Quantifying the Effect of Excessive Within-Part Variation
I
Iniko
I was trying to use the Average and Range method as described in the “Quantifying the Effects of Excessive Within-Part Variation” with one appraiser (because it’s an automated tester where the operator doesn’t interfere with the readings), 16 unit sample and two trials, in every trial each unit was tested twice so I have a minimum and maximum reading for each unit, in both trials.
I estimated the constants as follows: K1 = 0.87083, K3 =0.2770, I omitted the K2 since I don’t need to calculate the Reproducibility. I’d like to know if I’m correct about these estimations of K1 and K3.
The other thing that I’d like to know is how to calculate the “EVwiv“ term, used in the WIV calculation. Given the K1, I don’t see how to calculate the other term.
Thanks a lot, in advance.
Your K1 = .8862 because you are measuring in two trials. This is not dependent on the min/max measures. Your estimate of K3 appears to be very close.
NWIV = 1 since you only have one appraiser.
RdoubleBar WIV appears to be a misprint and should read Rbar WIV .
Note: It has been a while, but I remember finding a mathematical error in this article before. I duplicated the spreadsheet in Excel and double checked the math in Minitab. My results differed slightly from this article, and the error appear to be in the article.
I will look it up tomorrow and get back with you on it.
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Quantifying Cost Benefits associated with a Particular Task Lean in Manufacturing and Service Industries 3
N Quantifying our QMS Objectives - Your Thoughts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Quantifying "Risk" as a Usable Management Metric Quality Manager and Management Related Issues 3
D Quantifying the benefits of 5S Implementation Lean in Manufacturing and Service Industries 22
J Calculating Repeat Business for the purpose of quantifying a Quality Objective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
Q Autoclave and Sample Container - Pressure-steam cooking's effect Reliability Analysis - Predictions, Testing and Standards 1
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
supadrai Effect of a Merger on Acquired Company's Medical Device Licenses Other Medical Device Regulations World-Wide 2
H New FAQ & SI -IATF 16949 - Effect in april and june 2018 IATF 16949 - Automotive Quality Systems Standard 0
G Effect of ISO9001 2015 transition on ISO IEC 80079-34 Other ISO and International Standards and European Regulations 3
N PFMEA no effect ratings FMEA and Control Plans 15
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
D Is it okay to CE mark the product until the RoHS2 directive goes into effect? CE Marking (Conformité Européene) / CB Scheme 7
N Reason for determining no adverse effect on reworked product ISO 13485:2016 - Medical Device Quality Management Systems 8
S Seeking Feedback on ASQ Guide to Failure Mode and Effect Analysis FMEA and Control Plans 2
D Effect of Fixtures on Test Method Validation Design and Development of Products and Processes 1
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
C CFDA MD regulation_20140331 - Comes into effect June 01, 2014 China Medical Device Regulations 33
M Effect of Boil Test on Passivated SS Medical Instruments Manufacturing and Related Processes 11
F Power supply certification and its effect on testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Does the SIC have an effect on the ISO scope on your certificate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Severity of Effect on Process (Manufacturing/Assembly Effect) Scrap or Reworking FMEA and Control Plans 3
M BS EN ISO 15223-1:2012 replaces EN 980 - What is the effect of the change? Quality Manager and Management Related Issues 44
C Cause and Effect Matrix Template Document Control Systems, Procedures, Forms and Templates 0
B Changes that could effect the Quality Management System - Management Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Length Out of Specification - How do I perform Cause and Effect Diagram? Nonconformance and Corrective Action 6
A Comparing Effect of Process Parameters on Equipment Performance during Start Ups Statistical Analysis Tools, Techniques and SPC 3
P Control of "manufacturing material" that has adverse effect on the medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Effect of Soldering on Tin Plating Manufacturing and Related Processes 5
D Effect of Puncture Orientation on Force Value Other Medical Device Related Standards 1
P Process FMEA with the effect "brakes are broken" - Is it nonconformity? IATF 16949 - Automotive Quality Systems Standard 7
S Root Cause Analysis & Cause and Effect Diagram Customer Complaints 5
M Effect of double ETO (Ethylene Oxide) Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 13
V What effect has Supply Voltage on product performance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Main Effect - Interaction Plots - 2 Level Factorial DOE with 18 Runs Using Minitab Software 8
V Effect of sample size on Cpk results? Using Minitab Software 2
Chennaiite FMEA Severity Rating for Potential Manufacturing Effect mentioned in the FMEA manual FMEA and Control Plans 9
A Cause and Effect Analysis - Hardness of Rubber (i.e., durometer) Quality Tools, Improvement and Analysis 11
Ajit Basrur Pre Filled Syringes (PFS) - Effect of Containers on the Contents 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R EMP (Evaluating the Measurement Process) Studies for Bias Effect Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Sampling Plan - AQL effect on Sample Size AQL - Acceptable Quality Level 9
S The Effect of implementation of an Integrated Management System & EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Cause and Effect Worksheet Quality Tools, Improvement and Analysis 2
M Effect of your Quality Role on your life Coffee Break and Water Cooler Discussions 31
N Uncertainty for Humidity Probes - Temperature Effect from 0.5?C dew point = 1.3%rh Measurement Uncertainty (MU) 2
