Hi All
This, I know probably seems like a really dumb question, however everything that I thought I knew, I am starting to really question....causing a massive crash in the confidence of my own abilities.
Put simply, if you save someone in an office, 2 hours performing a particular task, how do you justify the benefit?
Having worked in Lean for a number of years, I have always used the principal that the cost benefit is associated to that particular task in terms of an hourly wage multiplied by the time saved. This also opens up into more qualitative savings (all be it harder to sometimes measure) in being able to spend more time doing more quality critical activities, or training, or maintenance, or 5S.....etc
Obviously, in most cases the person is paid whether or not they are performing that task or not, hence I have always calculated the before and after cost of the particular task I have improved and not the absolute cost of labour, because unless you physically remove someone off the payroll, there is no change.
New manager is telling me that this is completely wrong. That simply saving someone time does not add any value to the business (what they mean by value is money) and isn't a saving as they are still having their wages paid. It can only be a saving if they then spend that time......working on a project which saves money.
So, either I have actually done some worthwhile work, or I have been completely wasting my time as savings quantified (job specific) are not savings at all and I "haven't added any value at all to the business".
Thanks in advance.
Thanks in advance.
