Question: How to analyze numerical and attribute data
Is it possible to determine a plausible data point average when using numerical and attribute data? Example: substrates of varying thickness are tested under a constraint for 10hrs and if the substrates withstand the constraint for the allotted time period, this is a pass. If it fails within the time period, this is a fail. Testing is run overnight so there is no evaluation at interval time periods to determine a difference in failure (eg..sub1 fails after 2hrs vs sub2 failing after 5hrs) a fail is an absolute fail. Please let me know if there's a way to analyze this type of data, statistically, in minitab and can the software suggest/predict a possible thickness that will still pass at a lower level (lower than 1 but greater than 0.1)?
You can use a binary logistic regression in Minitab and get results similar to the one shown. However, I did get a warning on this analysis due to the lack of data in the middle. Therefore, the true curve may shift right or left.
Thank you so much!! I will try it. I guess it won't give a prediction for determining a possible pass at levels <1mm? Could I use the tangent of the curve as a potential point (don't know, just asking)?
If you were to have data in the middle region, the curve would be more accurate and you could do as you are asking. However, this particular curve is Minitab's best approximation since the data are missing. Therefore, there is much greater uncertainty.
Unless there is a significant cost to experimenting to fill in the missing data, I recommend doing that. Otherwise, you can start moving closer until results start falling.
Ninja
Looking for Reality
Moderator
A thought that may be a "Yeah, we already knew that"...
If the test period is 10hrs, and you do it overnight (18hrs, assuming single shift)...why not start the test when you arrive in the morning and check in on the parts every 30-60 min?
This could help get you data in the middle region.
Regardless, you also have a HUGE step in substrate thickness, with 100% of thins failing and 100% of thicks passing... do you ever have substrates in the middle thicknesses? If not, plotting a curve seems a bit overkill.
John Predmore
Could you hire an outside lab to run a one time test, and observe periodically (maybe every 20 minutes for 10 hours) for failure? In this way you would obtain variable data on failure points during the 10 hours run. My other idea is if you collect time-to-failure data for all samples, without stopping the test at 10 hours, you would have a better picture of the failure curve distribution, which enables better predictions. A Certified Reliability Engineer might offer other ideas, because they make a science out of failure rate analysis.
I remember one time, my company ran a product durability test that required manual application of a corrosive test fluid, every hour for 48 hours. All the team members voluntarily took a 1 hour shift throughout the night. I did my part, set my alarm for 2:30 am, did a squirt at 3:00 am and then another squirt at 4:00 am before I headed home and back to bed. I know this is not the question @Dannikf asked, but sometimes the barriers we think are insurmountable are really not that hard to overcome, depending on the culture of the workplace.
The data requirement has changed by lowering test time which allowed for a bit more data points. Based on the attached data, how can this be evaluated in minitab? I've been receiving error messages when I do statistical analysis and I'm not familiar with the software enough to know how to achieve what I'm looking for. Just by looking at this data, can you make a suggestion for what analysis can be used to logically evaluate this data?
A better question would be: is it possible to use some sort of predictive analysis to determine what the lowest film thickness can be added that will still achieve a passing after 360s? If this is not possible, what are some things that can be extrapolated from the data besides failing and passing at the extreme ranges of the test?
The additional data helped tighten up the prediction line, but more data in the gap (0.6 - 1.0) would improve it further.
NOTE: The vertical axis is the probability of passing.
E Question on how to analyze Customer Survey Results Statistical Analysis Tools, Techniques and SPC 2
S FDA 510(K) submission question US Food and Drug Administration (FDA) 4
Ron Rompen Question regarding CMM probe damage General Measurement Device and Calibration Topics 4
T FDA UDI Question - Class II Medical Device Other US Medical Device Regulations 1
C Complaint Return Sample Size Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
8 Drawing Feature Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Question on electronic signatures and initials on batch records ISO 13485:2016 - Medical Device Quality Management Systems 3
A Special Characteristic question from Automotive CSR Customer and Company Specific Requirements 9
Ron Rompen GDT Question - is this even correct? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A PPAP question for audit APQP and PPAP 16
C ISO Question - Do you say "I-S-O" or "I-Soh"? Misc. Quality Assurance and Business Systems Related Topics 14
D Question regarding where "validations" fit according to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
D Question on Supplier Quality (SCAR) ISO 13485:2016 - Medical Device Quality Management Systems 6
A +0/-.001 Tolerance question - Feature size is 1.249 +0/-.001 - Actually measures 1.2493 (.0003 OHL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Question and advice for a supplier self audit questionnaire ISO 13485:2016 - Medical Device Quality Management Systems 6
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
A Design Change/ECO Related Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Configuration Item definition question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Quality Management System Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
I IMDS Error Message Question RoHS, REACH, ELV, IMDS and Restricted Substances 1
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 3
C Gauge R&R Question Using Minitab Software 1
K Question on MDR classification EU Medical Device Regulations 4
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
M Clinical Decision Support Software Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
D Equipment Register and PM question ISO 13485:2016 - Medical Device Quality Management Systems 2
D Question regarding "storage and distribution" ISO 13485:2016 - Medical Device Quality Management Systems 1
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
D Equipment Register related question ISO 13485:2016 - Medical Device Quality Management Systems 1
S Study sign off question / responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
A Question on Authorized Representative in Malaysia Other Medical Device Regulations World-Wide 3
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
T Question for: Cg & Cgk calculation General Measurement Device and Calibration Topics 3
N ASL Question for GitHub ISO 13485:2016 - Medical Device Quality Management Systems 7
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
