality Manual needed? Please advise ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Establishing the quality policy for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A ISO 9001 Help - New Quality Manager - Upper Management Support Issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Supplier Control - Supplier quality management certificates (ISO, etc) ISO 13485:2016 - Medical Device Quality Management Systems 2
R ISO 9001:2015 Transition Quality Manual Update - Redundant Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S ISO 13485 Cl. 5.4.2 - Is Documented Quality Planning required? ISO 13485:2016 - Medical Device Quality Management Systems 2
B Integrated Quality Manual ISO 13485:2003 ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 6
T GDPR impact on ISO 9001 and Quality ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F ISO 9001:2015 4.3 - Determining the scope of the quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R ISO 13485:2016 - Quality Objectives Regulatory Requirement Examples ISO 13485:2016 - Medical Device Quality Management Systems 1
S Is a Quality Policy Statement a Requirement? (ISO 13485) ISO 13485:2016 - Medical Device Quality Management Systems 7
P Quality Assurance and Quality Control - Which clauses of ISO 9001 deal with each? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T ISO 17025 Section 5.9.1 - Assuring Quality of Tests - Requirements ISO 17025 related Discussions 4
R Examples of Quality Objectives related to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
M New Quality Policy for ISO 9001:2015 - Please Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Including the Word "Risk" into the Quality Policy (ISO 9001:2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T ISO 13485:2016 Clause 7.4.2 regarding Supplier Quality Agreements ISO 13485:2016 - Medical Device Quality Management Systems 11
F Quality Manual Updates - ISO 9001:2015 and API Q1 9th Editition Quality Management System (QMS) Manuals 14
A Leadership Responsibility in an ISO 9001:2015 Quality Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
A Quality Policy approach of ISO 9001:2015 Clause 5.2.1a ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
A What is "a router" in ISO/TS 9002 Quality management systems ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
T Does your Quality Dept Control Procedures Outside the Scope of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Quality Manual and ISO TS 16949 Standard IATF 16949 - Automotive Quality Systems Standard 5
M Using our parent company's ISO/TS 16949 Quality Manual IATF 16949 - Automotive Quality Systems Standard 11
N ISO 9001 Quality Manual for an O&M (Operations and Maintenance) Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D Combined Quality Manual for ISO 9001, ISO 14001, ISO 50001 and OHSAS 18001 Document Control Systems, Procedures, Forms and Templates 11
I Quality Procedures (as required by ISO 9001) for Inspection Bodies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y ISO 13485:2003 &FDA QSR (21 CFR 820) Quality Manual,34 Procedures and Form Book, Video, Blog and Web Site Reviews and Recommendations 8
