Question about IEC 60601-2-10 - Which waveform should I measure?
raymond02302
Hello folks,
I have one qution about the IEC 60601-2-10. It is a very old standard, when i handled project against IEC 60601-2-10, i faced a question as follow. To make it esay to understand, please see find the attached illustration.
In the standard, Cl 51.103 required a indication of output if energe exceed 10mJ per pulse. As shown in the illustration which waveform should i measure ?
My opinion is the burst (sum of a,b and c for case 1;sum of e,f,g and g for case 2), it represent one cycle delivering into patient.
Another opinion is that the energy shoud be measure in a, b or c separately for case 1 and e,f,g or h for case 2.
For the latter opinion, i think it is rare that one pulse can exeed 10mJ for stimulator, for instance, for a pluse (rectangular waveform) with duration of 200 µs (long enough), the amplitude of the waveform shoud be 223V.It is really very high for stimulator.therefore, it make this requirement meaningless.
Any one has idea about it?
thanks in advance.
Raymond
Re: Question about IEC 60601-2-10
Hullo Raymond,
Yes 60601-2-10 is quite old (dated 2000 as an EN but is largely a 1988 standard). It is currently being updated by IEC.
A problem with it that you have identified is that it really only works for stimulators that give out a single pulse at a time; more complex waveforms require some interpretation.
There is no definition of "pulse" in the existing standard, although pulse duration is defined (duration between 50% amplitudes). I have seen a draft of the new standard with pulse being defined as the waveform between two zero crossings. This would suggest that, from your illustration, a b and c are individual pulses and the energy in each pulse should be considered against the 10mJ indicator requirement. This is consistent with how I have considered it as well.
The same requirement applies to outputs above 10mA rms or 10V rms, averaged over 5sec. So this is where you would consider your pulse repitition frequency / bipolar stimulation / duration of stimulation etc.
raymond02302
Thanks for your input.
Commonly, we consider one individual pluse against this requirement. But, it does't stand for actual case. The stimualtor outputs one combined waveform to patient at a time. If the energy of the combinded waveform is too large, there also is unacceptable risk.
Besides, If this requirement is for individual pulse, did you ever see a stimulator with a single pulse more than 10 mJ ? 10 mJ is a very large value for individual pulse whis used in stimualtor.
About the new standard, do you konw when will it be published ? There are many obscurities in the current edition.
Thanks a lot.
Raymond
From the IEC SC62D committee page it is forecast to be available at the beginning of next year, but it looks to be at Committee Draft Vote stage at the moment so still more stages to go. (There still has to be a FDIS stage). At a guess it will be towards the middle of next year.
I did provide some comments to our national committee at an earlier stage but I have no idea whether they have been taken up. One comment I made was on the definition of a pulse and the need to consider more than the simplest of waveforms.
raymond02302
Thanks.
The "pulse" is the key word in this standards,there should be a clear definition for it.
I hope the NC have taken up your comments which will make us work smoothly.
Your effort is appreciated very much.
raymond02302
This question is clear in IEC 60601-2-10 ed 2.0. The amplitude is defied as rms value over 1s, whick I believe is originated from IEC/TS 60479-2 (1 s is corresponding to cycle of heart beat (60s/70bpm). there is no cumulative effect to heart for single phase pulse ).
I compared IEC 60601-2-10 ed 1.1 and ed 2.0 and the comparison table (some comments included)was uploaded
maracu
I have been trying to find if the new (ed 2) 60601-2-10 has been harmonized and when it will be mandatory but with no success. Does anyone have any information on the date yet?
:thanx:
IEC 60601-2-10 was published in June 2012.
The latest Official Journal (in which a listing indicates that a standard is now harmonised) was published in August 2012, which is a bit too quick for a new version to make it in. There should be a new OJ within the next couple of months.
There will probably be a period of 3 years before the old (EN -2-10:2000) version is withdrawn.
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J IEC 60601-1, ed 3.1 - Blue icon question IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R IEC 60601-2-18 Endoscopic Medical Electronic Equipment question IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A IEC 60601-2-24 Question: Free Flow Clamp on Set? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Question on IEC 60601 clause 15.5.1.1 (transformer overheating) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R IEC 60601-1 - RS232 Connector Requirements - Female Connectors question IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
M Predicate Device - Question on Biocompatibility and IEC 60601-1 Testing Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
K IEC 61010-2-100 Labeling question - IVD equipment Other ISO and International Standards and European Regulations 1
S IEC/EN 60335-2-30 cl.30 Plastic Enclosure on Fan Heater question Various Other Specifications, Standards, and related Requirements 2
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
C Gauge R&R Question Using Minitab Software 1
K Question on MDR classification EU Medical Device Regulations 4
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
M Clinical Decision Support Software Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
D Equipment Register and PM question ISO 13485:2016 - Medical Device Quality Management Systems 2
D Question regarding "storage and distribution" ISO 13485:2016 - Medical Device Quality Management Systems 1
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
D Equipment Register related question ISO 13485:2016 - Medical Device Quality Management Systems 1
S Study sign off question / responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
A Question on Authorized Representative in Malaysia Other Medical Device Regulations World-Wide 3
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
T Question for: Cg & Cgk calculation General Measurement Device and Calibration Topics 3
N ASL Question for GitHub ISO 13485:2016 - Medical Device Quality Management Systems 6
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
dinaroxentool Question about FDA Classification of a Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Another DFAR question 252.225-7009 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
F Conflict Mineral Smelter Question RoHS, REACH, ELV, IMDS and Restricted Substances 8
R NRTL - Scope Question - Off-the-Shelf Plug In IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
C MDR - Question around software accesories EU Medical Device Regulations 2
K My question is, what/when is a nonconformity? Therefore what requires an NCR? Nonconformance and Corrective Action 9
Watchcat Authoritative References about the Research Question? Quality Tools, Improvement and Analysis 0
T Question about Quality Department employee position titles Quality Manager and Management Related Issues 10
N Question on creepage/clearance requirements for HF Active Accessories for 2nd edition 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
B QMS question in regards to multiple medical devices/products and N/A activities Other Medical Device Related Standards 12
